Cat serial numbers
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Dec 7, 2025.
  1. ronlewis
    ronlewis Active Member
    986
    196
    texas
    2001 Prius
    Does anyone know the serial numbers on the cats for these cars? Not a biggie, just don't want to crawl under it. Apparently the market price at the recyclers is peaking right now so I want to get a price quote, but I need those serial numbers, one for each cat. IIRC, one is EA9?
  2. vaughnstark777
    185
    33
    Roy, WA
    2001 Prius
    I
  3. ronlewis
    986
    196
    texas
    2001 Prius
    we may have a miscommunication.
  4. vaughnstark777
    185
    33
    Roy, WA
    2001 Prius
    I
    I see you are wanting to sell it for recycle. If it is good it may be worth mor to sell it as a working unit. People steal them frequently
  5. ronlewis
    986
    196
    texas
    2001 Prius
    I have been trying to sell them to owners for years. It's a tough market. But I also hang on to them waiting for the precious metals market to go up. They have a book value to me of about $700. Based on the offers I'm getting on my ads from the recyclers, I'm thinking they're worth close to $900 now.
  6. Jakob
    Jakob Junior Member
    65
    17
    Wisconsin
    2003 Prius
    Looking at records from when I scrapped one I'm seeing GD5 and EA6.
    ronlewis likes this.
  7. priumium
    priumium Member
    205
    51
    Sweden
    This is indeed true. No one buys old, used catalytic converters, even when OE, and especially not when already stolen once.
    The true value of the three rare earth metals inside are only appreciated by special vendors that know/follow the value changes of those metals. They have risen astronomically last five years.
    The older versions on gen2 04-06 have a higher value due to almost excessive amounts of those precious elements.
    I do wonder if serial number is the correct term though, that term should indicate uniqueness. Likely more like version/model identifier, you just will have to crawl and likely use some Rockwell/scotcbrite to rub it to visibility. ;)
  8. ronlewis
    986
    196
    texas
    2001 Prius
    No one would buy them stolen for re-use because the thieves cut the cat off behind the exhaust manifold flange and again in front of the resonator. That front cut would be hard to weld back. But yeah, no one buys them much at all - I've only sold 3 in 4 years. I talk anyone in a non-CARB state out of buying, and I tell the CARB state owners to have two exhausts - one CARB-compliant for when you have inspections, and a second, non-CARB for your daily driver.
  9. priumium
    priumium Member
    205
    51
    Sweden
    That’s not very hard to weld though (exhaust being the number one welding target generally), but I would agree.
    However, when I sold my OE 2005 cat the purchaser wished for this cut off, since they naturally don’t care about the initial purpose, they pillage the rare earth only…
