4th gen Engine swap
Discussion in 'Gen 3 Prius Technical Discussion' started by Ata, Nov 18, 2025 at 1:24 PM.
  1. Ata
    Ata New Member
    Tuesday
    St louis
    Swapped the engine with a 4th gen engine
    Now it says hybrid malfunctioning and throws
    Poa40 and poa41 error
    Anybody has any idea whats up with it?
  2. Tombukt2
    12,900
    2,315
    Looks like the Gear wrench software. . I got a bunch of this changing from federal to JDM gen3 swap . The JDM throttle body didn't seem to be happy and a miserably failing HV battery. Once dealt with . All worked for a short while . Everything's plugged up safety plug in and all that ,?
  3. ASRDogman
    ASRDogman Senior Member
    7,538
    3,892
    Everyone has issues when the put the different engine in. If you search prius chat you can find many
    threads about the issues and how to possibly get a fix for them.
  4. Mendel Leisk
    41,301
    What was the miles, and the reason for doing the swap?
