Dirt/Grime getting under rear door OEM PPF
Discussion in 'Gen 5 Prius Main Forum' started by theRob, Jan 3, 2026.
  1. theRob
    theRob Active Member
    103
    119
    2023 Prius
    It looks like dirt and grime is getting under the rear door PPF on both sides. Will the paint get damaged if it stays like this for too long? Does anyone have the part number for this film?
    #1 theRob, Jan 3, 2026
  2. Mendel Leisk
    41,660
    3rd gen had some smaller strips of that nonsense. Ours was in semi-decent condition, not as bad as some I've seen posted, but I opted to remove it. Gentle application of a heat gun, pick at a corner (with just a fingernail) to get it started, slowly peel it off. Do it with bare hands so you've got feedback as to how much heat you're applying. Finished off with a little car wax, all residue disappeared.
    theRob likes this.
  3. theRob
    103
    119
    2023 Prius
    You think I should replace it though? It’s there to protect the paint from rocks hitting the paint right? I’m wondering if it’s worth replacing or not.
  4. Mendel Leisk
    41,660
    My 2 cents, leave it off. Wax the zone abundantly.
    dolphinsil likes this.
  5. Kenny94945
    Kenny94945 Active Member
    854
    430
    Sausalito
    2016 Prius v wagon
    If dirt, I do not think the paint will stain, deteriorate, etc... get damage.
    I have never had good luck "detailing" the edges of PPF.
    (Horsehair paint brush, detailing spray, Q-Tip, a wooden toothpick as sample tools)
    Your call whether to leave as is, try some detailing, or replace.
    You should be able to find the parts price somewhere on the 'net.
    Labor, I could only guess (remove, polish, prep, install)... 1 hour each side?
    FWIW with my own level of OCD and that beautiful Platinum Blizzard Pearl White paint, I would replace.
    Good luck with your project :)
  6. Gokhan
    Gokhan Senior Member
    6,326
    2,527
    Paramount CA
    Interestingly, my blue magnetism 2021 Prius Prime Limited came with PPF from the factory on both bumpers, mirror cups, and door handles. There was no port-installed accessory PPF. The factory PPF is probably thinner, but it’s extremely inconspicuous. Most people don’t even know that it is there.
  7. rjparker
    10,251
    6,401
    It looks like poorly applied dealer ppf. I would take it back to them if there is a 3 year warranty.
    Otherwise I would find an XPEL ppf dealer with an indoor shop to remove your ppf and install one of their two ppfs with edge seal.
  8. VelvetFoot
    VelvetFoot Active Member
    871
    311
    New York State
    2026 Prius
    I don’t think it’s dealer applied. Looking at the salt deposits the road spray makes me think the shape of the car might cause increased hits of debris there. I think it’s factory applied.
