Bodywork
Discussion in 'Fred's House of Pancakes' started by futurist, Nov 13, 2025.
  1. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Tue 16 Dec (cont.):
    On to the park. Just the cooldown 5th lap (which were done really leisurely, as was 1) kinda tuckered out genuinely :rolleyes:, and 2) trying to figure out how to access stored laps on my Casio watch... which can store 60 laps but no idea what key combos scroll thru recorded ones :( )... was divine, as proved in a gentle way, I were literally pushing the knee to its sane & constructive boundary. Haven't done much exerting since my running days ended due to this same knee issue (in both knees at the time) in 2023... so not surprised rocking up to the park trail, was gonna be more sightseeing than exercise...
    Huh -- so since most of the SE entrance trail is 100m of downhill... felt the knee protest from the usual cooling down in the car... but that faded after the level lap of the football field... and felt just as good if not better, climbing the steep 1st big hill, and down the long drop other side, to the stream bed and lowest elevation of the lot. That downhill portion's been near-constant airteeth for weeks, readers -- had never felt the knee sturdy / solid enough, to handle this part of the trail gracefully, not for months anyway. Sure at the end transitioning back to climbing was a bit gimpy... but once climbing, went back to feeling good. Again, huh :love:
    Even the final climb up the 20% hill... felt more strain than the climb out the streambed... but nothing like trotting atop the structure. This was very, very good...
    So wow -- guess I need to get 6 hrs sleep and eat just what I'd been eating last night... to get this knee into the fast swimlane (y)
    #41 futurist, Dec 16, 2025
  2. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wed 17 Dec:
    Change of plan: had to see the PCP for a 6 mo checkup, and since this is December on Maui, the next window to get one would be March Right in the middle of my usual workout (walk-out...?) so kiboshed the structure and the park lap, jings :cry:
    I like my doc; has done more for me a la getting tests, appts, imaging, and general GP stuff, than all of the so-called PCPs I've had in 3 states over the past 20y. Mind you, liked my previous PCP... but whilst a geek about medicine and kind to people (the only acceptable kind of PCP)... he wasn't all that proactive... so liked him as best of a cadre of bad, I guess. This current one's on the ball, funny in the correct way, and gleefully proactive. Now the bottleneck in my healthcare exp (other than her scant availability... which isn't surprising given how she 'medicines') is insurance -- which for the first time since coming back to HI mid-'90s (initial return)... has actually been utilised like a normal human being in a non-Red state... well, one that's not CA :p
    Fair to middling review of my serum draws... staying mostly stable, but a jump in a reading I'm vulnerable on, and one that's explained by a flu shot day-of (wanted to 2-birds-1-stone; ended up mucking up the draw results if I didn't know what caused it). Also been eating a lot more chicken breast, which explained other out-of-pale readings. So not great, not horrible. Watch your Vit D... :oops:
    (cont. next post)
  3. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wed 17 Dec (cont.):
    Ended up getting an xray of my knee -- finally. This is prelim for the actual consult with the ortho doc next yr... but since this morning was shot already, why not get it done (3 blocks up the hill, why not). So met with a cheery Local girl radiologist who answered some questions about the reasons for this first before the expensive pics... and also some side ones about how much actual rads she's expected to be exposed to with this old equipment, and what element provides the xrays (~30 - 35mSv, well below the 50 allowed; and a tungsten-rhenium alloy).
    Had no idea an alloy was used for creating xray imaging -- and just learned about rhenium in a YT video last night -- pretty rare element. Also, didn't know that lead, when exposed to high-energy electrons (beta radiation) such as in a particle accelerator... will actually emit xrays (high-energy photons). So lead isn't a de facto shield for all ionising radiation -- or in the case the video I watched had, needs two separate layers of lead, to fully protect your DNA from cancer risk.
    (cont. next post)
  4. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wed 17 Dec (cont.):
    Oh - forgot to mention... had made a mistake setting the appt time, so showed up as noted on my calendar... 1.5 hrs early (normally set my notification for an hour prior... but must've really fat-fingered this one. Auto-setting-calendar-date text app? You're fired). So with this lead time, figured why not take a lap around the neighborhood around the clinic, just to get my knee some steps...
    As mentioned in other bodywork posts before... you must make your injured joint reasonably do the thing you want it to do, by doing them... often past your comfort zone. But also as hammered home several times in this novel of a thread... you can't gung-ho do this, or the recovery from impatience can be longer than holding back a bit. Had that in mind, walking this neighborhood, which is in Wailuku.
    Wailuku, is on a pretty steep hill. Its name in Hawaiian means 'crazy water' or 'crazy stream', and this is probably because the Iao Stream, which emits from the massive and picturesque Iao Valley... often floods -- catastrophically (a team of National Geographic surveyors once hiked into the Valley, and were never seen alive again after a massive storm trapped them). More grade = more speed = more mayhem. Not unreasonable, given that we live on volcanic shield volcanoes -- you gonna get used to land that isn't plumb.* Wailuku is a milder version of some pretty kooky hills here on Maui, and around the State...
    That said... the knee was not happy being off the comparatively-controlled environment of the park trail, where there are lots of places to rest. I'm in here in a 1940 - 1950s era housing development that cannot be expanded for the sake of sidewalks or pedestrian accommodation of any sort... because in 1940, you had to really be someone, to own a car -- so all streets were basically sized for Local walking traffic. But now that you need cars to get anything done on Maui, and cars are crossovers 1K lbs and a foot longer and wider than cars even 30y ago... walking in this neighborhood around rush hour, means you cover your own unprotected arse. And the knee didn't like that.
    After ducking back to the clinic after a lap to get a drink in the car, headed out again (45 mins left)... and got a call from the clinic. We can see you now :rolleyes: I'm literally at the furthest point of the lap before heading back :cry: Because of course...
    (cont. next post)
    #44 futurist, Dec 17, 2025
  5. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wed 17 Dec (cont.):
    So hobbling uphill now, back to the clinic... got in and were seen for the usual numbers... then dovetail into the above doc visit :p
    Afterward... my rule is no workout, no eat. So drove back across town to my healthfood store for brekkies, and drove back to the park. Figured more than equalled the structure laps with those two laps of upper Wailuku... so just did the park.
    Hmm. Yeah that ~30 mins walking on hard ground, the knee needed it... but wasn't going to say 'thank you sir may I have another' at the park :confused: That said... despite the pounding it took atop the structure yesterday... the knee felt at the bottom of the big drop to the stream, quite unbothered, if feeling a bit stiffer (which may be muscular vs. ligament or meniscus-related -- walked some pretty good grades in Wailuku). Walking up and out was harder, but not because the joint were crying out, but from muscular strain... so far so good.
    Was looking forward to exposing the knee to more varied walking... and today proved I underestimated how entrained it would get, to just a few weeks doing clinically-similar exercises (mostly, to make progress meaningful by zeroing out the very variables it needs to develop). So think I'm out of the testing phase now, and just need to keep eye on ball whilst doing the plethora of 'normal' stuff with this knee... whilst remaining consistent with exercise every day... thru pain, if necessary :coffee:
  6. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Thu 18 Dec:
    Got up after another night of weird sleep -- there are SSE--erly winds we call Konas, that bring tonnes of moisture from Equatorial latitudes, not to mention Kilauea is also SE of us... so vog + humidity in the 90%+. Drenched in sweat normally (even sleeping atop the duvet) but wasn't as bad, maybe due to the fan being left at that same setting what annoyed the knee a week or so ago...
    Anyhow... got on road, hope not drenched and gritty still. Got lucky, as most of it dried by the time I rocked up to the structure.
    Today were a dial-back day, as hit the knee pretty hard w/ those trotting bits and felt they needed time to recupe. Getting out of the car, the same stiffness-becoming-pain getting out of car inner thigh... so did my warmup in the mall and walked my ramps to the top.
    Two and a half minutes w/ the trotting / shuffling, obvi wasn't a wise goal today, I thought... so set the watch and timed 1st lap, taking it easy but still walking with purpose.
    Stiff Konas today -- probably gusting to 30 wow... enough to shove me off-gait. Focused on relaxing and keeping knee and ankle aligned to a "T" imagined on the ground in front of me: a line betw. knuckles / ball of big and little toes aligned to the crossbar, and insides edges of feet, to the vertical. Some urchin's effing dog laid an egg in the corner, nice :mad: So-called adults coming up these days, zero class and can't be bothered. It's the top of a parking structure, loser -- doesn't go away because you ignore it :cautious:
    And you wonder why I don't always speak in flowery tones about living on my home island again. Old days, long gone :rolleyes:
    (continued next post)
  7. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Thu 18 Dec (cont.):
    Since the structure itself is built on a slight incline (or has settled that way since early '90s)... my CW lap begins with the long side slightly uphill, and the far side is, of course, downhill. I choose to try trotting on the downhill, since it would load the knee more if done gently but firmly thru a bit of pain. And today was no different... except...
    Trying to trot those 15 steps from yesterday... rather than doing a full-gait jog (at least what the pain would allow) 10-rest-5... decided to shuffle a bit more (shorter steps, less vertical impact) and run the whole far side that way.
    Well-well... whilst it didn't feel good and nothing close to normal... I could do it. In fact, did it the other 3 laps, and even extended the run to cover the final bit of the short side to the start / finish (basically a straight line to where I climb up the ramps -- also exit and descend to my car on the same side). Didn't have to kibosh due to intractable pain... tho got close on lap 1. After that, felt like work but not painful enough to stop running the whole long side downhill.
    Walk down the ramps was comfy too... wow :unsure:
    When driving to the park... no matter if the time in the driver's seat were just 5 mins / 300 secs... would ache getting out, and from the SE start point, a hobble down the 20% hill to the trail. No such flailing today -- the first time since using this entrance, it's not raised your scribe's age to fogey-cripple-old :eek:
    The rest of the trail were same. Still sore, still can't take my full weight multiplied by the height of a stair riser w/o airteeth-y pain... but hiking was fine now. Which means it's finally ready to someday do vertical laps again... which hopefully would be the last step in getting this knee back to normal (I'd even take 98%). Hopefully. No idea if this is just some other phase in the knee's roller-coaster recovery journey, or if this is really reaching cruising altitude :cautious:
    #47 futurist, Dec 18, 2025
  8. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Thu 18 Dec (addendum):
    Noticed today... for the first time since the incident, the knee isn't swollen.
    Thinking back to today's structure lap as well... remember that 'cool' feeling of something happening in the knee under load? Didn't feel anything like that either -- which used to be daily, familiar even. Funny how your mind snaps back into what you used to consider 'normal' when you're getting over something... like being so sick you think you forgot what being healthy feels like... but once you are, you jump up and have an appetite and do things you found impossible at your worst. Something like that, my mind jettisoning the need for awareness in the knee... because it wasn't being called to exist.
    Hidden by that swelling, which'd been companion since Sep... are veins and musculature developed getting this leg into shape, now visible. That guitar-string tension of the muscles of inner thigh, namely the semitendinosus, semimembranosus, gracilis, adductor magnus, and sartorius, are sooo much more relaxed at rest -- which confirms my suspicion:
    When the leg was injured, atrophied muscles across the knee (only used to 2y of 15 - 20 mins of level walking per day rather than 2 mi of running per day) were insufficient to splint the knee immobile in an emergency. When the incident happened, all available muscle fibres were forced to go at or near-100% contracted -- which were guaranteed to create TrPs. Thus my slow progress 2 mos, just trying to do enough with the knee, to build muscle to stop this reaction. So a catch-22: the reason the joint ached was because the muscles were forced to full tension and not letting the joint function... but in order to fix this, you must move the knee in exercise -- meaning the only way forward, is thru pain.
    Have counseled dozens of clients on the table, seeing this condition in their lower body... but it's highly useful to both of us, when I can feel -- and rehab back to health thru my own efforts -- the same condition in my own leg. Can luckily still grow muscle, which is not always the case, esp > 60yo. For those people, my work is only palliative. But the process isn't easy, either -- and for the median cool-in-HS people out there... certainly not going to follow my path to the letter, too much work. :rolleyes:
    If you want an excellent source material to rehab yourself out of injuries you thought condemned you to the cripple house for life... check out 'Pain Free', by Pete Egoscue. Vietnam operator, horribly injured -- VA and civvie medical authorities had no way to help him walk again, so developed his own methods. If you're determined to get back on the horse and no pain's gonna stop you... read that book. Also recommended: 'The Egoscue Method of Health Through Motion', which describes the exercises and methodology.
    The xray from yesterday was seen and results published -- apparently have no derangement visible using xrays only. Which means MRI should be next. Can't wait (y)
  9. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Fri 19 Dec:
    Well will you look at that -- it's still not swollen :cry::love:
    A bit tight tho -- and since we're expecting drizzle coming thru today (actually turned to propa rain, if light)... bedroom fan were left on that higher setting, just enough to not float atop the sweat :sick: But that's gonna make even a healthy knee tight.
    Usual warmup in the mall and up the structure -- time for my laps on top... which led to some interesting results...
    Lap times stayed in the 2:32 - 2:35 range -- not bad, and pretty consistent. But what stood out, was left calf were crying out, not right. Imagine that -- the right knee was ready enough to take weight / load, that it was tiring out the left leg. And it did, w/ less pain than yesterday.
    All four timed laps were done full shuffle, turning into a proper jog by lap 4. And got to shuffle / jog more than just that downhill long side, laps 3 and 4. What is going on...? Daily improvement seems far too quick for progress like this... so may need to dial it back, methinks.
    Am getting a propa sweat on now, too -- because I'm doing more, and going faster :confused: That were encouraging... but gotta be careful not to make the sophomore mistake of gung-ho / square-one. Knee feels fine 4 hrs later, tho...
    Park lap were more of same. The only old familiar tweak, was descending >15%, couple of 'whoa' moments. But once down that first set of steep downhills, the big long one to the streambed, felt... dare I say it, normal. Yes there's much less strength from 2 mos atrophied and beating on it to build... but this workout & chicken-filled diet, seems to've finally provoked actual muscle growth.
    Climb up, same -- feels much less like painfully keeping mind on the positives whilst putting in the work... and more like just Ordinary Knee doing ordinary work. Even the 20%+ small hill at the very end, no pain at all (L leg by now were rested enough not to assert its weakness into the walk).
    Had to do shopping plus find a place to eat breakfast (remember, no workout, no eat)... so would see how the leg would react to sitting that otherwise would doom it to Cripple Creek. And for the most part, it didn't. What seemed to tick it off the most, was sitting in the Prius, eating my (cold) meal. May need to adjust the seat bottom again...? Who knows, done everything else, so only thing left, is not enough tuchas...
    And 4 hrs later, no swelling. Am I out of the recupe penatly box? No, probably not wise to hammer on the knee w/ vertical laps just yet. But will keep pressing gently at the limits :coffee:
    #49 futurist, Dec 19, 2025
  10. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Sat 20 Dec:
    Oogh -- a bit stiff this AM out of bed. Same low medial spot's tight. Massaged and lengthened usual suspect hams and adductors, and aligned. Aha -- suspicion from yesterday, confirmed: it did get worked. But ? now is, by how much?
    Exp to now says... I can exercise in relative comfort... but will stagnate progress. You can gung-ho all you want, but'll end up inevitably at square one if lucky -- but more often further back than you started.
    Pulled up to the structure, all the warmup things. Starting the laps on top... noticed something odd.
    I'd lost the strength I'd had yesterday. Sure it was worked well and I got a propa workout sweat on... but my muscle tone were fine save the muscles crossing the bad knee and those of my left lower leg (mentioned past post). So the usual 'relax into exertion, wasn't working at all... if anything, it caused my legs to get tired more quickly. Wut...?
    So on lap 2... remembered back to what I'd eaten. There were such a stark change, figured must've been a gut thing (applies in a lot of other situs, too). More apples -- ate 3 yesterday. Nah, no way whole fruit that's not citrus could cause these symptoms. Then it hit me...
    I'd eaten a couple of handfuls of pistachios (to empty the bag and throw it away) vs. the usual one handful -- which is already roughly dbl the RDA for potassium.
    Potassium in the body has a relaxing, balancing effect on muscle tissue... which is why people say eat bananas if you cramp. Trouble w/ bananas is, the sugar -- sugar eaten w/ K (pot ash, not Vit K) inhibits its absorption. Which could be why in nature, the large amt of K in bananas has that buffer to prevent a particular condition, called hyperkalemia.
    Moderate to severe hyperkalemia can f*** w/ your heart... so it's usually something genetic or kidney-disease-related (kidneys filter excess from your blood). But up to that point, can cause nausea, stomach issues... and fatigue / weakness in the skeletal and smooth muscle, as well as cardiac muscle.
    I felt fine and had no problems w/ gut or walking around warming up... but once muscles were called on to perform... that's when mild symptoms of HK surfaced. And sure enough, on that 4th and last try-hard lap... just couldn't match the energy from yesterday, even taking recovery from overworked and possibly sore muscles into account.
    Confirmed it, with a stronger than normal urge to evacuate -- kidneys sensing excess K, would attempt to dissolve it in water then wee it out. And after the structure workout driving to the park... felt no cramps despite overworking my L calf enough to really slow down my times (could not descend below 2:28 today, even thru pain).
    At the park after a wee... yep, more strength, not less. Yes more tired since body had to work harder to get muscles doing the same thing as Fri... but climbing hills esp felt exactly the same, not more effort. And man was I thirsty (just like diabetics get, when their kidneys require water to dissolve high blood sugar into).
    Knee felt fine on park trail. Difficult to gauge actual progress after that diet flub... but Jesus -- just 16 - 20 pistachios give me symptoms of mild hyperkalemia...? (can't say it would for everyone, but only one I'm concerned with / have control over on this recovery journey, is moi :p ). I'd eaten quarts of almonds whilst apprenticing, w/ no ill effect (was my fave snack at the time). Not as much K as pistachios... but would've suffered effects of HK thru sheer intake I'd think (not to mention the oxalates, which cause stones to form). Actually pivoted to pistachios for nuts... due to rich in K + low oxalates... huh.
    Welp... better take that to heart -- literally :love::coffee:
  11. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Sunday Wash Day, 21 Dec:
    Jings, were really looking forward to my workout today. But no one to wash the Prius but yr fthfl svnt... so off I go.
    *sigh* Had to pass the structure, as post-wash my place to dry and wax the vehicle, is less than a block away. Got the car dried and cleaned, ready for wax.
    Slightly dreading this part, as back cried out in yodels last weekend. Since the gimp knee can't squat without searing pain and possible backsliding hard-won progress... have to do the doors and end caps bending at the waist -- which up to now, had been so painful and exhausting I'd skipped the usual work afterwards (interior) last week.
    So same rules: no work, no eat. Got the horizontal surfaces done, now for the dreaded doors / endcaps... Drove to the 2nd spot and gave it go...
    Huh -- yes were still sore and not-normal-feeling... but not exhausting either. Wut...?
    Suppose the only explanation is this past week. As you've read, a lot's happened in a week. Was a month doing this ramp climb / laps on top... resulting in actual growth only last week? Maybe... all the exps seem to agree. Which doesn't make sense tbh, because historically I need to do something 6 wks (1.5 mos) in order for body to say 'ah, Few-Chew seems serious about progress... all right we'd better give him some' :p Is it because I'm recovering from an injury, vs. getting into shape but otherwise healthy? Remember I'd wasted 2 mos w/ vertical laps, only for the problem to get worse. Maybe it's me lucking into the precise effort level in the revised workout, the knee actually needed? D u n n o . . . never effed up my knee before.
    But all the regular trail hiking (if you want to call less than a mile in both locations, 'hikes' :rolleyes: must've made more than my legs grow, which they emphatically and delightfully have. My back was yes a bit sore today... but nothing like last weekend. And would say got the car done today -- interior included -- in less time than when I were healthy... whu-hut? :confused:
    Some of that's just learning the tools and chemicals via trial / error (Griot's Garage 3-in-1 Ceramic Wax, is officially banned for use on vertical surfaces; only places on the car it doesn't make a whitish powder which must be buffed off by hand, are roof and hood -- no clue why. Hybrid Solutions Ceramic Spray Coating only, from now on). But the only way my back wouldn't hurt doing more work, more quickly, is if the muscles were stronger (and not weakened by eating too many pistachios :censored: ).
    Knee were still not liking the car detail vs. workout routine... but walking to the bathroom in the bldg I drive to for waxing the doors (separate places for horizontal vs. vertical surfaces, due to rent-a-cops on their little golf carts at the mall -- incl'g the one I told off last week re: the dog crap on the top level), found it far more 'usable', if still trick-y and weak in certain circumstances. A universe away from hobbling like I needed crutches...
    Well -- tmw is another week. And another past week of lessons to behoove, hopefully towards more progress :coffee:
  12. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Addendum, Sun 21 Dec:
    One of the challenges of having an internally-damaged knee that only seems to like the seated position driving (not at home in my office chair or on the sofa or loo or anywhere else), is 1) getting up from that position to walk, and 2) standing >5 mins. This is one of the aggravating things about the knee that hasn't reduced much thru exercise, as the other problems.
    Recently was so done with the pain in the shower (no handrails possible in a fiberglass shower, so make do leaning on the wall to rest), got a better showerhead (handheld) just to reduce time standing. Pretty aggravating 5 - 7/10 pain that increases ~a number every 30 secs - minute, depending on how the day went. Since were wash day and did hours of standing and bending at the waist... knee's done.
    Might've found a solution, tho... which actually'd been done before, but reverted back to standing as it were faster: getting a plastic seat in the shower.
    Tried this tonight... and ahhhh, no wincing / airteeth... just got a comfy, swear-free wash on. Yes it's slower and yes I still have to struggle off the floor... but when I'd stopped using it in summer, hadn't effed my knee yet. Funny how things work, the coincidences :coffee:
  13. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Mon 22 Dec:
    Load of clients for a Mon -- here for it as Dec's been weak. But workout first food second...
    Were a bit concerned about today's warm and hike, since the knee felt that notch better, at least walking. Standing as last post is still dodgy, glad to get it moving (and I weren't in mil with this goofy-arse injury).
    Woke today w/ some soreness and stiffness, but middling. Flights of stairs out of my walkup, stiff but strong, nothing's gotten any worse. Drive into town and getting out, not bad either.
    On the indoor lap in the mall, discovered my Japanese translation app will tranlaste one word, then go blank on any other input... so stopped the lap to to some sleuthing, maybe 10 mins. Then proceeded to the ramps and up top.
    Times weren't great. 2:34, like clockwork all 4 laps, so the knee's backslid a bit. Understandable after the car wash and all that standing and bending, so will give Mondays a pass for now. It was however, quicker to transition (from shuffling to running) and more comfy for longer, even if not quicker lap-times-wise. Rest lap was a bit anticlimatic; not the feeling of accomplishment as usual, but that's the price for progress: every up comes with a down... and w/ knee injury I'm learning, get used to more downs than ups.
    Haven't aligned the knee in a while -- so something's healed enough in there, to prevent going out. But walking that last structure lap, something occurred to me that may explain the quick-ascent-brief-cruise-descent arcs...
    When scar tissue forms, it's non-discerning -- meaning any severe enough inflammation (acute or chronic), brought on by damage or immune response... creates conditions for adhesive fibres to skip the phase where they're able to be worked thru the skin w/ bodywork into freedom; they go straight to scar tissue. ST's the worst healing response tissue to lay down outside the area of damage. My near amputation of my nearly half my hand mid-Y2Ks, resulted in scar tissue formation past my elbow -- which is typical; anyone who's broken their lower arm / wrist / hand / fingers will be familiar with this phenom.
    ST, sinks little molecular 'hooks' into the surface of everything around it, where this inflammation is. And doesn't just happen w/ physical insult... things like snakebites and wasp stings which inflame tissue can elicit the same response. But for this discussion, we're going to focus on what happens when scar tissue (and the mouldable adhesion to a smaller extent) sticks things together.
    Let's take my knee. Something happened which damaged thru exceeding elastic limit, ligaments in there. I can wag my R heel L and R, and feel the menisci moving. Doesn't happen near as much on the good knee. But things in the body don't have to snap in two, for scar tissue to form (in fact, that almost guarantees it won't happen). It can be stretched too far too, which only partially rends the tissue, whether ligament or tendon or muscle / fascia.
    When ST formation takes hold... it sticks everything, lah-dee-dah-dee, together. In the beginning, normal movement (as prior to injury) will serve to break weak adhesion, and only leave that which needs to exist. Ancient peoples had to exert thru pain and incomplete healing, because they had no choice living at the mercy of nature... only their wits and resources around them to survive, esp w/ children depending on you. So it's not a stretch (see what I did there) to think, if our genes adapted to accept and improve upon this unavoidable part of life... then your body inherited from these rougher times... would require some level of it, to thrive.
    This is why I workout thru pain. Not idiotically; when it hurts close to the point of functional failure, I stop. This knee require a couple of steps back from the harshest treatment I'd decided on (vertical stairwell laps), and the knee's responding with gratitude and healing.
    This confrontation with pain, is unavoidable, esp in the more technical injuries... meaning a lot of that pain is not the body telling you something vital's still damaged, back off... but just reporting the spinal cord's receiving a lot of input from nerve endings reporting pain. And this extra noise, is what the working out should be clearing.
    When these ST hooks attach to the surface of a nerve... it irritates it into stimulation. If a motor nerve, then coordination and strength can be disrupted. If a sensory or combo nerve, then the report is pain, up to and past the point where you can compensate for it. It can literally turn off opposing muscle contraction for the area adhered... which results in 'trick' knees and other joints.
    ST is worst at this condition, but the softer stuff can pull on nerves too, just eliciting a less-severe response. This is the 'tenderness', if inflammation's no present. When my knee stopped swelling beginning of last week (just after that bad knee day), the progress shot skyward. This is why bodywork in contraindicated when it's present (red, hot, and painful -- loss of function may be added to this rule of thumb too). My knee is faaar better than it was 01 Nov... but that soft adhesive tissue's still pulling on knee parts... which doesn't as much inhibit function, as take my awareness constantly away from what I'm doing, to pay attention. This also has a profound effect on what you can do, or even perceive your body can do.
    So still work to do -- whilst the long weeks in pain doing this workout's borne fruit... other totally normal actions with the knee, are still intensely painful and trick-inducing -- like exerting with the knee taking torque in either direction. Further exercise -- once I can jog and climb stairs comfortably -- will focus on these 'side' abilities... no way to get them back, but thru a little aggravating, frustrating, humbling pain :coffee:
  14. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Tue 23 Dec:
    Xmas Eve-Eve, as my little grand-nieces would say.
    Here it's more a rush on the big boxes for last-min shopping more than religious orthodox on mainland, for sure.
    If you're easily offended, scroll past to the next set of dashes...
    When your history from 1915's has been mostly Great-White-Society-peddling, and this cultural appropriation on mainland (even 3 gens later) is what many ignorants still consider Xmas in HI to be -- hula dancers w/ coconut bras and tiki bars strewn with tinsel, garlands of coloured lights.
    Tangent on the hula aspect of this whitewashing... what most see at hotel performances, are Tahitian-inspired grass skirts btw, save the coconuts -- actual female Tahitian dancers went minimal or nude waist-up, until colonisers demanded they be clothed. The nut bra came from further, unchecked Hollywood-isation marketing all things Hawaiian (and Polynesian, tbh), not restricted to just the Holidays.
    Ancient-traditional Hawaiian dancers wear pa'u skirts and coverings, made of ti leafs and bark fibre strips, not grass fronds. Colour were also green, as the ti leaf symbolised purity and godliness to the ancient Hawaiians, so dead leaves were not allowed on dancers, m or f. But today, as the culture of the hula evolved thru near-loss into the 1960s... the Merrie Monarch Festival's founding in '64, marked a turn in the resurgence of true Hawaiian lineage and connection to the traditions of the ancients, unmarked by profiteer colonisers with guns. But also incorporating ideas like cloth coverings and other things not done prior to Western arrival, as integral and owning the evolution of the hula, in and thru the age of colonisation. The dancers who compete at Merrie Monarch, don all of these styles -- owning the history of their artform, complete as it is.
    Back to the workout: expected a bit more soreness vs. Mon with a relative rest period washing car... and got it. But figured out a way to get me thru the week possibly, with only growth and minimal backsliding over that edge...
    All else remains the same but the rooftop laps: found today climbing stairs were less 'tweak-y' / trick, than yesterday, wonderful.
    During the laps, moved to shuffling again first 2 laps of 4, just faster. Jogging involves more impact of the forefoot on the floor during gait, and the knee doesn't like that yet; to boot the L lower leg doesn't like it either, as I'm apparently pushing its parts towards more than daily walking were keeping unadhered. Have already done what I can thru the skin; the rest has to be done thru exercise (wisely pushing until only enough breaks away, w/o reinjuring the internal knee). Didn't want to actually push the knee, until these first 2 laps warmed and broke the weak adhesions.
    Final 2 'push' laps: stretched gait length first, then last lap lifted chin, eyes on horizon... and began to jog. You can't properly jog w/o proper posture... or all the weeks working out in bad posture will need to be corrected once the knee heals up and regains normal potential -- undesirable when at that point, I just want to kick out further. Smart work > more work (unless you're slow about learning the hard way) :LOL:
    Felt... okay. Park lap were good -- just a bit down on power, I felt. Not so much the workout, but in what condition I started it in. But did notice my time for lapping the park had gone down. So even feeling a bit rough... still were walking more efficiently? I'll take it :p
    Tomorrow, will modify the workout, by doing intervals: Mon push, Tue half-push, Wed push, and so on. Need to be able to do enough to keep adhesion at bay, without stunting this great trend of muscle growth. Seems like the current 6-day schedule isn't allowing enough rest, so will provide a bit more. Not as off-base as the vertical laps were at that point in recovery; learning from mistakes :rolleyes:
    Whoof -- all this spending on decent, clean food really empties a bloke's wallet on Maui. Won't get another food assistance pymt until the 3rd, so making do paying out-of-pocket... which means less food overall, sadly. But the body seems to like this chicken breast regimen -- just wondering abt the rundown feeling of late.
    Muscle on both legs is significantly, visibly greater -- confirmed by the sharp increase in total weight (just under 195 lbs now; when running 13 min 2-milers in health, was 180 lbs, 5y ago. Started this journey @188 lbs...
    I keep telling clients, don't push too hard in the gym, esp when you know it doesn't return results -- all you're doing is reinjuring muscle and fascia that refuses to strengthen and grow, until your body's particular schedule for rest, is conformed to... got this from trial and plenty of error, years running in covid. Everyone's different -- some genetics will like & even demand more push more often, but most will fail and stay sore / weak, until you give it what it needs. This applies esp if you start already battling atrophy, past age 40 (M) or 50 (F)...
    Muscle is denser and heavier than fat, so no too concerned re: not losing fat simultaneously, as the focus should be on rehabbing the knee, and what it needs (less than a proper running workout would demand). But as long as no gain in abdominal fat weight, should be all green for the knee. Muscle doesn't grow, until you give it what it needs (y)
  15. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Addendum 23 Dec:
    This one's for client work...
    Very good, gold-star client referred by another goldie. Overtrains sometimes, as trying to change disciplines from muscle building gym work, to the stamina-muscle-dominant world of long-distance running. The great majority of his sessions involve untying knots of warring tensions between opposing muscle groups.
    This time, were just my cup of tea: the fringe cases of athletes.
    When you condition yourself with gym work since teens into 30s... your nervous system and tissues conform to this long-term input, and integrate it into your very cells, as formative experiences. The body now optimises the body further and further to do just this task, and creates structures physically as well as schema in the brain and spinal cord to deal with it. It's why you can ride a bicycle in your 50s even after not riding one since childhood. But that example only extends to entrainment -- the body itself can also change physically to do one task and it only, if severe enough specialisation if done over decades.
    Client were one of these cases. He'd been warned by those where he wants to be, that the process of reshaping the body from a muscle-bound one to a marathoner, would need a lot of de-training and re-training, over lots of time. But old habits die hard... and one can only nudge away from them in small increments, held fast and stopped only when the desired goal is achieved.
    Intense pain bending big toes upward, esp on L foot, which I'd worked last week but ran out of time to balance with R leg. So this session was to address the leftovers.
    Found the usual suspects misbehaving... but not to the extent the amt of pain would suggest. Had to be something else, hidden deeper. Were pretty thorough on the L leg to the hip last week, so no dice there... but the R one were beginning to exhibit the same traits -- makes sense, it's the weak leg now. So R foot to start...
    Turns out two things stood out quite strongly: 1) the medial cuneiform bone, a tarsal or sort of wrist bone for the ankle, were sunk into the arch a few mil, and 2) the very strong quadratus plantae muscle, toe-ward in front of the heel, was rock-hard. Both suggest a tug-of-war between opponents moving bone and stunting foot performance.
    The cuneiform turned out to be a manifestation of adhesion of the tendon for the fibularis longus muscle, a peroneal or outer-side-of-shin muscle, used to control tilt of the foot to the outside (pronation) and inside (supination). Breaking that free and working the muscle belly, resulted in the bone moving back into place on its own. But inspection found the big toe still adamantly refusing to bend headward, even touching it caused jump sign or involuntary jerking of the limb away from my hands. So had to first remove any compression of the column of 1st toe bones, meaning extensors and flexors.
    That done... still 7/10 pain (jump sign is 7 or above, if it's found. Otherwise can assume ticklishness, which is partially mental and must be approached completely differently). So decided to work the toe itself.
    When someone can't bend or extend (dorsiflex) the big toe, a very common cause is twofold: either osteoarthritis, or gout. Confirmed my client did not have gout in his family medical history, and no other pain in larger joints like the knee, so safely ruled it out. But osteo's extremely common, esp in gym rats, even < 40yo. The trick to treating it, is to find it.
    When osteo's in its pre-pathology stage... it forms because a joint's articular surfaces have been touching and rubbing under load with no break, a long time. Said his problems with the big toe(s) began more than a year ago -- when he began this pivot to long-distance running. The way the body deals with this inability for the joint to relax and create space, is to begin depositing calcium carbonate -- literally crab shell. This will reinforce the joint and help carry, according to evolution, the heavy load it assumes is being applied to the joint in life. What the reaction doesn't take into account, is the touching's caused by opposing muscles compressing the toe phalanx bones. So if the muscle tension never stops at rest, it dooms this blunt countermeasure to causing intense and chronic pain, esp in the toes.
    I held the 1st metatarsal bone steady, whilst grabbing the 1st phalanx (proximal phalanx), and shearing the joint thru its range of motion as-is. Lots of cracking and crumbly sensations, resulting in greater range of motion. Compressed joint now, breaking up the pieces and allowing them to reabsorb. Had client stand and test...
    Could not believe what he were feeling: had not been able to move the toe on the table even, w/o a 'base' amt of pain. But upon standing, delighted to find he could walk on it comfortably now. That were the keystone, as problem were with the entire column of the big toe, or hallucis (cuneiform tarsal, 1st metatarsal, and phalanges). If that's effed, you're effed to your neck :p
    Not surprising the whole leg relaxed a couple of notches... and whatever were left would be the only remaining problems. Small TrPs and nerve adhesions they were, but the real work were done -- and took 2 hrs to find the cause of 12 mos of constant pain.
    Good session. Work is deader now due to the two weeks of indulgent spending people'll do day after tmw and the week after that... but if this is the session I'm to close 2025 with, it's a good one -- in the notebook it goes (y)
  16. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wed 24 Dec:
    First day on the new regimen (push, half-push, push, rinse-repeat), as today's the first half-push...
    Rather than all 4 exertion laps w/ shuffling-running + 1 cooldown lap, today were 2 exertion laps (no shuffling-running) + 2 exertion laps (w/ shuffling-running) + 1 cooldown.
    Have to say... it works. Today were a tangibly cooler day (about 3F cooler than normal for the rooftop laps) plus much windier... so expected slower lap times, esp for the all-walking initial laps. Reality: both walking laps read 2:54 & 2:50, and running laps 2:32 and 2:24 o_O (also, all running -- done on the northwest long side -- were done into the wind).
    Had a feeling I'd been a touch hard on the knee (and its long-suffering compensating L leg and hip), as Tue laps were overall slower and a touch more sore than Mon... and didn't improve much Wed or Thu, even when laps were more consistent. The clue were in reaction to relative rest from Wash Sunday... and this set of laps confirms it. A longer warmup time (virtually, as the walk 'round the mall and ramp descent/climb counts to the knee) means the first two rooftop laps w/o hard load, can get more lubrication and circulation where it needs to go, not to mention warmth into stiff, possibly scar-tissue-hampered ligaments and other internal knee anatomy... before I push it. And that last lap, pushed it harder than ever before -- because the knee could now take it.
    Were scar tissue set and dominant in the knee... both the colder, windier conditions would slow all laps. But all sped up, despite worse conditions? Complying (y)
    Another neat lesson from today... were at the park -- and blindsided me, tbh...
    Looks like the center start point for the mall, yesterday packed w/ soccer parents watching their 6 - 15yos hold training before a game... is no longer my start point, SE entrance über alles. Even w/ the 3-min drive to the spot, getting out felt a bit stiff -- 180º opposite to how it felt on the rooftop. Huh... well, let's see how it hikes.
    On that first dip down to the trail... did something done fairly frequently in this recovery journey: stepped with the bad knee downhill, then tried to hold my weight as gait moved me over the 90º-bent knee... and see how much further I could bend it, before needing L foot. Repeat 5 - 6x... & found knee quite weak past 80º, which isn't unusual given my attempts 2 mos ago (which were 100% more painful and weak-feeling).
    But a strange thing happened: as I leveled out at the bottom of the giant scooped-out bowl in sand hills of this park's twin soccer fields... the knee felt better. Not only less pain (which was already sub-showstopping, if still distracting) but more strength. Where did this strength come from? The vastus lateralis, or outside quad, which is the only one of the 4 w/ obvious injury visible thru the skin.
    Looking at both thighs from Sep to now... the L thigh is much more muscular, more like my running days. Hope so -- those vertical laps for 2 mos weren't easy. But R quads look stunted... bigger than Vertical Lap Independence Day... but obviously smaller and dissimilar shape vs. the L. Calves however are about par. Which points to that injury and healing, as potential to unlock more ability, methinks.
    Did the Big Up and Big Down to the streambed, then the Big Climb up higher than entering the park (after leaving the parking lot) and te Whoop Section. This is where a fork exists where I descend down to the soccer field fence, and where the quad 'step-eccentric' exercise 6x were done; did it again. Oddly, the knee didn't feel better, but was a bit more loose.
    So tricky navigation from here... have to stress and gently break the adhesions holding that outer quad back, whilst not changing things so fast the knee becomes unstable, for however long it takes for the body's homeostasis to catch up. It did fine for 2.5y doing everything normal I'd do (including squatting to wash the car)... so somewhere in the injury's a quad and connective tissue which can assume normal load w/o pain, or compromising function of other parts of the knee.
    But very nice confirmation of theories, and of course adoption (until they stop working, of course). Will see if the knee can be pushed as usual, tmw :coffee:
    #56 futurist, Dec 24, 2025
  17. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Thu Xmas Day:
    Well-well...
    First, Xmas greetings to all who haven't blocked me yet :p I am prolific, and this thread isn't about you, only for you if you choose. So read if ya like, eff off if you don't :love:
    Back to wells...
    Mentioned this were the 2nd push day in the new knee cycle... so wanted to proof the half-push as a way forward. Have to admit bit of nervousness, since were pretty sure about the vertical laps being a way forward too...
    Slept well last night, but overnight temps dropped below mid-60s F (that downdraft of freezing air 10K ft atop Haleakala, spills down onto us due to trades in winter)... so woke a bit chilled. But just thought how much more'd be, were I still stuck on Bainbridge Island (40s) or Phoenix (40s) or Arlington (20s) or Würzburg (20s) on Xmas Day, warms me right up ":coffee:" Did mean my knee were doth protesting a bit, getting my carcass out the casket...
    Rooftop: initially felt after the mall lap (did 2 half lap shortcuts inside to stretch the warming time, as were 70F in Kahului too + wind chill), so a bit stiff. Discovered a set of bathrooms I'd never noticed since the mall were built in the '90s, much less used... way closer than the one I'd been using since early days of the structure laps (both kinds). Well f*** me, will see what they're like inside tmw (probably just more abuse and typical defunct mall-on-life-support squalor, but with my own eyes is always best...
    So figured the ramps were gonna be crucial to getting decent lap times up top... so tried to do them as relaxed as possible, not stressing them too much. That'd come on top, not on the ramps, I figured.
    1st lap: found a bit of wobbliness first half of the long side downhill shuffle... but cleared into less pain reaching the corner back to the start/finish on the low short side. Felt good enough, shuffled all the way to the line... and got a 2:40. Not sizzling, not awful.
    2nd lap: minced my way back to the far corner, and gave it a bit more gas on the downhill: knee liked it. Hmm, could raise eyes to the opposite side of the rooftop now, always good since your brain goes where you look, and adjusts your posture to be more efficient (if you're not stuck together or in huge amts of compensation in the core / ribs -- plus on Tue, couldn't do this). Not bad -- running about a third faster but still shuffling, and could hold that around the corner. 2:33...
    3rd lap: knee felt like it were warmed into comfort now... but still not perfect, obvi. Pushed off for the downhill... and found could run. Not run a few steps then collapse back into the shuffle in pain... but more like actual, prior-to-injury running. Yes my L leg and hip were still heavily invested in the compensation of 3 mos of gimphood... but found all my weight were now transitioning off the L leg, and onto the R. So not foot to the wood... but were now gently running. Kept that pace around the corner to the line: 2:30 (y)
    Last lap: walking felt loose but could feel my L hips esp start to tire, poor thing... will give you some rubbing later. Stimmed the sensory nerves for the skin atop my arsecheek glutes, crossing over the bone... which loosens their tone. Gonna need it, methinks...
    Round the high far corner... and f*** me, I'm running. Not desperately like Tue... but knees are coming up, R foot is landing on forefoot w/o severe pain and pulling fine. And the speed -- about half my old running pace, womp-womp-whwaaah :p Eh, too effing early to dream that big :rolleyes:
    2:24. 4 secs faster than fastest to date... and less than half the pain. Can now mint the push / half-push / rinse-repeat regimen gavel knock (y)
    Trail time. Drove over, and did the same quad-hold-on-a-hill exercise 6x on the first genuine downhill (right out the car park). On the sam spot I'd done it again Tue... another 6x. Whoof, felt some drama in the knee now. Distributed away from the low-medial spot that's been with me the whole journey... but felt more right, somehow...
    Walked normally across the footbridge, past other Xmas daywalkers opposite way :p And got an inkling, gotta do more of that quad thing to the knee. Stopped next to the fence by the football field bottom of the bowl... and tested the L leg first for a control. Then L foot off the floor, held the fence whilst I tried a half-squat, full weight on the R knee.
    F*** me, that hurt. It is weaker than the L thigh by about 40%, and lacks enough strength to rise from the squat (meaning catching myself w/ the L leg) to strictly 80º. Tbf the L knee won't squat w/ full weight much further, but can get to 70º w/ no pain but the exertion, whatsoever. The interesting thing's twofold...
    One, where the pain of strain ended up, once standing and walking again: all in that low medial spot. But having rubbed on it 3 mos... know what the difference were betw. L & R spots. Now, it felt striated, striped and 'washboard'-like rather than a solid mass. This is due to how scar tissue formation evolved: there's the glue first then permanent, plastic-like scar tissue w/ normal healing... but severe injury skips more of the glue phase. But still needs this malleable glue to form a framework to reinforce, so that need laid down first, but only minimally -- there's vital shite to hold together from spilling into a predator's stomach :cautious:
    Problem -- or rather, fifty-thousand-thousand-millennia of trial-error genius -- of this process... is when activity returns to the joint, that minimal glue or course breaks and starts to dissolve. You dissolve the foundations something stronger's built on, it goes down too. That's what causes the 'stripes' in the formerly-caulk-plug-like stuck region low-medial to the patella.
    When something sticks in injury conditions, it sticks statically -- meaning if said stuck area rotates and muscles need to slide to accommodate this rotation... it'll pull due to this restriction -- causing pain, spinal 'trick' reaction... and weakness / refusal for muscle to grow under load.
    The first month of this new regimen, was easy enough on those stuck areas, that rather than tear and cause more scar tissue deposition to form (vertical laps)... this 60 - 80% exercise -- constantly monitoring the joint tissues' existing reality of where '80%' is -- worked better at slowly dissolving existing depositions, and returning attachments and damaged tendons / muscle to normal function. And squats under load, have to be part of that.
    Know this to be true, as 2 hrs later sitting at my desk typing this, long after breakfast... knee feels better, even cold. And there's a slight tender spot where the majority of the low-medial bugaboo's been (the rended stuff that shouldn't be there)... but standing and sitting feels better, again cold. So on push days, will have to incorporate some squats and step-ups, to get stuck bits looser -- right now can only comfortably step up 12" -- will start Sat on the first rung of this exercise, a 14" step my knee simply would not lift my weight over. Perhaps even the Return of the Vertical Lap, but smarter...
    More work to do :coffee:
  18. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Fri 26 Dec:
    Middling sleep last night... not sure why, weren't drenched in sweat (the usual reason), mystery really. But awake and alert and may as well get cracking...
    Oogh -- knee's a bit stiff, must be morning of a rest day :p Did the same extra oh, 100m inside the mall, then the ramps. Still felt stiff up top, but just noted for later.
    2 x non-push laps felt a bit less normal than after a rest day (preferable)... but quickly warmed. Xtra mall laps are minted into the protocol.
    2 x push laps: here are the total times... 1st -- 2:44; 2nd -- 2:40; 3rd -- 2:24 o_O; 4th -- 2:21 :eek:
    Times have plummeted -- has to be due to transitioning off the shuffling into jogging sooner and holding on both the long side downhill and the short low side portion to the start line (~8 paces from the low near corner). Reason: less pain, more muscle growth, less adhesion. Figure were I healthy at the same stage in training... 1:50s or lower would be easy, since I'd be running all 4 laps. So getting >10 secs faster than just last week by lap 4 running only long side+... like it (y)
    Milestone: first time getting out of that car at the SE entrance and walking down that slope, knee didn't protest. Didn't do the usual quad-hold on one leg as usual, as that energy were needed in a bit...
    Only testing angles on the downhill to the football field... so caught pace of a local auntie in front of me getting her steps in. Limping, she'd leave me for dead. But despite cooling in the car five mins, was able to overtake her -- on the grass -- on the Big Up. Must be the training, but I feel better climbing that hill, on the grass verge... almost feel my knee thanking me, before the Big Down to the streambed.
    Ut-ut -- stopping here at the west car park. Today, we're going to include exercises at the stations (park has a little isometric self-gym as a feature).
    Did 10 back extensions (laying prone on an angled cement cube w/ a pipe to fasten your ankles on, used for sit-ups and back extensions)... and 10 step-ups as promised, 18" (sorry, misjudged -- not 14" as written earlier). Boy oh boy was that an experience -- all the pain of vertical laps, just 50% more, some grunt work :mad:. Had to boost myself w/ L calf, as knee won't yet allow stepping up to this height unassisted. So did what I could -- and by the 10th rep, L were helping much less, which was encouraging. Wondered what the neighbors across the street thought of my vocalisation first rep tho. Wull bit of embarrassment notwithstanding, if that's what it takes, that's what it looks like shrugs :p
    After doing these two meager sets... set off down the 80% left of the Big Down... and tried jogging it. And whaddya know -- didn't hurt nearly as much as a week ago. May also be the intensity of my arsehole pinching diamonds at the exercise station masking it via perspective... but hoo boy was it nice being able to do something closer to normal...
    Climbing the Big Climb: love doing this, and so glad the knee isn't punishing me anymore, for an innate ability I'd been able to get thru 15-mi marches over SC hilly terrain in boot camp, > 30y ago. My HS has some intense elevation changes... and not knowing better, we felt it normal... until visiting the other HSs in Kahului, on relative level ground. So climbing hills had precedent as 'normal', even in combat boots and 60-lb ruck, kevlar, and weapon. Weird bodily memories of boot camp sprung up doing cadence with breath: at your marching pace, 1-ct inhale, 3-cts exhale as if blowing out a candle (square breathing). Makes the hill disappear in a way, when you optimise breathing.
    The Whoops were not jogged at all; this is a half-push day after all. But felt great cresting the smallest but steepest hill and exiting the SE side. Hope tmw's push day finds me ready to (y)
  19. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Sat 27 Dec:
    Hooookay -- push day...
    Modded the warmup to spend even more time inside (probably 75m more walking), thinking this add'l working bloodflow thru the cold knee scar tissue, will benefit the rooftop laps. Only one way to find out...
    Ramps were a bit sore, tbh. Got some ragged sleep last night, probably 6.5 hrs (not far off the usual 7, but would you like to be roused awake a half-hour early arbitrarily?). Did my New Year's rituals and cringe out the door on those damned stairs...
    [My Japanese New Year's doesn't take long (~10 mins) but I can't skip them, and already have daily CPAP cleaning to do, also mandatory if I want to avoid dirty-CPAP pathologies directly accessing my effing sinuses, w/ vulnerable access to the brain for pathogens. Explains why I need a certain sleep length but also early enough it doesn't overlap these non-negotiables. Sidled up to the start line, and hit the stopwatch]
    Remember on push days, I'm running that entire downhill long side and the short stretch to the s/f line, all 4 laps vs. just 2 on nons:
    Lap 1 -- 2:38
    Lap 2 -- 2:26
    Lap 3 -- 2:21
    Lap 4 -- 2:11
    Holy sheepshite -- even w/ the soreness / stiffness from yesterday (which due to new activities / challenges, wasn't technically a full rest day) were nagging at the start line... shaved 10 secs from yesterday's best time, which is today's 3rd lap time. How the... ?
    Should be noted... the knee felt more tender, but esp on Laps 3 & 4, could very obviously take more load than yesterday. So confused now -- does the knee want more load, or does it want more rest at this juncture? High load early, defo effed me to the root by making knee worse overall, at doing everything. So holding back when feeling froggy seemed the way forward... but how much? And when...? It's a bunch of mixed signals from the knee for sure -- part of which I may need to talk to personal trainers accustomed to injury recovery -- my own ignorance of certain truths from that discipline vs. mine, may hold answers.
    Park time -- initial downhill from the lot were tender but not trick --- which felt fine. Same strength walking that >15% incline, no change to knee angle or strength. Didn't test too much on both downhills to the bowl floor, since would do more at the exercise station.
    Exercise station: back's beginning to feel the core extensions -- and the knee having endured two days of fastest times on the rooftop, really hated sliding into that setup today -- had to get out on rep 5 of 10, just to set the knee and reduce some ham resting tone. Last 5 reps, no problem but it's gonna be an issue next push day...
    Hoo boy -- the 18" step-up. Been a while since I'd felt that body sense physically holding me back from the pain... but f*** it, no sense shrinking from something that needs to happen, in my face...
    Yep. Fook me, that hurt. Full boost from the L leg, more than yesterday, 2 reps. Well, that's an old guy's bag -- get it done and over, gramps...
    By 3rd rep... were using less boost, and pain were fading, if slowly. By last rep (10th)... almost could depend on the R leg the whole step, and pain about 50% less. Sweating like a m'fer tho... but seems immersion in the slop of 9/10 pain, is something the knee's actually working with.
    Sitting rubbing the knee... thoughts of my cane-worker ancestors, persisting in centipede-infested mud to their waists, cutting and baling sticky, heavy cane on shoulders and backs, making meat scraps white people wouldn't buy, into delicious camp classics, if only sustainable living that labourer's life, grunting 90 - 100%, every day of your working life. Felt better about my little twisted knee :notworthy:
    Didn't trot down to the streambed, just walked (balanced yesterday's over-ambitiousness for rest today). The perspective of the pain and remembering who I came from, comfy enough :) Leaning into the Big Climb, no problems -- square breathing really works, should try it sometime (hard to second guess Navy Seal techniques). Was going to try to trot thru the Whoops, when sense and clarity reminded me, I'd done enough with the knee today on that rooftop -- maybe next push day (y):coffee:
  20. futurist
    futurist Member
    53
    92
    United States
    2024 Prius
    Wash Day -- Sunday 28 Dec:
    Really stiff today; could be due to overnight drop in temps that really had me scrambling for some covers (62F, which even for here, is pretty cold 15 feet above sea level). Commensurate pain bending the knee out of bed but not the worst it's been. Gathered up my stuff and started the 'rest' day, that isn't a rest day...
    Man, the knee really hates not doing the workout -- feel it's worse than last week in some ways, much better in others? Great o_O
    Sure enough... despite a really calm day (surprising considering the winds at altitude have been pushing clouds back and forth all day, and made some pretty scenery -- have pics I may upload later), the knee were crying out at the standing-only gig the whole mess -- even made driving a bit of a twist :confused:
    But last Mon, felt great... the best it'd been, despite not being able to do nearly as much as now. Now the currency rate's ability : pain, and can't get one w/o the other being affected. But haven't done the usual pounding on it atop the structure... so hope tonight will get the healing done enough to go another week. And read on, may've done something that pushes the reset button anyway.
    Developed a big crack in my L heel, doing all that exertion in cooler temps. Warmer, more humid days are fine... but when the air dries a bit, my skin cracks -- happened as early as mil days overseas. Used to use bag balm to stop it -- which is nasty and greasy. But when humidity's in the teens & 25F outside... my Hawaiian-raised genes apparently overrule my Hokkaido-born ones :rolleyes:
    The crack's quite painful to run in sandals with -- so will let it heal for another 2 days. May be time anyway, as my lap times were a bit too aggressive last week, according to the heel -- can't run with open sores on my feet. Can't run w/ shoes either -- willll make my athlete's foot flare up. So only recourse is to wait until the crack's healed, and start again. Bright side: no need to buy chicken breasts until Wed :cry:
    My body these days :rolleyes: Just when I were building a head of steam, it fails and forces a sabbatical. What else is new :coffee:
    #60 futurist, Dec 28, 2025
