I recently entered into the Prius world by buying a 2005 with about 198000 miles on it. It came to me with a known bad brake actuator and my first order of business was to get it swapped out. After trying two different used units from junkyards, I gave up and bought a new Toyota unit. I installed it, bled the system, I'm pretty sure I did all the relearns and resets, and all was good. For about 3,000 miles or so. This is the car I bought for my daughter to drive to college, so she's put most of the miles on it. She told me that after a hard braking event the three brake/ABS/VSC lights came on. I brought it back into the garage and found that it had a C1253 with INF code 138: MTT input is 3.5V or less for at least 1 sec (0.2 sec during initial check) when main relay 1 monitor is 9.5V or more and motor relay 2 is on. Knowing that things get wonky with old batteries, I put a new battery in it and everything seemed okay again. I couldn't get it to fail on me so I sent it off. It happened again while she was away at school so, since she's a less-experienced driver, I hooked up the trailer and went and fetched it (and her) to get it back into my garage to work on it. I followed the flowchart: Active test of motor relay 1 and 2. Worked fine - relays clicked, pump ran. Inspect ABS-1 and ABS-2 fuse. Checked resistance all along the fusible link assembly and had 0 Ohms. Inspect brake actuator assy. 6 different resistance tests, and they were all (probably) good. Probably? Well, BM2 to MTT and MB1 to MTT were both 500 Ohms exactly, as opposed to the "about 33 Ohms" that the flowchart calls for. It's a brand new unit from Toyota and I saw another thread or two where others indicated that the 500 Ohm reading was expected. So I moved on to the next test. Check harness and connector between the skid ECU and the brake actuator. Three resistance tests, and all three passed. Use the scanner to measure the voltage from the accumulator pressure sender. This was also within spec The only thing left after that is "replace skid control ecu". So I went out to the local junkyard this morning and pulled a unit with the same part number off of another '05. After figuring out how to get to all three bolts without removing the steering column, I bought it home, got it installed in my car and... same code showed up. I fiddled around a bunch with trying to clear the memory, reset the yaw sensor, re-run the linear valve offset learn, to no avail. If I cleared out the codes, they would come back immediately if I ran the manual activation of the ABS MTR relays from my scanner. Eventually, I performed the memory clear, left the battery unplugged for a while, and installed the resistor that came with the new brake actuator. I reconnected the battery, then did the linear valve offset relearn and the yaw sensor relearn. No codes came back, so I then went through and manually activated the MTR relays about a dozen times. Still no codes. I gave it a quite drive for a couple miles, including some hard braking. Still no codes. I don't know if I did anything or if it's just going to have the same problem again. The only thing that really changed is that I have the resistor replaced now, but I haven't read anything so far that indicates that the resistor would make any difference other than what it sounds like. I suppose it's certainly possible that I grabbed a used skid control ECU that is broken in the same way as my original one, but I haven't seen any way to test one - it seems like if you don't find any other problems, replace that. Is there anything else that might not be on that chart which could cause this sort of problem? I have no other codes, but could a system that isn't totally bled get that sort of result? I hate to call it "fixed", because it's done this to me before, and I'm very open to suggestions!
Very nice description of all the work you did. One question. Can you please describe how you did the brake bleeding. Did you use a scanner (if so, which one) that was capable of activating all the little valves in the brake actuator?
I've got an Autel MaxiCOM MK808S and I used its bleed function where it ran me around the all four corners and actuated the various valves. I will say that I've noticed that when the system is working, there's a lot of groaning noises from the rear brakes. Not like a metal on metal noise, more like the noises that the linear offset valve relearn process makes. I have no idea if that has anything to do with anything. After letting the car sit overnight, I just started it up and the lights are back on, same code/INF. I'm kind of at my wit's end here...
If for some reason you think that the brakes may not be bled? What always works for me is to start at st rear rt open bleeder lay they're and watch it wen air passes it'll bubble at the bleed fittings opening and then resume the steady drip. By looking at this enough you will notice how this works no. Pedal pushing is going on . 5 min minimum at each corner . Look at the fitting for the time . Lay on a pad be comfortable . If you get a spiddle of bubbles at a wheel. Continue letting that fitting drip another 3 to 5 min . To make sure it's clear . The gravity is pushing the air down n out .
I pulled the relays off and bench tested them and they worked perfectly. I wasn't able to pull the full amperage, so it's entirely possible that the contacts aren't.. uh.. contacting. For good measure, I swapped out the relays with ones I harvested from another car, but had the same problem. I can absolutely hear the relays clicking on and the pump running, though, when I do the commanded activation of the MTR1 and MTR2 relays with my scanner.
I spent some time glaring at the car and calculating how far into the parking lot I'd need to move it so that I didn't catch my garage on fire when I doused the car in gasoline and tossed a match on it. And then got back to work. The freeze frame data has indicated every single time that the MTT voltage is exactly 0. So I pulled off the cowling, backprobed the MTT pin on the accumulator connection, powered up the car, and started pumping the brake pedal. As soon as the brake pump activated, I read 7 volts. I'm not very good with numbers, but I think that is greater than 0. That tells me that the accumulator is probably doing what it needs to be doing. I went in and backprobed the top connector on the skid ECU next, again selecting the red wire which is the MTT one. Powered up the car, started pumping the brakes, and as soon as the brake pump turned out, I got the same 7 volts. That tells me that the wiring is solid from the accumulator to the skid ECU. I had also cleared the codes to make sure that I wasn't just wiggling loose wires and fixing the problem as I observed it. Sure enough, the code came back with the same 0 MTT volts. This leads me to believe that the accumulator is good and the wiring is good but that I have managed to score myself a skid ECU that is bad in the same way as my original one.
Your saga sounds very similar to this one (different, but closely related vehicle): c1253 134/138 and why factory testing procedure won't save you - ClubLexus - Lexus Forum Discussion For the impatient, the code switched from 134 to 138 when the two relays were swapped, and back again when swapped back. The relays passed all the tests, but one was still not up to snuff and the car would throw a code corresponding to which slot it was plugged into. If swapping the relays doesn't change the code I would check for corrosion in the socket and at both ends of the wires from the relay indicated by 138. Then pull the relay and check for shorts to ground or another wire. Another approach would be to get a second socket, "plug it into" the original with some wires, plug the relay into the second socket, and check the currents observed on the drive and load pins. (Solder a wire onto each pin on the socket, and solder a spade onto the other end of that wire, which is similar in size to the connectors on the relays. Don't wire it wrong!) This way you can measure the currents without having to cut into the wiring harness, just cut into the socket to socket connecting wires. Repeat on the other (good) socket/relay and compare.
Was this measured all along the top of the fusible link? There are a bunch of electrical connectors on the bottom and sides and I have read in this forum that they can corrode if the vehicle has been on salted roads. Kind of a pain getting to them to check though: Maybe measure the resistance from the other ends of those wires where they come out on connectors?
I did swap the relays around and grabbed a set from another car and tried them as well with no change in the behavior. I also only checked from the top of the bus bar to the bottom of the fusible links, and didn't try to load test the circuit from the positive terminal all the way to the actuator. That said, though, I'm measuring 7.something volts on the MTT wire at the skid ECU connector while the ABS system is reporting that the MTT value read by the skid control unit is 0 volts. I don't fully understand how the system works, but is it a bad assumption that if the actuator is coming on, giving good brake pressure, and outputting >3.5V to the MTT circuit that the relays, fuses, and wires from the PDC to the actuator are testing good? And further, if I'm reading >3.5 volts on the MTT pin at the skid control ECU connector then either the connector is faulty or the skid control ECU is faulty?
