Delay when in reverse and maybe in drive?
Discussion in 'Gen 2 Prius Main Forum' started by bluecrazymonkey, Nov 20, 2025 at 8:02 PM.
  1. bluecrazymonkey
    bluecrazymonkey New Member
    Earth
    I just started noticing this like a couple of weeks ago or maybe a month ago. I think i swear I used to be able to reverse right away after putting in R but now it seems like its delayed 2-3 seconds. Sort of the same with D maybe I am not sure about this.
    My theory is that this seem to have started happening when I started using parking brakes on hills (I'm a delivery driver) I used to not do that until i learned its a good practice to do that so it doesn't mess with your transmission over time. I am pretty sure the delay in reverse started happening because of this since when I look back at the time frame its when this problem started appearing around when I started using parking brakes but again this is just my theory.
    The way I use parking brake from what i hear is to push down the parking brake all the way then press P and let go off the brake.
    Also when going R when looking at the display it takes 1-3 seconds, same for D, I'm just mentioning this part as well in case.
    I have a toyota prius 2008 currently at 119,000 miles. I bought this car at 103,000 miles. I have no issues so far and its been great also would like to mention its a salvage.
    Also i dont know the health of the 12v battery.
    Here are the maintenance i got done so far
    106803 brake fluid flush and bleed
    107779 transmission fluid drain and fill (4 qt)
    110000 oil change
    111955 serpentine belt and idle pulley
    113000 radiator replaced (person before me used a junkyard piece for this)
    115338 spark plugs changed, oil change
    115338 throttle body cleaned, mass air flow sensor cleaned
    edit: checked my 12v battery it shows 14.0v when car engine is on, 12.3v (ACC), 12.0v IG-ON mode
    im assuming maybe my 12v battery could be the culprit?
    #1 bluecrazymonkey, Nov 20, 2025 at 8:02 PM
  2. dolj
    dolj Senior Member
    8,425
    4,284
    Wellington, New Zealand
    No, and there is nothing wrong with your battery. It is just showing that it is not new. It wouldn't hurt for you to get into the habit of charging it up to full once every two weeks using an external charger, to ensure it lasts as long as possible.
    For what it's worth, I don't think there is anything new with the delay you mention, just that you are noticing it now when you didn't before. With the change you made to your park brake routine, maybe you move to D/R, then get to the gas pedal sooner than you did in the previous routine.
    With regards to your routine, a better sequence is park brake on; foot off brake pedal - ensure park brake is holding**; Press P - although if your next step is IG-OFF, you can skip that as the shutdown sequence sets P anyway.
    The problem with noticing something is, you can't 'un-notice' it. Think of all the scratches you notice that you never saw before. Once you know they're there, you see them every time.
    ** If it does not hold, press the foot Brake; release and set the park brake one more click than last time; check it holds. If it is still not holding, repeat these steps. It is worth noting that you only want to apply enough park brake clicks to hold the car safely to avoid stretching the park brake cable. You don't want to be in the habit of mashing the park brake pedal 'to the floor'.
    #2 dolj, Nov 20, 2025 at 10:04 PM
  3. bluecrazymonkey
    Earth
    I get what youre saying about when you notice something then its always there however id like to say im about speed and efficiency in my job and i know for sure I used to be able to reverse out immediately after shifting to R but that doesnt seem to be the case. I always did everything the same, nothing has changed in regards to my actions on how i drive my car other than just now using parking brake on hills sometimes.
    Also on a side note I just noticed my vanity light isnt working now
    edit: also I did the battery testing after the car has only been sitting for an hour in my parking lot after using it all afternoon
  4. dolj
    dolj Senior Member
    8,425
    4,284
    I'm the same, but I notice that my brain is faster than reality sometimes. I move the selector, but just not quite enough (or hold that split-second long enough) to actually select the gear, then try to go, but no go. I find that being a fraction slower to be more deliberate is faster in the long run. YMMV.
    Coincidence. The bulb has blown. How often do you check this?
  5. bluecrazymonkey
    Earth
    yeah I get what youre saying but I move the selector to the desired gear but it takes 2-3 seconds for the dash reverse cam to show up when it should be instantly.
    I also find it a coincidence that not only 1 bulb but two vanity light bulb went out and I cant remember the last time I checked it maybe like a couple of weeks ago?
