2014 Prius V want to avoid head gasket problems
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Mountweasel64, Feb 20, 2024.
  1. BiomedO1
    3,496
    1,818
    SacTown, Ca
    It's a gen3 and too soon to tell. You gotta remember that people jump on this site to rant about what went wrong and how to fix it cheaply. While the gen3 is probably the worst reliable Prius line when compared to the other generations - the bar was already set very high.
    I would drive it and see; but if someone wants to give you a decent offer - I'd probably take it.
    Tim Jones and ksyolsen like this.
  2. ksyolsen
    ksyolsen Junior Member
    55
    Haslett, MI
    2013 Prius v wagon
    It’s already had the inverter recall done
    The battery is in good health
    Yeah, the brake booster is a $1200 part but can “fail” for years before actually needing to replace it from what I’ve read.
    I’ve already put so much into the car (brakes, tires, EGR/intake cleaning, coolant, spark plugs, windshield, struts, alignment, etc etc) and I’ve only had it a month.
    Every car is going to have repairs, they’re mechanical and it’s a 2013 with 166k miles. I’m not surprised that work has had to be done. I just don’t want to jump ship just to acquire another vehicle with someone else’s problems again.
    #42 ksyolsen, Nov 22, 2025 at 4:35 PM
  3. Tim Jones
    Tim Jones Senior Member
    1,757
    565
    SE Texas
    2011 Nissan LEAF
    OK.............. I'm out of here aparently you know more about this than me............... Start saving $$$$$$$$$ for the real pain
  4. Mendel Leisk
    41,326
    I'd hang on. You've done the EGR clean, which is not trivial. And you're aware of the possible pending issues. There's head gasket links in my signature, which'll give some idea what you'd be in for, if and when. Even if you opt to use professionals, it's good to know the process.
    ksyolsen likes this.
