heat stops after 10-15 mins - AC room temperature sensor?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dex3703, Dec 1, 2025.
  1. dex3703
    dex3703 Member
    65
    31
    Seattle
    My 2005 Prius with 173k miles has a problem with the heater deciding to not blow heat after 10-15 minutes of operation. I've had the car since 2013, and the heater/AC has worked fine until the last year or so. AC seems to work fine--I just keep it at max cold--but the heat has started cutting out after 10-15 minutes in the winter. Pleasant 65 or 66 becomes ice cold. I can sometimes get it to return by cranking the temp above 70.
    I'm guessing it's related to the AC cabin temperature sensor, but wanted to ask before digging around. I've seen this mentioned in these threads, though these threads don't speak specifically to my issue.
    AC issue | PriusChat
    Any idea what this is? | PriusChat
    Thanks in advance.
  2. ChapmanF
    18,458
    It's a thermistor, not something you often hear about going bad. But a simple way to check would be to watch the room temperature sensor live data on a scan tool and see if it is or isn't showing a believable reading, before and/or after the heat stops coming.
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,988
    5,282
    Pacific Northwest, USA
    That's the amount of time it takes for the heating system to transition from electric over to traditional engine heat via the coolant. So the system that does that would be a good place to start looking. Watching the the live data like @ChapmanF says will help... Also making sure you don't have any air in the coolant system and ensuring its running at a normal temperature needs to be checked too.
    I think in reality though you don't have any problems with your car, just that its been down to freezing in Seattle area past couple days and setting your cabin temperature at 65 isn't going to warm up the car very well and you need to turn the heater all the way up to hi... As in a vehicle thermostat doesn't work like a house thermostat. For best results get the car as warm as possible as quickly as possible and control the vents and fan speed to optimize cabin temperature.
  4. ChapmanF
    18,458
    If this is a gen 2, though, I don't think it has any more electric heat capacity than gen 3, like somewhere around 700 watts.
    That has never been enough to make a difference I can feel. It does make a noticeable difference in how fast the windshield clears, but the air still feels cool to my hand. The 700-ish watt electric element is just nowhere near close to the rated 5300 watts of heat that can be extracted from the coolant once the engine's warmed up.
  5. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    The first thing to do is check the level of the coolant in the radiator. When the car is cool, remove the radiator cap and make sure the coolant is all the way to the very top. The next thing is to check the level of the coolant in the plastic overflow bottle.
    priumium likes this.
  6. dex3703
    dex3703 Member
    65
    31
    Seattle
    Well whaddyaknow--the coolant is a little low. I've never seen that in this car. I had the coolant-inverter coolant changed at the dealership a couple years ago. Guess I'll add some and see if that helps. No warnings or other indicators--no sign of leaks.
    Is it the same coolant for the radiator and the inverter? The bottle next to the inverter could also use a little, though it's not to the 'low' line.
  7. Brian1954
    2,371
    954
    Yes, both cooling systems use the same coolant.
    After filling the radiator, come back and tell us if that fixed the problem.
    dex3703 likes this.
  8. PriusCamper
    12,988
    5,282
    Yeah... Once I realized OP was from the Seattle area, which rarely experiences weather down to freezing and OP said they keep their heater temp on the bottom end of its abilities and because we've had freezing temps the past couple days, I was certain that this was OP error not vehicle error.
  9. Tombukt2
    13,292
    2,398
    Small coolant disappear in a gen2 puts heat off really quick car won't overheat . But no heat .
  10. dex3703
    dex3703 Member
    65
    31
    Seattle
    I added maybe half a liter of coolant to the radiator (very little), overflow tank (most of it), and the inverter tank (also very little). I haven't driven the car long enough to tell if that fixes it. Do I need to bleed it? Be worried about anything else? I don't see any leaks, and don't know why the coolant would drop like that.
  11. Tombukt2
    13,292
    2,398
    Gen 2 heat disappearing is almost always because air is taking up some space set coolant should be . Fill it up you have heat in my situation 45 min later cool air and level down again . Mine is HG seepage . Won't get fixed this is on my work vehicle with over 540 on it
  12. PriusCamper
    12,988
    5,282
    As long as you're topping off under the radiator cap when the engine is cold for a few days in a row, you'll have successfully gotten all the air out of the system.
  13. Tombukt2
    13,292
    2,398
    I you have to keep this up . You're losing a bit . If it's a seeping HG. My car will be out of heat in 45 min but car will run all month without issue in town etc . Wen I get on hiway going solid 65 mph . The triangle flashes etc like overheat . Get wer I'm going top off this car Been like this for months now it's old work vehicle so not fixing still drives 45mpg I use on colder months mainly and in town . In town it'll drive w no triangle for months you gotta get it up to speed 30 min or so .
  14. PriusCamper
    12,988
    5,282
    I'm pretty sure in Gen2 Prius chronic coolant loss is usually attributed to engine water pump failure rather than Headgasket, which is a Gen3 problem.
  15. dex3703
    dex3703 Member
    65
    31
    Seattle
    I was just thinking that. The car is a 2005 with 173k miles. Should the water pump be pre-emptively replaced? Is that something I can do myself? I had the coolant changed at the dealer as it looked way more complicated than usual.
  16. PriusCamper
    12,988
    5,282
    If it was a gen3 it's an electric pump and so easy to replace, many do it pre-emptively. But on Gen2 it's a belt driven pump and way more hassle to replace and may people have double your mileage with still no need to replace it.
    But if you keep losing coolant and it starts running really loud then replacing it would be wise.
    dex3703 likes this.
  17. Tombukt2
    13,292
    2,398
    Man I was hoping this generation 2 09. Was just that. previous this engine had lost its water pump belt and it probably took me 48 to notice no notices from car at all no coolant missing etc weep hole nada put new garages belt on . It's still on . Water moves great. In approx 45 min driving in town to store etc it loses about two litre bottle worth of coolant . Plastic is all missing under the car. I parked this car on very clean surface looking for any leaks they're not a hose or connection leaking on this thing . I've not scoped bores . All that's left .
  18. dex3703
    dex3703 Member
    65
    31
    Seattle
    Thanks. I found a
    Thanks. I found a Youtube video explaining how to replace it--doesn't seem any worse than any other water pump I've replaced. I don't hear any noise or see any leaks, but I'll look closer.
  19. Tombukt2
    13,292
    2,398
    I've replaced about 5 water pump like on Gen 2. But other Toyoda engines over 47 years of driving some those vehicles still on road today . those mech. Pumps can go forever . Not to tite on the belt.
  20. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Our 2007 did something perhaps related yesterday.
    I had to drop my daughter off at the Amtrak station in Burbank by 7:30 AM. It was fairly cold (for us) when we left, below 60F. The heat worked as expected all the way to the station (about 50 minutes, mostly highway, with some crawling along due to heavy traffic) and it also worked for 15 minutes or so coming back. Then going up a long hill (the only big hill on this route) all of a sudden it started to blow outside temperature air out the vents instead of the 72F set on the control (fresh air position, not recirc). Outside temp by this time was mid 60's. It seemed like quite a sudden transition, but since I didn't have a thermometer stuck in a vent at the time, I cannot be sure that was the case. The temperature was turned up a bit but don't recall if that helped or not because traffic became heavy a short time later and I had to stop messing with the HVAC. The issue seemed to have gone away by itself, but the sun was probably heating the car to 70F or so by the time I got home. Have not used the heat since.
    The coolant overflow tank is at the exact same level it was when I finished bleeding it a while back. (At which time using MAX HEAT nearly cooked me alive in the car.) No gurgling. No actuator sounds from the dash. No CEL. No loss of the heat going up that hill in the other direction, which would have been about 20 minutes into the trip.
    dex3703 likes this.
