Is Gen2 Prius still a reliable purchase in 2026?
Discussion in 'Gen 2 Prius Main Forum' started by gafortiby, Dec 25, 2025.
  1. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Hello Gen 2 owners,
    I am a happy Prius V owner looking for a 2nd car. I am looking for a reliable used car, with the following requirements.
    • Budget $8000 USD (in US market) which is probably a 2009 with 120k miles.
    • Reliable : near 0% chance of $3000+ problems in the next 50k miles. Fuel tank? brake booster?
    • Old hybrid battery is not a problem, I can DIY that.
    • Toyota but not Lexus
    • Hatchback/wagon for utility
    • Automatic climate control (okay maybe that's asking too much)
    • Backup camera (I can install it myself it needed)
    • IIHS rating is GOOD for both side/front.
    I posted in the Gen3 forum, and so far the consensus is do not buy a Gen3 with 150k miles on it because it will have head gasket/oil consumption issues at my budget. So, I thought I'd ask here about Gen2 instead. Buying a used 150k mile Gen3 Prius in 2026
  2. Tombukt2
    13,258
    2,393
    Own 4 with your budget for the one at 8K I don't mind faded paint . But must have leather interior air must work no exceptions . Don't care about heat . Inside must be clean it's wer I live . Hybrid batteries I keep here and plenty of parts here . Easily last forever . Keep em away from others . They will wreck them . I don't let anyone use em anymore wen I do they get wrecked. .now they so old no one asks anymore .
  3. bisco
    52,252
    they were great cars, built like tanks. no one can guarantee reliability, especially on the one you buy vs the overall fleet
    gafortiby likes this.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,759
    825
    Southern California
    That's a bit unrealistic. Things break on old cars, often several things close together. Your odds of having no huge expenses for 50k miles will be better if you buy something like a Corolla or a Civic, old enough not to have either GDI or a CVT transmission (a manual would be best), and only if there is no significant corrosion. Even so, having the A/C evaporator fail is a significant risk in a car that old, and it will be a $3000 job unless you do it yourself, because the whole dash needs to come apart. In that distance a car will need tires, and if it is old, it may well need shocks or other suspension components. That could easily come to $3k too.
  5. Leadfoot J. McCoalroller
    8,129
    7,626
    Pennsylvania
    2018 Prius c
    No.
    Thank you for coming to my TED talk.
    bisco and gafortiby like this.
  6. gafortiby
    gafortiby Member
    97
    58
    Colorado
    I found a very nice 2009 Prius but it has a C1300 that showed up, and inspection note is: "Skid Control ECU will have to be replaced if the code comes back"
    I'll pass on that but it seems anything this old has risks, the next 2009 I find might have a different issue too.
  7. bisco
    52,252
    i'll say this much, it's only 3 years older than your v, and was built better in the engine and brake booster
  8. Leadfoot J. McCoalroller
    8,129
    7,626
    Pennsylvania
    2018 Prius c
    I got my cheap shot humor out of the way, so I'll give a few more words.
    Those 2nd generation Priuseses were fantastically reliable cars, but now they're all too old and used up. Old cars will eat your wallet no matter how reliable they used to be. And an old Prius is especially good at it due to its complexity.
    For your budget? stick to a simple car that anyone can repair.
    gafortiby, frodoz737 and Brian1954 like this.
  9. Leadfoot J. McCoalroller
    8,129
    7,626
    Pennsylvania
    2018 Prius c
    Just to add:
    Across a 50,000 mile driving career, the difference in fuel costs between a typical compact gas burner @38 mpg and a Prius in top shape @48 mpg is maybe $1,000.
    Basically any problem in the Prius is going to eat that difference and ask for seconds.
  10. pasadena_commut
    2,759
    825
    Southern California
    It does depend on where a person is driving. The above analysis uses MPG which is 100% highway. In pure city driving something like a 2005 Civic (excluding the hybrid, and Lord knows, one should definitely exclude that hybrid) will only return 25-26mpg. The Prius in pure city driving can still do over 40 mpg, let's say 42. Assume gas is $4/gal (for a round number) . That would be $4762 for the Prius and $8000 for the Civic. The $3238 difference favors the Prius and might be enough to cover repairs during that period, especially if the owner can do some or all of the work. Additionally, the Prius is unlikely to need brake pads in that 50K, while the Civic will need at least one set. (Pretty much a rounding error compared to replacing the gas tank on the Prius, for instance.)
    But I don't disagree with your point.
    There is some chance of coming out ahead in some circumstances with the Prius, but it is more likely to work out better with a conventional car, and much less likely for a catastrophically expensive set of mechanical failures. Going back to the gas tank, a failed gas pump in the Civic is a relatively cheap repair (if the owner changes it, anyway), in the Prius very expensive if the owner does it and outrageously expensive if a mechanic does. About the only thing which is the other way around is the steering rack, since the electric ones have turned out to be more reliable than the hydraulic ones.
  11. Leadfoot J. McCoalroller
    8,129
    7,626
    Pennsylvania
    2018 Prius c
    Another point of consideration is the intended career for OP's next car.... From the other thread, I learned that they want to put 50k miles on it.
    Ok great... but how quickly will that happen? 50k miles spread over two years isn't such a terrible risk in my mind- get those hits in before the car has time to age into more problems. Might even get through it without anything expensive happening.
    50k miles spread over 10 years is another proposition entirely. The car absolutely will have time to develop more problems, and if it happens to be an old Prius they'll be expensive problems.
    The underlying point to the whole thing is that the best way a Prius can save you money is if you drive a lot of miles, and you drive it for enough years that they really rack up.
    If you start with an older Prius, you just don't get very many years before it starts throwing expensive problems at you, negating all of those savings.
    If you aren't driving a lot of miles, or won't own the car long enough to rack them up, (or both) then what's the point? You might be saving gasoline, but you're clearly not in it to save money.
    #11 Leadfoot J. McCoalroller, Dec 28, 2025
  12. rjparker
    10,391
    6,507
    $1.77 gas in Colorado makes Prius gas savings less than $1500 even at far less than epa mpg.
  13. Moving Right Along
    Moving Right Along Senior Member
    730
    586
    A gen 2 Prius can definitely be a very reliable vehicle, and while it is certainly unlikely that you’ll have a $3000+ expense from one, it would be unrealistic to say there’s a 0% chance of that happening. Think of a Prius similar to a Corolla: they’re both practical and reliable cars, but after enough time and miles (time more than miles on the Prius), they still break.
    Is a 17-22 year old Gen 2 Prius a good risk compared to other cars the same age? Absolutely.
    But can you guarantee there won’t be a catastrophic failure? No.
    The older a car is, the more important it is to pay attention to how it was maintained before being put up for sale. A well maintained 2nd Gen Prius will likely treat you well, but you might have more problems with a poorly or even a sporadically maintained one. If you pay attention to the maintenance history, that (along with a pre-purchase inspection) will give you the most important information about whether to buy or not.
    gafortiby and Brian1954 like this.
  14. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Thanks for the analysis everyone. The consensus appears to be that a 2009 Prius is just too old and complex to be risk-free, even if it was a reliable car in the past.
    I appreciate everyone trying to prevent me from making a big mistake, but I am confused on two points.
    1. Car shoppers generally use the fuel-cost formula to calculate a break even point when comparing a new hybrid with a new non-hybrid because the hybrid version costs more. But, in my 100mile radius (Denver, Colorado), a used 2009 Prius is cheaper than nearly every 2009 Toyota of same mileage and condition except a Yaris. (A 2010-2011 Prius is even cheaper but I think we know why.) Perhaps the gen2 Prius is cheaper because everybody knows that the old hybrid battery is going to need replacement soon. But I can get a used 2009 Prius and install a new bumblebee/greentech battery, and it will still be cheaper than a used 2009 Rav4.
    2. The things that make a gen2 Prius more complex/expensive to repair is stuff like inverters and hard-to-repair brake system. But replacing those is not any more expensive than replacing the short block of an oil-burning 2AZ-FE engine (many 2009 Toyotas with I4), or a replacing a blown 2GR-FE engine (many 2009 Toyotas with V6) when the rubber oil cooler line ruptures.
    Still, I think I understand the point being made. What I am hearing is that any 17 year old car will have problems, so it is unreasonable to expect a 2009 Prius to be problem-free just because of its great reputation.
    So... given my budget and the very high Toyota tax I see in the used market, I may need to buy a newer non-Toyota model like a 2012 Mazda 3 Hatchback. Or the 2012 Ford Escape :eek:.
  15. Leadfoot J. McCoalroller
    8,129
    7,626
    Pennsylvania
    2018 Prius c
    Again I have to wonder about the timetable and not just the intent to drive '50k miles.' A rebuilt hybrid battery can work well for a year or two- they really are valid as short-term fixes. But if you plan to operate the car much longer than that, you should budget for several of those in a row or a real Toyota OEM replacement.
    The more general note? Lots of Priuseses were owned and operated by frugal people. The decision to sell or trade came after they felt they'd squeezed that orange for every bit of good juice. They may well have been correct. The market is sending you a message- it's up to you to interpret it.
    I haven't done a detailed comparison, but in almost any city in America there are 100+ independent garages who will gleefully compete with each other to do an engine swap for every one that even knows how to successfully swap a Prius brake booster.
    Consider the Hyundais as well. They richly deserved their reputation as terrible cars up until about 2005. After (roughly) then, they flowered. We had outstanding results from a 2007 Accent and I've enjoyed renting and driving many more recent ones. We have a Mazda now, though it is too young for me to prognosticate upon its virtues as an old car.
    Good luck!
  16. rjparker
    10,391
    6,507
    Often people asking for advice on a buying a used Prius are simply looking for validation for a move they want to make.
  17. pasadena_commut
    2,759
    825
    Southern California
    Do those new batteries use cylindrical cells or prismatic ones like the OEM? At least historically the latter have been longer lasting than the former.
  18. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Oh? I didn't now you could build a Prius pack with cylindrical cells. Because the cells in my Honda Civic Hybrid are cylindrical and therefore they will not last even if I get new ones. Honda hasn't made any new OEM packs for many years.
    Haha this is true. I see the points here though, so I don't think I'll be looking for a gen2/gen3 Prius anymore. That still leaves me with the problem of finding a used Toyota, and that is still though. I think everyone knows every used car trick now, because even Pontiac Vibes are very expensive now.
    Lots of Toyota owners are frugal and either they dumped their beloved Toyota because it had some high-cost failure, or different Toyota owners are neglectful and dumped their Toyota after years of abuse. Years ago, a friend told me "what's an oil change? I was told Toyotas are bulletproof so I have never been to a mechanic"--I think their first oil change was at 50k miles or something ridiculous like that. I am finding used Avalon or upper-trim Camry tend to be gently used, comparatively.
  19. gafortiby
    gafortiby Member
    97
    58
    Colorado
    10 years 50k miles. That's my usage timetable. I would drive it at least once a week though, so a stable hybrid battery like the Prius prismatic cell design should be fine. ... wait is "Prismatic" where Prius gets its name?
    I agree based on the used cars I'm seeing in my market.
  20. Moving Right Along
    730
    586
    What Leadfoot said about Prius owners tending to keep their cars until they have gotten every bit of use of it may be true. I know I decided to move on from mine only after it started getting spreading rust and yearly repairs got more expensive.
    I think concerns about hybrid batteries are often overblown. Only a small percentage of Prius batteries have ever needed to be replaced, so although we know what factors make batteries happy and unhappy in general, it’s hard to predict specifically for any given one that’s not currently showing signs of problems.
    What has been proven regarding hybrid batteries is every option apart from OEM is inferior and much more likely to fail within 2-3 years. That includes rebuilt, rebalanced, remanufactured, and custom new options with either Lithium, Sodium, or Nickel based batteries. From what I’ve read on this forum, I would ONLY trust new hybrid batteries from Toyota if you need a replacement.
    I don’t know why the Prius is cheaper than other Toyota models of the same age, but my best guess would be supply. There are more older Prii on the road than there are most other models, so you get a bit of a discount compared to other models that might be in shorter supply.
    I completely agree with your second point and disagree with many others on this forum that consider the Prius uniquely expensive to repair. Just because there are some expensive parts does not mean that they fail at rates any higher than the expensive parts in other cars.
