XM Radio
Discussion in 'Gen 2 Prius Technical Discussion' started by brianarkin, Jan 29, 2007.
  1. brianarkin
    brianarkin New Member
    Hello,
    Does anyone know the install process to install a Toyota factory XM Radio in a 2007 Prius? Is this car pre-wired for the radio? Does the dash need to be opened? Where does the actually XM radio go? Sorry in advance if I am not using this board correctly. This is my first posting.
    Thanks!
  2. aaf709
    3,862
    2022 Prius Prime
  3. brianarkin
    <div class='quotetop'>QUOTE(aaf709 @ Jan 29 2007, 04:41 PM) [snapback]382441[/snapback]</div>
    I looked at that document from metrotpn and it covers 2004-2005. Are there any wiring differences? I seen some discussion about how the XM Radio fits into brackets under the rear seat. This is different then the metrotpn document.
  4. aaf709
    3,862
    2022 Prius Prime
    I believe it still plugs in the back of the radio. I've been hearing, though, that the new method is putting the antenna on the dash, so the XM part would fit in a different location.
  5. BethlehemPrius
    BethlehemPrius New Member
    180
    Bethlehem, PA
    I just purchased the xm radio from the dealership when I bought my 07 about 3 weeks ago. They installed it and I ended up taking it out not liking the line up of xm and switched back to Sirius.
    However, they mount the unit under the rear passenger side seat. You pull the seat bottom cushion out and there is a plate that unscrews and they mount the unit to the underside of the plate with brackets.
    The dealer gave me the full instructions of how to mount the unit since I asked to move the antenna from the window to the roof. Its really quite simple to place it at that location with the right tools, brackets from toyota.
    btw (still have my xm unit listed 4sale on here if your interested)
    Good luck
  6. brianarkin
    <div class='quotetop'>QUOTE(BethlehemPrius @ Jan 30 2007, 10:04 AM) [snapback]382770[/snapback]</div>
    I found a dealer that provided me a 15 page Toyota installation guide for tuner assy 86180-0W030 and mounting kit PT546-07060. The installation guide matches your description.
    How did the radio work with the antenna on the corner right-front dash? Did it look OK? How well did the reception work? When you moved the antenna to the roof, did the antenna and antenna ground plate come off the dash OK?
  7. BethlehemPrius
    180
    Bethlehem, PA
    <div class='quotetop'>QUOTE(arkinprius @ Jan 30 2007, 04:39 PM) [snapback]383008[/snapback]</div>
    the Radio worked so-so on the dash, it still had a decent amount of fuzziness-static at some points due to the location. It didn't look to bad, however I didn't have the plate to mount it on, so I just had it stuck there with a little bit of sticky tape.
    The dealer provided me with a new antenna and I placed that on the roof, it improved the signal a great deal in my opinion and do not lose the signal near as much. I may be partial since my 4runner has an antenna on the roof, so I was comparing my signal to that vehicle.
    When the dealership gave me a new antenna, the claimed it was an external one, however it looked identical to the previous one! And it seems to be fine on the roof with just the magnetic aspect and no ground plate. If you want any pictures of the radio in the car under the seat or of the roof with antenna let me know, i have some on my digital camera.
    Good luck.
  8. brianarkin
    <div class='quotetop'>QUOTE(BethlehemPrius @ Jan 30 2007, 04:53 PM) [snapback]383016[/snapback]</div>
    Thanks for the quick response. A couple of picture would be great. I think I will go with the roof mount. How did you run the wire? Any issues I should be aware of.
    Thanks!
  9. aaf709
    3,862
    2022 Prius Prime
    I put my XM antenna behind the regular antenna. Others have mounted theirs inside the spoiler and some have put it inside the sharkfin antenna (if they installed one).
  10. BethlehemPrius
    180
    Bethlehem, PA
    <div class='quotetop'>QUOTE(arkinprius @ Jan 30 2007, 05:53 PM) [snapback]383035[/snapback]</div>
    Hey there,
    here is the link for how I have run my current antenna and past ones. I don't have the other photos on this pc but will post em online once I get back home.
    http://priuschat.com/Installing-satellite-...lly-t28807.html
    Any more questions feel free to hit me up again.
    ps. I think someone on the thread above suggested routing it through the rear tail light or something.... I have never tried it, in my opinion the way I did it was the easiest way...but to each their own :)
  11. BethlehemPrius
    180
    Bethlehem, PA
    my antenna on the roof looks just like the guy who posted it above my reply, so I have included the other photos of the piece you can remove under the back seat and also how I ran my wires down around the hatch.
    Ok having issues adding the pics... will have to try later on, sorry.
  12. brianarkin
    <div class='quotetop'>QUOTE(BethlehemPrius @ Jan 31 2007, 01:18 PM) [snapback]383359[/snapback]</div>
    A few pictures of under the seat and routing of the wire would be helpful. I will check back later.
    Thanks!
  13. aroide
    aroide New Member
    Phoenix, AZ
    <div class='quotetop'>QUOTE(arkinprius @ Jan 29 2007, 02:06 PM) [snapback]382418[/snapback]</div>
    I ordered the kit from factory interactive http://www.factoryinteractive.com/PriusXM/ . It was quite easy, took me 3 hours. The kit comes with a 'how-to' DVD and the radio shipped is a Toyota factory radio with a slim (very slim) antenna that you can mount right behind the esittimg am/fm antenna on the roof. I'm tech savvy, but not the kind of guy who could build a ship in a bottle or do detailed finish work. Luckily, the Priusm pretty much snaps apart, so install was easy.
    Note that the DVD discusses how to best install a bigger, older antenna. When I called John to get advice on the smaller antenna, he had great info on how and where to install it. He also had advice on how to get to the connecter behind the radio without unsnapping the whole dash... saved me an hour of install work.
    Other than seeing a tiny 2"x2" antenna on the roof, you'd never know the installation was there. And reception is great for both satellite and terrestrial with this antenna placement.
  14. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    It is also available through the PriusChat Shop:
    http://priuschat.com/shop/product_info.php/products_id/69
    You'll receive documentation along with the XM unit to help you install it (it uses the "install under the seat" technique), plus you'll get the warm and fuzzy feeling that you've helped to support PriusChat :)
