Verification of EGR cleaning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusKyle, Dec 5, 2025.
  1. PriusKyle
    PriusKyle Junior Member
    73
    Virginia
    Hey all,
    Have 2011 Prius at 155,000 and I’m thinking of having the EGR valve, cooler and pipe and the intake manifold (all 4 ports) cleaned.
    Not experiencing any issues but out of preventative maintenance.
    1) How can I confirm the work has been done?
    2) How much should it cost?
    3) Any recommendations on a good shop near Northern Virginia where I’ll get an honest work done at a honest price?
    Thanks!
  2. Mendel Leisk
    41,451
    Pretty hard to confirm. I think best bet would to find a shop with a good reputation for doing EGR cleaning. Which may be easier said than done.
    I've heard $600~900 USD
    Leave that to other responders, hopefully somebody fits the bill. :)
    PriusKyle likes this.
  3. ChapmanF
    18,195
    A value of around 20 to 22 kPa in the car's EGR flow insufficiency self-test is typical of freshly-cleaned EGR systems. It's a decreases-with-clogging number; high is good.
    Many scan tools and apps are able to retrieve "mode 6 test results", including that one. You can see several examples in the linked thread.
    PriusKyle and ETC(SS) like this.
  4. ETC(SS)
    7,157
    @ChapmanF already answered #1.
    For #2 I would call a place called Tampa Hybrids in.......wait for it!....Tampa.
    Service - Tampa Hybrids Inc.
    I know they're not in your Commonwealth, but they have a darned good rep and they may even be able to recommend a more local-to-you alternative. Their quote will probably represent what a good, fair, hybrid specialist SHOULD charge.
    If I were close to the beltway and counted a G3 for daily commutes I would even consider a weekend jaunt to the Sunshine state to have them do the work. ;)
    You can GET cheaper - but it may not always BE cheaper.
    Preventative maintenance is like painting on a ship.
    There IS no end short of the scrapyard.
    At 150K you've probably done or had done all of the periotic maintenance for you vehicle as recommended by the manufacturer - but remember.......they will only provide warranty coverage for 120,000 miles - more or less.
    Recommendations:
    Verify all prior maintenance has been done if you bought the vehicle used.
    Start changing (or continue to change) your oil every 5K.
    Consider coolant changes.
    Consider transaxle fluid change IF you can be sure it's done correctly.
    Same with brake fluid.
    Good Luck.
    #4 ETC(SS), Dec 6, 2025
    PriusKyle and Mendel Leisk like this.
  5. PriusKyle
    73
    Virginia
    Thanks. I’ve had my coolant and spark plugs changed at 120.000 and recently did a drain and fill with Toyota genuine transmission fluid, always change oil at 5,000. Don’t think I’ve done a brake fluid change. Bought used at 30,000 about a decade ago from CarMax.
    ETC(SS) likes this.
  6. indel
    indel Member
    105
    35
    Northwest Indiana
    If you are going to spend $1000 on cleaning the EGR system, you might as well buy all new parts and install them yourself. The autoparts.toyota.com website often runs 25% sale and free shipping. They just finished one for BFCM but who knows they might run another one for xmas. Not all dealerships have good prices, but we can provide you with a couple of recommendations if you decide to go that route.
    priumium likes this.
  7. ETC(SS)
    7,157
    Sounds like you're doing good things.
    Let the community know what happens.
    I'll always have a soft spot in my heart for the G3, since it was my gateway into Priusdom.
    Best of luck!
  8. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    If results from the easy flow test ChapmanF recommends are good, I wouldn't bother with the cooler. The intake manifold EGR ports are much easier to clean out, and more likely to cause a problem, if they're unequally clogged. (The Mode 6 flow test won't catch a single clogged port, because it only checks overall flow restriction.)
    When my 2011 had about the same mileage yours does, the Mode 6 flow test came out in the high teens, so the cooler was not significantly clogged. I cleaned the intake manifold ports, one of which looked sorta half-blocked.
  9. ASRDogman
    ASRDogman Senior Member
    7,591
    3,916
    It would be WISE to clean the cooler. That is the weakest link in the system.
    Next would be the small holes in the intake manifold.
    If you clean the cooler BEFORE it clogs, it will be a LOT easier to clean.
    Think PREVENTIVE maintenance.... You do it BEFORE it fails, and possibly cause more issues,
    which could cost more money...
  10. Mendel Leisk
    41,451
    Cooler can be “flowing good”, but have enough carbon to reduce its cooling ability?
    155k miles is well into head gasket failure zone.
  11. ChapmanF
    18,195
    For a little perspective, 20 to 22 kPa will be the flow test result for a freshly-cleaned or newish cooler.
    Something like 0.99 kPa is when the car says it 'fails', and sets a P0401 code.
    There are a lot of numbers between 22 and 0.99.
    Even if you decide for yourself that Toyota set the car's threshold too low, and for your own comfort you'd rather say 15 kPa is 'fails', or 18 kPa is 'fails' ...
    ... you can still make good use of the car's self-test result in guiding the effective application of your labor.
  12. indel
    indel Member
    105
    35
    Northwest Indiana
    Is there a way to test this without Techstream?
  13. ChapmanF
    18,195
    Many scan tools and apps are able to retrieve "mode 6 test results", including that one. You can see several examples in the thread linked from #3 above.
    indel likes this.
  14. priumium
    priumium Member
    197
    49
    Sweden
    But the cooling feature is secondary to the general flow/throughput of exhaust gas recirculation all the way to the manifold.
    The sensor reading of data that @ChapmanF states is not placed in the cooler, but after/in the valve, as I recall? So any buildup in the manifold or pipe would never be noted by analysis of this value alone?
  15. ChapmanF
    18,195
    There is one single Manifold Absolute Pressure sensor, located in the intake manifold near the throttle body.
    The car's self-test works by picking some time that you are decelerating and the engine happens to be spinning, with the fuel cut, so it is pumping a certain level of vacuum in the manifold, read on the MAP sensor. Then the car opens the EGR valve by some amount, which reduces the manifold vacuum (increases the absolute pressure), and the amount of the change is the test result. So if the MAP was, say, 6 kPa (a good bit of vacuum) and then went to 28 kPa with the EGR valve opened, that would be a test result of 22 kPa, indicating very good flow.
    That does end up checking the whole flow path from the exhaust to the intake ports. Its one limitation is it can't tell you if some of the four individual-port EGR passages are more clogged than others, because there's only one sensor and it could see a satisfactory pressure change even with some of those passages flowing more and others less. But that definitely isn't great for the engine: the cylinders flowing more may see misfiring, and the ones flowing less may see detonation, which is associated in peer-reviewed literature with head-gasket damage.
    Fortunately, to check and clean the four passages in the intake manifold is not a big job.
