2024 PRIUS XLE AWD TPMS SENSOR QUESTION
Discussion in 'Gen 5 Prius Technical Discussion' started by longshot, Nov 26, 2025.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I believe the 315MHz US sensors are the "old" ones and the 433MHz Japan/European sensors are the "new" ones. I checked the OP and saw they bought the 433MHz version before I replied to them. They should be okay just letting the car do the work.
    My understanding of the difference is that the 315MHz frequency band in Europe is reserved for something else. That's why they had to make 433MHz sensors. (this all happened many years ago) I assume it was cheaper to build the 315MHz sensors back then, so it was worth it to make two different versions. Since Toyota seems to be switching over to 433MHz for everything now, I assume the production costs between the two versions is now low enough that it doesn't make sense to keep making one version for North America and one version for the rest of the world.
    #21 Hammersmith, Nov 27, 2025
    longshot and KMO like this.
  2. notspam3
    notspam3 Member
    79
    Toronto
    2024 Prius Prime
    XSE Premium
    Try buying from a different tire shop next time...when I got my new winter wheels they "programmed" it for free. The only scammers I know who charge to program the TPMS are the Toyota Stealerships.
    Their free programming via ODB2 didn't work, I had to manually tell the car to learn the new set of TMPS through the maintenance menus.
  3. VelvetFoot
    VelvetFoot Active Member
    1,146
    452
    New York State
    2026 Prius
    The Amazon search results for '2026 Prius TPMS sensors' are littered with 315 mHz units. They call them 'preprogrammed' as well.
  4. longshot
    longshot Junior Member
    83
    There has to be someone that's swappedin
    ordered thru tire rack. The place told me 25 per tire to program! I said no thanks. I could buy my own for that price. Told them just mount and balance and I'll take care of the programming part. They act like programing tpms takes an hour and is hard physical labor lol
  5. longshot
    83
    Yeah now I'm wondering if the 433mhz will work
  6. Gokhan
    Gokhan Senior Member
    6,483
    2,594
    Paramount CA
    If the frequency is different, it will not work for sure.
  7. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Once again, everything I'm seeing says that the gen5 can recognize BOTH the current 433MHz sensors(which are what come with the car) as well as the legacy 315MHz sensors. However it's likely that the 315MHz sensors would need to be programmed with a scantool.
    The car comes with part numbers 42607-47010 or 42607-0E090(newest version). Both are 433MHz.
    The official Toyota parts website also lists 42607-47020 as fitting the gen5, which is a 315MHz sensor.
    longshot and Gokhan like this.
  8. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    Weird stuff, man.
    edit: Doing some internet searches, I only come up with 315 mHz for those part numbers.
    #28 VelvetFoot, Dec 1, 2025
  9. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    For instance:
    (It's got the groovy rubber stem too, lol.)
    longshot likes this.
  10. longshot
    83
    I contacted the nearest Toyota Dealership using my VIN# this is the part # they gave me 42607-0E090 but couldn't give me the mhz info lol
  11. longshot
    83
    Where you see the mhz in the pics attached?
  12. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    I didn't. I had to look outside of the Toyota page, as in post #29.
  13. longshot
    83
    I'll give it a try again. I didn't drive 30 min non stop. I know I drove at least 20 min Or so
  14. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    The whole winter tires/wheels situation sucks.
  15. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,482
    Taylors, SC
    I would still do the cloned original TPMS transmitters route.
    If you had it done by a tire dealer like Discount Tire, they are guaranteed for 6 years or 70,000 miles.
  16. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    I have a suspicion it may not be quite so simple. The frequency may not be inherently linked to the programming need. I would expect the higher-level protocol to be independent of the radio frequency.
    Toyota themselves may only currently supply manually-programmed (old protocol) 315MHz and automatically-detected (new protocol) 433MHz in North America, but it's possible that you could use the old protocol at 433MHz, and it may be that's what these third-party sensors are doing. (Presumably Toyota would have shipped with that in Europe previously, even if never in the US).
  17. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    Where are you seeing part numbers 42607-47010 or 42607-0E090 there?
    Mind you, the fact they're rubber-stemmed is supposed to indicate (according to Car Care Nut) that they're new style - so maybe those are new-style auto-programming 315 MHz ones?
    (I'm not sure if I'm 100% convinced that the metal/rubber stem thing also 100% correlates though, across markets. My spare set got yet another part ID 42607-02070 from the Toyota dealer, and they're metal stemmed, but I thought they were new style. )
    #37 KMO, Dec 1, 2025
  18. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    You are correct. Its says it's a replacement for 42607-0E020, my bad.
    #38 VelvetFoot, Dec 1, 2025
  19. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
  20. longshot
    83
    Drove over 40min. Car didnt pick em up (433mhz). TireRack even says 315mhz for my car. So ordering those now and will report back if they work or not.
    Gokhan and VelvetFoot like this.
