Misfire Cylinder 4
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gjkristi, Dec 16, 2025 at 9:34 AM.
  1. gjkristi
    gjkristi Junior Member
    30
    I have a 2010 Prius and I'm getting a check engine with Cylinder 4 missfire. Head gasket has been replaced and the engine never goes down so don't think it's that. I replaced the EGR (with toyota new) cleaned the intake and all the pipes. Replaced the spark plugs with new one step hotter plug. Swapped coils 3 and 4. Never see a missfire driving but after a couple weeks check engine light comes on. Anything to try next?
  2. BiomedO1
    3,649
    1,880
    SacTown, Ca
    does the problem ever move off of #4?
  3. gjkristi
    30
    No it does not move from #4
  4. ASRDogman
    ASRDogman Senior Member
    7,602
    3,915
    Switch the #3 an 4 coils. If the problem stays at 4, switch the coils back,
    and switch the spark plugs.
    If it changes, it's the plug.
    Are the plugs from Toyota? Or ebay/amazon..... cheap chinese copies.
    Also, check the wiring harness. It's easy to mess something up without realizing it....
  5. BiomedO1
    3,649
    1,880
    SacTown, Ca
    Well, that kinda makes it easier.
    You need to verify:
    Spark
    compression
    fuel
    in cylinder #4. New spark plugs and moving the coil probably rules out those as a cause, but is that #4 coil getting power or signal? Check the wiring harness for rodent chew marks. Whomever did the head gasket could've loosen up the connection or partially broke the wire.
    Then you need to see if you've got enough compression and fuel in that cylinder. I'd dump some Techron fuel injection cleaner in with your next fill-up and see if there's a compression tester available at your local auto parts store. They'll let you borrow it, if you put down a deposit.
  6. gjkristi
    30
    Already swapped coils no change. The wiring looked OK but will take a closer look. The clips are still there. Thanks Gregg
  7. gjkristi
    30
    I did the head gasket and was careful taking it apart. Ran good for a year after head gasket. I can check the wiring again. The clips are good on the connectors and the car stays mainly in the garage. I have a compression gauge to test. I could send some cleaner down the pipe and see if that helps. Maybe I have a dirty injector. They are all original and would only want to replace one with OEM and kind of expensive. Do you think I could see something with the techsteam software? The code only comes on after a week or two. Driving I don't see any miss fires. Thanks for your help Gregg
  8. ASRDogman
    7,602
    3,915
  9. BiomedO1
    3,649
    1,880
    SacTown, Ca
    Yes, Techstream will tell you how often it's missing and look at the fuel trims for each cylinder. That'll tell you a lot on how the engine is performing and don't limit your search to cylinder #4; sometimes the computer gets it wrong. It can't think, just follows instructions you give it.
    Good Luck.....
  10. gjkristi
    30
    They are from a local parts store not ebay or amazon. Never buy elctronic parts from ebay or amazon
  11. ASRDogman
    7,602
    3,915
    I bought ngk plugs from autozone, because they didn't have the bosch ones I usually get.
    2 failed in less than 1000 miles......
    It's easy to switch the coil packs, and just slightly more work to switch the plugs....
  12. ChapmanF
    18,235
    I had heard some newer Prius models can calculate fuel trims for each cylinder (amazing tech, that).
    I don't think gen 3 could, though. Just a long-term and a short-term trim for the engine overall.
    Brian1954 and BiomedO1 like this.
  13. gjkristi
    30
    I didn't see independant fuel trims only all cylinders (gen 3) This weekend I will do a compression test on 3 and 4 to see if there's a difference in cylinders. Also put a camera down it to see if I see if there are any issues. 3 days of driving and see 3 miss fires on #4. Maybe just on start ups throws a missfire.
  14. ASRDogman
    7,602
    3,915
    :cautious:(n) Wonder why it's called a "miss fire"? :whistle::eek::rolleyes:o_O
  15. ETC(SS)
    7,169
    Try OEM plugs from the stealer.
    I almost never give that advice but it's a fairly good way to avoid knock-off plugs.
    If you know somebody with a borescope you may want to ask nicely if you can borrow it to look inside the hole.
  16. ASRDogman
    7,602
    3,915
    The dealership isn't holding a gun on you to buy from them.
    You don't have to purchase anything from them...
