Stinky vent hoses
Discussion in 'Gen 2 Prius Main Forum' started by highdesert, Nov 18, 2025 at 4:33 PM.
  1. highdesert
    highdesert New Member
    Yesterday
    Idaho
    Hello everyone. We bought a great 2007 Toyota Prius with no issues, except the stink from the hoses. I have verified that the battery hoses stink really bad. I tried to order some off eBay, but they also stink. I heard Toyota did away with these hoses in third generation Prius batteries? does that mean I’d have to upgrade to one of these types of batteries to get rid of the hoses? I take it? I can’t just remove the hoses from my current battery? what are my options to get rid of this smell? Any in all Help appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    12,675
    5,113
    Pacific Northwest, USA
    After the first year or two of Gen3 (2010-2015) they instead relied on the hybrid cooling fan to evacuate the gases from the battery module vents. This is most likely due to so many people complaining of that classic Prius electrical stink that you can smell in the battery air intake vent in Gen2. The source of the smell is caused by the minor amounts of vented gas that interacts with the plastic chemicals in the vent tubes.
    In your case it would be safe to remove the vent tubes to eliminate the smell, or better yet upgrade to a sodium-ion pack that doesn't use those tubes.
    Also because venting happens when pack runs in high temps, like rush hour traffic after being in a hot sunny parking lot all day, you'll want to run a phone app via an OBD2 reader to run your hybrid battery cooling fan more often. Hybrid Assistant app is particularly easy to use to control that fan speed.
  3. Tombukt2
    12,898
    2,315
    This is a real thing ? Hmmmm I get no smell even wen I overcharge an ole crappy pack by semi accident . No smells not even a external shop fan on pack . I'll have to look out for that smell never noticed . Me thinks some of these things built into later gens of folk . Kinda like the gluten business or .
  4. ChapmanF
    18,053
    Yup.
    PriusCamper and xw20_driver like this.
  5. rogerthat
    rogerthat Active Member
    385
    123
    Georgia
    Yeah, some of those tubes have a nauseating hospital/urine odor. I replaced mine in 2015 with silicone tubes. Pretty easy to punch in the holes. I'm sure there are a few threads on priuschat detailing the process. It still took at least a year for the smell to disappear as it had already permeated the car. Not all vent tubes had this smell so very likely a specific supplier issue.
  6. rogerthat
    385
    123
    Georgia
    Here's a pic of my silicone tubes when I switched them over to my new battery. I had read somewhere that these new battery cells didn't even vent and I think I recall the vent nipples being closed, but I still installed the tubes.
    xw20_driver likes this.
  7. xw20_driver
    xw20_driver Junior Member
    89
    46
    PNW
    Do you have a link to the source of these silicone tubes?
  8. PriusCamper
    12,675
    5,113
    Are you a cigarette smoker? That's a common reason for people not noticing smelly stuff.
  9. PriusCamper
    12,675
    5,113
    Do you think when Toyota decided to eliminate the vent tubes they change the battery cooling fan settings so it runs more often to address heavier reliance on it for vent modules?
