Gen 3 Prius Owners (2010–2015) – Important Action on Head Gasket & Hybrid System Failures
Discussion in 'Gen 3 Prius Main Forum' started by caprib, Jan 12, 2026 at 2:55 PM.
  1. bisco
    52,096
    it's one thing to replace inverters, and a whole nuther to replace engines. the inverter lawsuit was about safety
    BiomedO1 likes this.
  2. BiomedO1
    3,797
    1,975
    SacTown, Ca
    The court also ruled that Toyota must fix it, even if it's a salvaged car. In other words, If someone puts together a FrankenPrius - Toyota must fix that inverter too as long as the VIN meets the inverter suit parameters..........
  3. Mendel Leisk
    41,647
    There is a somewhat astounding statement in my North American 2010 Prius Owner’s Manual:
    I also got this letter from Toyota Canada:
    #23 Mendel Leisk, Jan 14, 2026 at 7:22 AM
  4. ChapmanF
    18,318
    The letter makes another appearance with a red circle around "While the majority of vehicles will not experience this condition", but no red circle around what condition the letter was about.
    The condition that particular letter was about is (just above the red circle that's there) "a sticking EGR valve due to excess carbon build-up" when that condition causes cold start-up misfiring.
    I don't actually know how many vehicles ever do experience that condition. There are occasional posts here where people have found their EGR valve stuck with carbon build-up, but it doesn't seem like a lot of them.
    Other conditions, like rutted ski jumps and clogged coolers, may be encountered more often. (And, of course, a notorious condition that can cause cold start-up misfiring is a damaged head gasket, whatever may have caused that.)
  5. BiomedO1
    3,797
    1,975
    SacTown, Ca
    Sorry should've of been clearer on my post; 300K miles not KM
    That quart for every 600 miles oil burn seems to be industry standard. I believe Subaru also uses that standard to determine engine replacement. Mind you that this consumption would empty your oil sump in less than 2500 miles - for those that don't check their oil levels be it 5K or 10K mile oil change intervals......
  6. BiomedO1
    3,797
    1,975
    SacTown, Ca
    There was a guy from the UK that had 200K+ miles on the clock on a very early gen4. Only did oil changes but didn't do coolant change. His EGR valve locked-up and had a slight hesitation on acceleration. The EGR error code was there the entire time he was parts swapping.o_O
    He did plugs, coils, throttle body clean-out x2; before jumping on to the forum to ask us.
    He posted pictures afterwards and the jammed valve looked more corrosion than carbon fouled.
    #26 BiomedO1, Jan 14, 2026 at 11:27 AM
