Wiper Blades or Inserts?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by scotched, Dec 17, 2025.
  1. scotched
    scotched Member
    70
    93
    Encino, CA
    2023 Prius
    OEM blades are starting to show lines. I've had them for a year, and within that year they worked flawlessly for the handful of times I actually used them.
    Wondering if u all went with the OEM inserts or went with another system altogether.
    Where I live it never rains, but pours when it does. My wipers spend most of their time cooking in the sun.
  2. mingc
    mingc Member
    57
    36
    Portland, OR
    2023 Prius
    XLE AWD-e
    Starting with my 2015, which I had until earlier this year, I replace just the inserts. I had the original wipers the whole while and saw no reason to replace them. I'm going to do the same for my 2023, whose original inserts are still doing fine. Have you tried cleaning the inserts to see if the lines will go away? I live in the Pacific NW where it does rain a lot.
    #2 mingc, Dec 18, 2025
  3. BiomedO1
    3,803
    1,976
    SacTown, Ca
    IMHO; you should stick with the inserts. Once you replace the blades, you'll have to always replace the blades - since you won't know if they will accommodate inserts and type of insert blades. Unless you keep the original blades and don't damage them when you replace them.
    I went with commercial silicone inserts several years ago. They've outlasted my original OEMs by 2x now. The original OEMs separated at the pivot point.
    #3 BiomedO1, Dec 18, 2025
  4. notspam3
    notspam3 Member
    60
    34
    Toronto
    2024 Prius Prime
    XSE Premium
    I prefer the inserts - easy to do, generates way less waste. Never had to replace the complete blade holder on any car I've had with inserts since 2008.
    Brian1954 likes this.
  5. VelvetFoot
    VelvetFoot Active Member
    871
    311
    New York State
    2026 Prius
    I just measured the driver's side wiper on my '26: 27"!
    Largest one in my years of car ownership.
  6. rjparker
    10,251
    6,401
    On my gen3 v I replace the inserts over 345k miles. Around 300k I replaced the blades with oem primarily due to faded paint. The oem blades are aero while aftermarkets are not.
    I did replace the driver's wiper arm once due to stripped splines probably due to prior removals and reassembly.
  7. BiomedO1
    3,803
    1,976
    SacTown, Ca
    My dealership has cheaper non-OEM wiper blade options, that's what I was referring to (ie. Rain-X blade assemblies).
  8. BiomedO1
    3,803
    1,976
    SacTown, Ca
    What's surprising is that it doesn't skip and does a great job clearing the glass @ 75 mph for a 27" blade.
    VelvetFoot likes this.
  9. Gokhan
    Gokhan Senior Member
    6,326
    2,527
    Paramount CA
    Inserts, of course. They are cheap. It is not environmentally conscious to replace the whole blade, not to mention that it is totally unnecessary.
  10. scotched
    scotched Member
    70
    93
    Encino, CA
    2023 Prius
    Thanks all.
    Gokhan likes this.
