Can I bleed brakes old fashion way?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hendr1x, Dec 20, 2025 at 3:54 PM.
  1. hendr1x
    hendr1x Junior Member
    22
    US
    My 2011 Prius had the rear brake lines disconnected (changed rear axle beam) so there is air in there but I don't think there is a lot but I have to get it out. I reconnected them each quickly but it happened twice. During removal and installation. I figured I would also do the front and do a full fluid flush.
    Anyway...can someone confirm I can just bleed my brakes the old fashion way with someone pumping on the brake pedal with my battery disconnect. My battery has been disconnected since I started this job and computer has no codes currently. I'd rather not go through the process of invalid mode....never mind spending money on techstream.
  2. ChapmanF
    18,248
    The dependable answer is no. Only with a scan tool can you trigger the opening of various valves in the actuator that are otherwise closed and create dead ends that cannot be bled.
    If you're very sure the only air that entered the system is still localized back near the rear brakes, you might be able to succeed in bleeding air just from those lines, without a scan tool. That would be a specialized exception to the general rule. There's no guarantee you'll get away with it.
    You can't do it by pumping the pedal with the battery disconnected. That only uses the fail-safe hydraulic system, which doesn't include the rear brakes. So the system has to be powered. When it is powered, with a steady pressure on the pedal, you don't have to pump; pressurized fluid will come out the bleeder as long as you have it open (or until the reservoir is drained and air is sucked in up front).
    Without being in the bleed procedure or in invalid mode, though, that excess fluid flow is likely to trigger a trouble code that will leave that line valved off.
  3. PriusCamper
    PriusCamper Senior Member
    12,789
    5,179
    Pacific Northwest, USA
    I've talked to several people who have successfully bled the brakes the old fashion way, even when replacing brake booster pump. But when I go down this rabbit hole I intend to use an Autel device's bleed procedure and if that doesn't do the final calibration I'll use Toyota Techstream on an old laptop.
  4. Tombukt2
    13,033
    2,334
    If you had the rear disconnected at the beam? Fill the reservoir up I'm assuming you let it empty fill it up go to rest of car wait for fluid to come it is coming. Wen it do spin one caliper on bleeder open rt side . Go left add caliper close it's bleeder . Let rt side drip 20 minutes . Close same on left side . Whaddya ya got? No pumping .
  5. hendr1x
    22
    US
    If I have to start the car to bleed the brakes I assume I'm going to get errors in the system. Is that going to screw me. I read a lot people warn about errors that can't be cleared except by the dealer. Is that a concern for me?
    @Tombukt2 I assume that is gravity bleeding? I'll look into that. I didn't empty anything. I just separated the lines and immediately reattached...twice at each junction.
    @PriusCamper : But to bleed the brakes they had to put the car into invalid mode?
    @ChapmanF : Thanks for explaining, I didn't realize that is how it worked.
  6. ChapmanF
    18,248
    Not 'start'. Just power to the brake system (what we often call "IG ON").
    You don't get errors if you are using a scan tool to make the bleeding happen, or if you enter ECB Invalid Mode first, using a jumper wire.
    If you enter ECB Invalid Mode using a scan tool, you do get a code (C1451) that can only be cleared with a scan tool—by going through the bleed procedure, which is what you're there for anyway, so that shouldn't be a deal-breaker.
  7. Tombukt2
    13,033
    2,334
    Yep gravity fills up whole actuator from mid feed to bottom and top of the aluminum block do fluid get in front and behind those opening valves that are not yet . I've lotsa issues with brake bleeding not happening no matter the scanner . Fails on first screen alot Park brake set ign on or ready and so on . Push next and fails fire it starts . But vehicles scan fine 8 can clear all take info etc do other things but not bleed . Had happened 4 times 4 different vehicles battling one today .
  8. Mendel Leisk
    41,495
    It’s not that hard.
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,699
    1,746
    Bay Area
    Just follow this video, please don't make it too hard
  10. Tombukt2
    13,033
    2,334
    Well he doesn't know what he's talking about but yeah this is basically manually bleeding . Dot3. I run 5 but yeppers
  11. indel
    indel Member
    125
    45
    Northwest Indiana
    I asked chatgpt to translate what @Tombukt2 is saying. Here is its response:
    <begin CHATGPT>
    Because of gravity, brake fluid fills the entire actuator—from the middle feed down to the bottom and up to the top of the aluminum block. Fluid does get in front of and behind the valve openings, even though those valves aren’t being opened yet.
    They are having many problems getting the brakes to bleed properly, even when using a scan tool. The bleed procedure repeatedly fails on the very first screen. The scanner gives instructions like “parking brake set,” “ignition on or READY,” etc., but when they press “next,” it fails. If they start the vehicle, it fails again.
    The scan tool itself works fine otherwise: it can scan the vehicle, clear codes, read data, and perform other functions—but it will not run the brake bleeding procedure.
    This has happened to them four times on four different vehicles, and they are currently dealing with the same problem again today.
    </end CHATGPT>
    Edit: "they" == Tombukt2
    #11 indel, Dec 21, 2025 at 5:45 PM
    PriusCamper likes this.
  12. PriusCamper
    12,789
    5,179
    I love it... I'm gonna use AI to make sense of his writings in the future too!
    indel likes this.
