Just Installed BM-2 Battery Monitor and NOCO On Board Charger
Discussion in 'Gen 5 Prius Main Forum' started by VelvetFoot, Dec 9, 2025.
  1. Gokhan
    Gokhan Senior Member
    6,331
    2,528
    Paramount CA
    Same with Gen 4, which has an identical BMS. It goes up to 14.4 V, but it is usually 14.1–14.3 V. The battery SOC will affect the actual voltage.
  2. VelvetFoot
    VelvetFoot Active Member
    875
    313
    New York State
    2026 Prius
    First dip, 5 hours after stop. Probably EVAP pump. Hopefully, one or two shots and over, 'cause it does cause a step down in voltage.
    2023p and Gokhan like this.
  3. Gokhan
    6,331
    2,528
    Paramount CA
    Yep, that’s just EVAP, nothing to worry about.
    Gen 4/Gen 5 parasitic drain is mostly an urban legend or myth. The main reason for Gen 4/Gen 5 battery failures is the fact that the BMS doesn’t charge much during warmer months, and if you don’t drive the car frequently for long distances, that could result in battery failures.
    2023p likes this.
  4. VelvetFoot
    875
    313
    New York State
    2026 Prius
    There were 3 tiny dips in half-hour intervals overnight, starting an hour after the probable EVAP pump. Perhaps related?. Makes you wonder what they are. :)
    I might see if my security camera in the garage can pick up the sound of the EVAP pump, lol.
  5. Gokhan
    6,331
    2,528
    Paramount CA
    They could be EVAP or other things. It is nothing to worry about.
    Incidentally, the dips for my AGM battery are shallower than for your flooded-cell battery because of the lower internal resistance of an AGM battery.
    VelvetFoot likes this.
  6. schja01
    schja01 Senior Member
    1,838
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
    What do people do who live in Apartments or Condos with no access to an external outlet?
    I'm a senior and expect to eventually downsize to a Condo and drive as I do now. As in Infrequently.
    I keep my car on my 2A NOCO in the garage 50%+ of the time. If I move with no external AC
    at the new location am I screwed?
  7. Mendel Leisk
    41,666
    Yes.
    Look for a place with outlet in the parking area? I'd recommend to use an "on-board" style charger, one where the charger is under the hood (or elsewhere within the car), and just a cord with 120 volt plug is run out. That way the charger can't be easily stolen. Neither could some joker short out your battery, say if you have a quick connect cable of some sort, run out through the grill. Those cables sometimes have an inline fuse though, which safeguards against that.
    To date I think underground condo parking with electrical outlets at each stall is not that common, hopefully that will change. It's essential for EV's, and good to have for 12 volt battery chargers, block heaters (albeit not that important with heated parking), and just for stuff like power tools, vacuums, what have you.
    #27 Mendel Leisk, Dec 14, 2025
  8. ChapmanF
    18,326
    I have the gen 3 trim that came with a solar panel on the roof, good for 60 watts max. From the factory, the only thing it does is run the HVAC blower to vent hot air out of the cabin in summer.
    I added a little buck converter so it also charges the 12-volt battery; did that back in the lockdown, 5+ years ago, not a battery worry since. And there's still enough of the 60 watt panel output left that it still runs the HVAC blower and vents hot air out.
    On a shelf, I still have a 2000s-era PulseTech solar maintainer that I used on the SUV that I had then. Its panel is about a foot square and rated for all of 5 watts. (I haven't kept up with what a typical output would be for a foot-square panel today!) I just left that panel sitting on the old vehicle for months at a time and it was enough to do the trick.
    It looks like PulseTech's current product that's closest to the same panel dimensions would be their 12-watt, somewhere between double and triple the output of my old one.
    Which seems about right: I think the current Prii with the solar roof option have panels rated about 180 watts, or triple the output of my 2010 from the same size of panel.
    The PulseTech maintainers are advertised to have a battery-desulfating pulse superimposed on their output (hence the name). I have no strong opinion on whether that's worth the hype or not. For what it's worth, their FAQ says it's ok to use with the battery connected in the car, and won't interfere with any car electronics (they even say "This technology has been applied to a variety of military vehicles with very sensitive launching systems or computer systems with no interference or problems."). I have no strong opinion on that either. I used it with no issues on that SUV that I had, but it had 1980s-era electronics.
    #28 ChapmanF, Dec 14, 2025
  9. Mr.Vanvandenburg
    1,357
    577
    2020 Prius Prime
    If you have a battery monitor and can see the data, charge it with the car by leaving it on in park is possible. I do this often so as not to bother with the external charger. Sit in car and read news or whatever for twenty mins or something, depending on what you want. I external charger to 100% at least once a week, and on my truck too. I have the Ancelmonitors on these vehicles, put a bm-2 on my daughters car.
  10. bisco
    52,101
    just carry a jump pack. if you don't drive much, maybe consider a different car
  11. Gokhan
    6,331
    2,528
    Paramount CA
    They sell inverters that can be hooked up to power-tool batteries. If you have the cordless power tool, you might be able to find a compatible inverter. They are very cheap if you already have the power tool with a compatible batery.
    Dewalt-battery compatible inverter on Amazon
    Ryobi-battery compatible inverter on Amazon
  12. VelvetFoot
    875
    313
    New York State
    2026 Prius
    I trended the voltage loss and came up with 8 days from fully charged to 12 V, if the car was just sitting there.
  13. VelvetFoot
    875
    313
    New York State
    2026 Prius
    After a couple days of having the OBDLink MX+ bluetooth dongle installed full time, I think I can say that its power saving mode of 2mA is likely correct.
  14. VelvetFoot
    875
    313
    New York State
    2026 Prius
    This what the 15 day chart looks like.
    I've been driving the car every day.
    Gokhan likes this.
  15. VelvetFoot
    875
    313
    New York State
    2026 Prius
    I opened the door to get something from the car around 730 this morning.
    A dip in voltage occurred, appearing similar to the 5-hr evap pump dip.
    Is it the evap pump again? Or something like the brake accumulator pump (I have to study more on the mysterious workings of the Prius)?
  16. schja01
    1,838
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
    I see similar when a Key Fob gets within a few feet of the door handle.
  17. Mendel Leisk
    41,666
    If I've popped the hood the night before, when I do a simple voltage test (at the jump point in engine bay fuse box) I'll get something like 12.8. If I've neglected to pop the hood, and have to momentarily open the door to use the hood release, voltage will be more like 12.5.
    #37 Mendel Leisk, Dec 26, 2025
    schja01 and VelvetFoot like this.
