Brake creaking noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by saneesh8, Dec 22, 2025 at 1:05 PM.
  1. saneesh8
    saneesh8 Member
    191
    Allen, TX
    Hi all,
    I have been dealing with a weird noise seems like brake creaking noise for a while now. Replaced the rotors and pads (Akebono) last week and the noise remains same. There is no sound in braking, but after releasing the brake and car starts moving, it makes this creaking noise which is kind of like metal creaking. I will try to record the sound.
    Initial thought was suspension related, but once the car starts moving, there it no noise on pot holes / bumps etc. It is not rattling also. Confirmed that the brake shield is not touching the rotor.
    While replacing, i cleaned it thoroughly. Cleaned the re-lubed the pins with silicone grease also. It was not stuck and was freely moving.
    What can it be? is it a worn out caliper pin/Cylinder Slide Pin (47715-47010)? If so, both sides. Checked the calipers also. No rust and boots are fine.
    The sound is very similar to this, but only on brake release and once car starts moving ->
  2. PriusCamper
    PriusCamper Senior Member
    12,792
    5,180
    Pacific Northwest, USA
    I had that for a couple hundred thousand miles till I replaced the brakes... Lubing the calipers pins is what I believe the source of the noise is, but not certain. Did you lube yours?
