Newbie code u0129
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rone5399, Dec 29, 2025.
  1. Rone5399
    Rone5399 New Member
    washington
    Just got 2010 it has 0129 code bought it k
    This way. History. Long term owner had bakes done at les shuab had allmost all warning lights on when they got it back Shuab said we checked and we did nothing wrong. They drove it to dealer. They found code u0129 then checked for chewing and damage told them it would take More time to further analize problem (remove wiper cowl and testing resistance etc and would probably be several thousand to fix they took it home instead. It drives fine I test brakes the rear lock up under hard braking. Abs probably not working. I think I'll start by checking for any damage they may have caused by improper lift etc Any ideas foe me
    They charged the over 600$ for help
    52,286
  3. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    You created this thread in the Prius c forum, which started with model year 2012. If you car is model year 2010, it probably is a Gen 3 Prius hatchback. Can you please confirm what car you own?
  4. Rone5399
    Rone5399 New Member
    washington
    Yes to gen 3 sorry about that
  5. Brian1954
    2,371
    954
    No problem. I will ask a moderator to more this thread to the correct forum.
