I looked in the multimedia owner’s manual…I really did!
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by HamiltonPrius, Dec 4, 2025 at 4:31 PM.
  1. HamiltonPrius
    HamiltonPrius Member
    164
    Parts unknown
    2026 Prius
    Ok, why is my ringtone, new message and received volume sliders greyed out and unusable in my sound and media > levels settings?
  2. HamiltonPrius
    164
    Parts unknown
    2026 Prius
    Ok, I’ve got the answer for this too. Go to setting>bluetooth and tap on your device. Once in there turn off car play and turn on use phone for media and phone.
    Go back to sound media > levels and the 3 sliders will active. You can now adjust the volumes. Once you have done that go back to Bluetooth >your device and click car play back on.
    The volume controls you just adjusted will be greyed out again but the settings will be saved where you set them.
    Easy Peezy…..
    #2 HamiltonPrius, Dec 5, 2025 at 3:58 PM
    otatrant and VelvetFoot like this.
  3. VelvetFoot
    VelvetFoot Active Member
    640
    226
    New York State
    2026 Prius
    This may be relevant. Or, an answer to a question you hadn't thought of. :)
    I was annoyed with how load the map voice was. Turns out when she's speaking, you can use the volume knob to adjust it.
  4. HamiltonPrius
    164
    Parts unknown
    2026 Prius
    I believe you can also adjust the volume with the knob in messages and while using the phone.
    VelvetFoot likes this.
