Buying a used 150k mile Gen3 Prius in 2026
Discussion in 'Gen 3 Prius Main Forum' started by gafortiby, Dec 23, 2025.
  1. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Oh my, voice commands? Seems bad to me, as a very verbal driver….
  2. CR94
    CR94 Senior Member
    2,749
    1,204
    Northwestern S.C.
    At >160k, my 2011 doesn't consume that much oil. It's not likely the only one that doesn't.
    It's not guzzling coolant, either.
    priumium likes this.
  3. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Looking at a used 2010 Prius for $3700 with 220 K.
    One owner and suppose to look really nice.
    My understanding is that the EGR valve and Head gaskets are major issues?
    Can I preemptively simply replace them?
    If I do so, a video that is not time lapses seems to be 30 to 35 minutes
    How long is the replacement job and is it something one person can on their own reasonably easily?
    How much for a shop to do these things?
  4. Brian1954
    Brian1954 Senior Member
    2,402
    962
    South Central PA, USA
    It would cost more than the $3700 price of that car. Do not buy that car unless you can do the work yourself. The head gasket replacement is very involved.
    Please keep this discussion in the thread that you created, https://priuschat.com/index.php?posts/3588731
    #44 Brian1954, Jan 3, 2026
  5. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    Was a dealer and I get there and it has the triangle of death.
    If what the mechanic said is correct about the code, inverter coolant sensor.
    According to Car Fax though, it looks like the head gasket had already been replaced.
    Buying no car with the triangle of death though.
  6. indel
    indel Member
    274
    88
    Northwest Indiana
    There are a lot of misconceptions about "red triangle of death". It does not literally mean that the car's life is over. But yeah, buying one seldom makes sense unless you are able to fix it yourself and have the knowhow and experience (and $$$).
    CR94 likes this.
  7. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    That is a must be solved before I consider buy it and I drive it off the lot and if it comes back within 100 miles, I will see you in court. Likely more like 1000 miles but that may be a bit harder to argue.
    I have replaced on my own, one inverter coolant pump, one inverter, and five total battery replacements.
  8. Mendel Leisk
    41,898
    The EGR system very obviously went into production untested. It clogs, often asymmetrically, with cylinder one end starved first, overheat ensues, and head gasket fails, typically on the exhaust side of the common wall between cyl one and two..
  9. rjparker
    10,503
    6,593
    I hope this was not a new car dealer selling a broken $3700 gen3 with 220k miles. Most likely it was an auction buyer who paid $1000 plus $500 in fees and would have given you a "deal" at $2500 if pushed.
    My take on gen3 issues is quite different than Mendel's based on a local shop who has changed about 1000 gen3 engines in the last three years along with hundreds of brake boosters and a few inverters using junk car stock.
    Toyota knew the downsides of low tension rings but were pushed by management to improve mpg while reducing costs on a rather complex drivetrain. At the same time they were engineering advanced safety systems for gen3 and went to 10k oil changes with the first two free reinforcing that unfortunate schedule which aggravated the low tension ring problem.
    Gen3s typically do not overheat even when head gaskets start to fail. Months later some drivers might lose enough coolant to eventually overheat but most rebuilt or exchanged engines never overheated the original. The gen3 death rattle forces action first. Sealant can mask the head gasket leak for weeks or months which is great for flippers; terrible for buyers.
    Egrs were not used on gen2s so they used very expensive catalytic converters that later became a thieves best friend. Gen3 used a less expensive cat along with an existing egr system that worked fine on conventional Corolla 1.8s but proved inadequate on a stop start hybrid. Dramatic thermal cycling of gen3s added to the issue. Gen4 1.8s used reengineered pistons, rings, head gasket, cylinder walls and egr systems along with good results. However gen3 owners were left holding the bag.
    Brake boosters were a problem on gen2s as well and really did not improve until gen4 and were dramatically improved in gen5 hybrids.
    Gen3 inverters were also a poor design and would strand drivers without warning. They are still covered due to the only successful gen3 class action suit. However being stranded with something that takes a week to fix is absolutely no fun. Ask me how I know.
    Better to look elsewhere for a reliable low cost of ownership used car. And we did not even discuss hybrid batteries.
    #49 rjparker, Jan 4, 2026
  10. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    I think they likely bought it at auction. I will say that there are a lot of third gen driving around my local area. They are not rare currently but there are still a lot of second gen as well.
    I know 2nd Gen (and 1st Gen) much better. Likely be a better option to stay with them for the moment.
    If I had about 8 k, I have been seeing some "older" (2017 or 2018) Chevy Bolts around and spoke to the owners. They said it gets 200+ miles and most seem to really love them. Nissan Leafs don't usually have enough range to get back and forth to work unfortunately.
  11. bisco
    52,386
    have you considered a used ev?
  12. Mendel Leisk
    41,898
    That is Toyota USA. For 3rd gen Toyota Canada specd 8k kms (~5k miles) for oil and filter change. No maintenance freebies either. Same damn piston rings though.
  13. rjparker
    10,503
    6,593
    Toyota had previously used low tension rings for years on Rav4s, Camrys, Corollas, Scions and Matrixs before deploying them on gen3s. What is interesting is they stopped using them on three models before the gen3s were released and by 2012 only Prius still had them.
    Toyota replaced thousands of Prii pistons, rings and head gaskets free when excessive oil burning of one quart in 1200 miles (!) was verified assuming the 60,000 mile powertrain warranty was still in effect. That is more than four quarts in 5,000 miles, essentially burning all the oil for the owner who never checked their oil.
    A good gen3 engine will burn no observable oil in 5,000 miles even with low tension rings. But extended oil change intervals of 10k miles, initial coolant changes at 100k miles and excessive carbon buildup due to oil burning left most owners with engine problems.
    All of which suggests a used gen3 is a poor bet. Coding and 220,000 miles? Forget about it.
    priumium and Mendel Leisk like this.
  14. gafortiby
    gafortiby Member
    97
    58
    Colorado
    I thought about a used EV but the battery degradation on the old Leaf is much worse than the battery degradation on any hybrid, and it wouldn't be a useful 2nd car for the family if it cannot drive 150+ miles in one drive (because the distance between Colorado Springs-Denver).
    I think you're citing low-tension rings in 2AZ-FE engines (TSB link), different engine from Prius, but I agree that Toyota used the low-tension design a little too much. Perhaps what would reinforce your point more is the fact that the Corolla 2ZR does not burn oil even though the Prius 2ZR does: 2ZR oil consumption TSB, another evidence that the Prius is uniquely "fragile"?
    Still, my 2012 Prius V has been so useful as our primary family car for ten years, a Corolla could not have worked (a highlander might have worked?), and I do not regret buying it ten years ago even if the Prius died tomorrow. Of course this thread is about buying a Gen3 Prius with 150k miles, so it is a different calculation.
  15. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    is a Gen 3 with the same miles as a Gen 2 actually a worse deal?
  16. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    NO! The 3rd generation is a huge improvement over the 2nd.
    As with any car it has it's issues.
    My had gasket lasted 301,000 miles.... Still have the original master cylinder and pump.
    The OEM Hybrid battery lasted 340,763 miles.
    Just because there are some who want other to enjoy there misery, don't let it sway you.
  17. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    Surely this should depend on the price and the definition of a deal. For an inclined DIY, there are many ”cheap” G3s to pick up, perhaps with above mentioned issues..
    G2 has less root motor issues - and since it sold above a million vehicles globally, affordable spare parts and instructions and fixes are much more available.
    The purchase of G2 can be very cheap, since it does feel a tad un-modern, UI and chassi wise... (and may have CEL for P0420, ie low catalyst efficiency = deal time)
    #57 priumium, Jan 6, 2026
  18. rjparker
    10,503
    6,593
    Any high mile car is a risk and its never zero. All vehicles will need repairs as they age. Hybrids will be more expensive to repair due to the unique parts and mechanic skillsets needed.
  19. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Conclusion!
    I bought a 2015 Toyota Sienna LE FWD with 160k miles on it. It passed 3rd party PPI, and I also personally inspected for timing chain cover leak, head gasket leak, rust, all suspension parts front and back, sliding door recall, etc. So, I expect it to be reliable.
    Thank you for all your help!
    Does it meet my requirements?
    • Yes Budget $8.000 USD (in US market)
    • Yes 160k miles or less (=nearly 0% chance of head gasket or oil consumption in next 50k miles)
    • Yes Toyota but not Lexus
    • Better than yes! Hatchback/wagon
    • Yes Automatic climate control
    • Yes Backup camera
    • Yes IIHS rating is GOOD for both side/front.
  20. KitsuneVoss
    KitsuneVoss Member
    370
    55
    Virginia
    I like that 45 - 50 mpg and a Prius has a surprising amount of carry ability. My old 2009 Prius carried the bumper, fender, and everything else to repair body damage for the 2003 Prius.
