Prime 12v battery dead
Discussion in 'Gen 5 Prius Main Forum' started by dr_rock, Nov 30, 2025.
  1. Mendel Leisk
    41,661
    ^ Maybe the connection could be a bit more eloquent though, feed the wire up through the same route the 12 volt positive cable takes? Not over the threshold of weather-proof seal.
    that’s essentially my 3rd gen scenario:
    #21 Mendel Leisk, Dec 2, 2025
  2. Paul Gregory
    Paul Gregory Senior Member
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    The NOCO battery maintainers have detachable gator clips, which leave ring terminals. I find the ring terminals much more reliable than the clips.
  3. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    A battery maintainer tests the battery and tops it up as required.
    A trickle charger delivers a constant voltage which eventually destroyed several of my batteries.
    Prodigyplace likes this.
  4. Mendel Leisk
    41,661
    I know that, you know that. Appreciate it's a misnomer.
    Similar to the expression "flush" being used, in place of "replace" or "change" with some drain-and-fills. Technically incorrect, but very common usage.
    Or, when people refer to bolts by their required socket size, not the thread diameter. It's an expedience.
  5. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    I try not to perpetuate misnomers, if I can.
  6. rjparker
    10,251
    6,401
    PTS, bisco and Brian1954 like this.
  7. Mendel Leisk
    41,661
    As long as we're digressing, how about this one, regularly mangled:
    "I could care less"
    The correct expression being "I couldn't care less"., which actually makes sense.
    Used to bug me, but then I figure, what does it matter, you know (hopefully) what they're trying to say, leave it at that.
  8. VelvetFoot
    VelvetFoot Active Member
    874
    311
    New York State
    2026 Prius
    In what way? :)
  9. Gokhan
    Gokhan Senior Member
    6,327
    2,527
    Paramount CA
    As @Mendel Leisk said, chances are that you will not get a trickle charge, which is a dumb charger that supplies a small current to the battery indefinitely, which would eventually damage the battery.
    You can leave the Noco Genius, which is a smart maintainer, hooked up indefinitely, as it will toggle on and off according to the battery SOC. It will come on about twice a week and charge for about a day each time and then and go off and then repeat after a couple of days.
    Brian1954 likes this.
  10. Gokhan
    6,327
    2,527
    Paramount CA
    Your fifteen-year-old car is a lot cleaner under the hood than his two-year-old. LOL
  11. bisco
    52,100
    eloquent or elegant? :cool:
    Gokhan likes this.
  12. bisco
    52,100
    i googled trickle chargers, and all i came up with was maintainers
  13. Paul Gregory
    2,180
    576
    Alberta
    2024 Prius Prime
    XSE
    One of those expressions that works either way.
    Like "flammable" and "inflammable" mean the same thing.
  14. bisco
    52,100
    i thougght they meant the opposite (n)
  15. Gokhan
    6,327
    2,527
    Paramount CA
    The truck that chased you in Duel said flammable.
  16. bisco
    52,100
    how would anyone know the flammable stuff is inside? :cool:
    Gokhan likes this.
  17. Gokhan
    6,327
    2,527
    Paramount CA
    Right, if it had said inflammable instead, you would have never had inflamed him and caused all that horrible road rage. LOL
  18. bisco
    52,100
    but that's an example that one thing is flammable, and another is inflammable. they mean the opposite, not the same
  19. Gokhan
    6,327
    2,527
    Paramount CA
    LOL no, inflammable means flammable (material) or easily angered (person). Its anonym is noninflammable or nonflammable.
  20. bisco
    52,100
    Gokhan likes this.
