Coolant valve hose positions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Michael Garrahan, Jan 16, 2018.
  1. Michael Garrahan
    Michael Garrahan Junior Member
    Any help appreciated. I've watched and read all coolant valve threads. 3 years ago my coolant valve was replaced but check engine light never went off, mechanics said they did everything and are stumped, except for replacing storage tank etc. Now it's time to get inspected, so I figured I'd replace the valve again myself. After weeks of YouTube and this forum, I had a good handle on replacement and bleeding. But I noticed that the top and middle hose may have been put on incorrectly 3 years ago. Possibly my valve isn't bad, just the previous mechanic was. So for starters, until tomorrow when I get the new valve in...Which hose goes with which valve. Bottom one is no brainer, top and middle one I need to get right. So please anybody tell me where the top hose leads to, and middle hose leads to. They both have white dots, think the mechanic tried to cover his nice person. So please tell me where each hose leads to and I'll be ready to go. Thanks.
    SFO likes this.
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Welcome to PriusChat!!
    Good guess on the mechanic messing this one up, its happened before.
    The easy way would be to just switch the two hoses around and see if the check engine light goes out after a 12v reset.
    Pretty sure the middle hose goes to the engine block and the upper hose goes to the heat pump.
    How is it currently routed?
    Let us know how it all works out :)
    Sistroe likes this.
  3. Michael Garrahan
    Thanks for the reply. Yeah top is routed to engine, middle to pump. I'll switch it around today. Let you know.
    SFO likes this.
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Is the same DTC still logged as before the pump was replaced?
  5. Michael Garrahan
    Yes. Just replaced coolant valve, bled lines, switched the hose configuration, did 12 v reset. Check engine light came back on. Could it be the sensor? Or the relay? Haven't checked the code yet, will swing by auto store tonight or tomorrow. I'm stumped.
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Without the code it would be hard to say what the potential problem is.
    You will need a Hybrid compatible code reader, the one at the auto parts store may not be fully compatible.
    You profile doesn't show a location, where are you near and maybe someone can offer help.
    Raytheeagle likes this.
  7. Michael Garrahan
    With the old valve and new one, I pop the relay out and jump with a multimeter, I hear the valve pumping. Could it be the inverter pump? Though I I feel movement through those hoses.
  8. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Check the inverter pump by touching it, if your hand can't reach it then use a stick/pencil/etc and feel for vibration.
    Also you can take the cap off the reservoir and look for movement on the liquid surface.
  9. Michael Garrahan
    Brooklyn NY
  10. jerryroy1
    jerryroy1 Junior Member
    Downey CA USA
    Anyone have a part number from Toyota for this hose on a 2006 Prius? (circled in red)
    #10 jerryroy1, Mar 4, 2019
  11. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
  12. Mendel Leisk
    41,357
    Skibob and SFO like this.
  13. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I like the picture but now I’m confused. Is the 3rd engine coolant pump inside the coolant storage tank? My understanding is there are 3 engine cooling and 1 inverter cooling pumps.
  14. Mendel Leisk
    41,357
    SFO likes this.
  15. Malom Rosz
    Malom Rosz New Member
    Tucson AZ
    I
    I too had the same problem with a replaced coolant control valve followed by a check engine light. I also got a P1116 code which deals with the sensor in the hot water tank in the Front of the front left wheel well. Appears to be on the lower part of this tank and kind of resembles a spark plug. Here is a link to a very interesting video concerning the proper way to burp the cooling hot water tank after any kind of draining of the coolant. The kid that is featured in this link seems very bright on all things Prius.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    SFO's engine coolant diagram although very nice doesn't show the connections to the throttle body or the radiator but is good for the 3 way valve.
    To the Op the fact that you bled the system means you have more work to do. Its sometimes very very difficult to get all the air out of the engine loop.
    There is a hex key bleed port on the drivers side of the rad. Open that up and let it drain till the air stops coming out. And it will really help if you jump out the CHRS pump relay like you did with the valve to cycle the thermos pump that's where the air is getting stuck that and the
    top of the cylinder head. Real pia.
    Be sure you have all the air out if you have alot of air in the system you can easily overheat the motor and pop the aluminum head.
    You will never know the engine is over heating because the damn car does not have a temp gauge. After you think you have the air out take it for a drive with the heat on and listen for gurgling under the dash. That's trapped air. Any water rushing sounds means you still have air in the system. If it sounds ok you should be ok.
    This is where the Scan Gauge pays for itself. You can monitor engine temp. And the X gauge can pull hybrid codes and clear all codes also.
    Based on what I see on this site the auto parts guys obd code reading is pretty lame. And there usually not able to pull hybrid codes either.
    Tell the wife you want a Scangauge for Christmas!
  17. yogithom
    yogithom Junior Member
    prescott, az
    What gen is this a diagram for?
  18. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    That would be the Gen2 platform, which is what this thread is about.
    edthefox5 and Raytheeagle like this.
  19. Jalal
    Jalal New Member
    Yesterday
    Cincinnati, OH
    I have a question about a hose on my 2010 Prius. I accidentally pinched the metal pipe while trying to remove this hose (completely unnecessarily) and I wonder what it is for?
    i tried un-pinching it as much as i could but I’m not sure if i should replace the metal pipe.
    any help identifying and:eek:r advice on whether to resolve the metal pipe still be appreciated!
