Huge MPG Loss
Discussion in 'Prius c Fuel Economy' started by CMJAnew, Jan 2, 2026.
  1. CMJAnew
    CMJAnew Member
    121
    24
    I haven’t eliminated the EV system….however, having driven C’s for better than 600,000 miles combined (three cars) I’ve not experienced an MPG loss like this - WELL OVER 10mpg loss happened pretty much overnight - but not last night - LOL
    I have eliminated brake drag and wheel bearing issues. The car has new spark plugs and air filter.
    There is a noice that sounds similar to ‘traction control/stability control’ activation coming from the passenger front only when the ice engine is activated. At least that is where I believe it’s coming from.
    Also, when watching the onboard “home” screen it seems to get extremely poor mileage - like 35ish mpg at 65mph (history says it should be getting closer to 50 than 40 at those speeds).
    ThanksMuch, and happy new year
    52,792
    so you're not tracking it at the pump?
  3. Mendel Leisk
    42,289
    The dash display, albeit skewed, is at least consistently skewed.
    Any new tires in the mix?
    Gas up somewhere other than the usual?
  4. bisco
    52,792
    12 volt or hybrid battery weak?
  5. BiomedO1
    4,537
    2,389
    Left Coast
    If your only hearing a noise when the engine is running; there's a high likelihood that's an engine noise your hearing. Traction/stability control, wheel spin issue, suspension issue; you should also hear the noise when the engine is OFF too, since the car is also moving.
    You'll need to put the car into maintenance mode to track down that noise. Could be something as simple as, something rubbing up against the harmonic balancer.
    Good Luck..
  6. CMJAnew
    CMJAnew Member
    121
    24
    I’ve confirmed the MPG with calculator too. I ALWAYS reset trip A at fuel up.
  7. CMJAnew
    CMJAnew Member
    121
    24
    Four New Tires AFTER the mileage drop. I gas up all over the place - no specific brand.
  8. CMJAnew
    CMJAnew Member
    121
    24
    This may sound stupid, but what is “maintenance mode”?
  9. rjparker
    11,027
    6,916
    Maintenance Mode
    Continuously Idle Engine
    Press Start button 2 times without Brake
    (ignition On)
    Press Gas Pedal 2 times
    Press Brake and shift to Neutral
    Press Park
    (hybrid warning light will start flashing)
    Press Brake and Start button
    (starts engine, shutdown returns to normal)
    Cliff Notes:
    Ignition Mode, 2Gas, Neutral, 2Gas, Park, 2Gas, Start Engine
    BiomedO1 and CMJAnew like this.
  10. CMJAnew
    CMJAnew Member
    121
    24
    Here’s an addendum or two to my original query;
    1. the issue started when a driver side wheel bearing was replaced.
    2. So today I put my cheap diagnostic tool on the car. I monitored the live wheel speed - the driver front is reading some 5mph off when compared to the other three. Like the fool I am, I didn’t check the speedo — nor do I recall if it’s reading faster or slower (I’ll try again with a passenger this evening).
    thanks for trying to help….i know I’ll not be fixing the issue myself, but I like to have some idea when ‘going in’
  11. rjparker
    11,027
    6,916
    Continuous idle maintenance mode was suggested to allow you to find the noise; not locate the mpg issue.
    If you had a 5 mph difference from that wheel's speed sensor you would get a specific code for that sensor.
    Most Toyotas of that vintage display high mph to the driver and accurate mph to a scanner. At 65 it displays around 3 mph high.
    Typically drastic mpg drops are usually caused by a weak hybrid battery.
    I would also clean the throttle body and perhaps suspect a clogged catalytic converter.
    BiomedO1 likes this.
  12. Brian1954
    Brian1954 Senior Member
    2,665
    1,066
    South Central PA, USA
    Use a scanner and look at the short-term and long-term fuel trims. If they look good, my guess is the hybrid battery is getting weak (losing capacity).
    #12 Brian1954, Jan 3, 2026
  13. CMJAnew
    CMJAnew Member
    121
    24
    No Code Specific to the driver front wheel sensor. With a passenger reading the scan tool, we determined the wheel is reading about 5mph slower than the other three AND the speedo.
  14. CMJAnew
    CMJAnew Member
    121
    24
    Just to reiterate, the mileage drop was immediate….not a gradual change. And it happened the day of the bearing replacement. On another thread I mentioned unintended wheel spin due to the bottle jacks on the lift not being fully retracted (free spin in reverse). That is also the exact time the noise started. I’ll do the maintenance mode check today. Probably won’t learn anything …. due to my lack of mechanical aptitude.
  15. CMJAnew
    CMJAnew Member
    121
    24
    I don’t understand the “….fuel trims….”
  16. CMJAnew
    CMJAnew Member
    121
    24
    I did this procedure….the dash indicated “maintenance mode” + “trac off” in rotation. But, this did not lock out EV. It still cycled into EV mode while running.
    So, rather than waste any more of you guy’s time, I’m just gonna contemplate my next move.
    I will report back with any findings going forward.
    thanks again
  17. bisco
    52,792
    you had a bearing replaced and mpg immediately dropped? Occam's_razor
  18. CMJAnew
    CMJAnew Member
    121
    24
    Yes Sir. And that’s the same time the noise on the opposite side started.
  19. bisco
    52,792
    and that isn't worth taking a look at?
  20. CMJAnew
    CMJAnew Member
    121
    24
    Other than a manual turn of the wheel(s) while jacked up and in neutral?
