2010 toyota prius cylinder number 4 indentification
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tjohnson329, Feb 17, 2023.
  1. tjohnson329
    tjohnson329 New Member
    New York
    I
    I have a 2010 toyota prius with a P0304 cylinder 4 missfire. I have read the thread and looking to troubleshoot but I dont know which one is cylinder 4. any help would be appreciated.
  2. Tombukt2
    13,127
    2,355
    Stand on the right side of the car with the hood up You're looking straight down at the front of your engine at this point The number one spark plug is the closest to your body number two three and four are right behind so the number for spark plug when you're sitting in the car would be the one closest to your probably right knee so if you're standing in the front of the car It would be the last spark plug on the left closest to the driver the one on the far right closest to the passenger is number one
  3. mjoo
    mjoo Senior Member
    1,160
    1,329
    Michigan
    Cylinder #1 is closest to the front of the engine. The front of the engine has the harmonic balancer and accessories (water pump, etc). The rear of the engine is connected to the transmission.
    Cylinders are numbered in ascending order starting from the front to the rear.
  4. Mendel Leisk
    41,649
    What's the miles on it? Has the EGR system ever been cleaned?
    Cylinder numbering:
  5. bisco
    52,098
    Same poster with the bad egr
  6. Mendel Leisk
    41,649
    Ah, the ol' double thread trick.
  7. Cheryl A
    Cheryl A Junior Member
    Is the cyl order the same as firing order when identifying a fault code?
  8. Cheryl A
  9. Cheryl A
  10. Brian1954
    Brian1954 Senior Member
    2,306
    921
    South Central PA, USA
    Trouble code P0301 means the misfire is from cylinder #1.
    Trouble code P0302 means the misfire is from cylinder #2.
    Trouble code P0303 means the misfire is from cylinder #3.
    Trouble code P0304 means the misfire is from cylinder #4.
    I do not know the firing order of the engine off hand, but the car's engine control module (ECM) knows the firing order, and it will activate the trouble codes listed above for the correct cylinder number that has the misfire.
  11. ASRDogman
    ASRDogman Senior Member
    7,653
    3,940
    1-3-4-2 I believe it is.
    But starting from the front of the engine, where the coolant pump, compressor and crank pulley are,
    is #1, then 2-3-4.
    So If you get a code for cylinder #2, you don't look at the firing order, it would be the 2nd one from the front.
  12. Mendel Leisk
    41,649
    Yes, if you’re standing at front of car facing the engine bay, cylinder one’s at the left end (aka “front”), and they go left-to-right in numeric order.
  13. ETC(SS)
    7,230
    Cheryl....
    Tell the forum more about YOUR car.
    The original poster vapored in 2023.
    If you're experiencing the "Prius Death Rattle" and have a cylinder misfire code then you probably need to stop driving the car until we talk about things like mileage, coolant levels, EGR coolers, etc.....
    If the coolant level is solid and you've cleaned the EGR loop a bunch of times and your car (a 2010?) only has 90,000 miles on it then this will be a much different conversation.
