Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    1. The battery pack is made up of 28 modules that are all connected in series. So, the pack is only as good as the weakest module in the pack. (I am keeping this simple and not getting into the fact that inside each module is 6 cells that are wired in series.) As the battery pack charges and discharges, heat is generated due to the resistance of the battery cells. The modules in the center of the pack get hotter than the modules on the ends of the pack. This heat is what causes the battery modules to degrade over a long period of time. The center modules will degrade at a faster rate than the modules on the ends.
      Looking at the freeze frame data, two things stand out to me.
      1. Block #8 is much higher than any other block in the battery pack. It appears to me that one or both of the battery modules in that block were replaced by newer used modules by someone.
      2. There is a large voltage difference between the battery blocks.
      A health battery pack will have a voltage difference of 0.30 volts or less between the battery blocks. To me, it appears that this battery pack is not in very good condition.
      The freeze frame data shows that the battery pack was being discharged at 29.10 amps when the P0A80 trouble code occurred. That is a fairly low current draw. During hard acceleration or high regenerative braking, the current flow into or out of the battery can easily be 50 to 75 amps. As the current flow increases, the voltage difference between the battery blocks will also increase.
      I am guessing that most of the battery modules in the pack are the originals from when the car was built 10 or 11 years ago. So, those modules have 260k miles on them. That is a lot of miles for a battery. Batteries do not last forever.
      You could try to refurbish the battery pack by charging and discharging each module 3 to 5 times to determine the capacity of the modules and decide which ones are good enough to keep and buy used replacement modules to make a good battery pack. This will take you 3 to 4 weeks to do correctly. The refurbished battery may last a month or a year or two until the next P0A80 code occurs. It is a gamble.
      In my opinion, it is not worth the time and effort to refurbish a battery pack that has 260k miles on it. I would replace it with a new OEM battery (if you plan on keeping the car for 5 years or more) or purchase new cylindrical cell design battery (if you plan on keeping the car for 3 to 5 years) or a refurbished battery ( if you plan on keeping the car for 2 years or less).
    #21 Brian1954, Jan 26, 2026
    PriuSocal likes this.
  2. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Amazing info, I appreciate all that!
    I cleared the codes yesterday and so far the P0A80 has not come back on BUT i got a CEL again today and it was p219A "Air-Fuel Ratio Imbalance”. I Immediately thought Air/Fuel Sensor Bank 1 but googled it and a bunch of stuff comes up.
    Odd thing is the Oxygen sensors along with a new cat were replaced by Toyota less than 100 miles ago on the car. Prev owner gave me the receipts for it.
    Car appears to be running fine and no other code came up. I do however, have parts coming in from rockauto to do a maintenance on the things I thought would be important. like : Spark Plugs, Inner/Outer tie rods, air filter, cabon filter etc.
    Attached is the freeze frame data.
    P.S…If I need to make a separate thread for this just lmk
    #22 PriuSocal, Jan 28, 2026
  3. indel
    indel Member
    267
    87
    Northwest Indiana
    It would be best to use spark plugs purchased from the stealership. At least you will know they are genuine and not cheap knockoff.
  4. rjparker
    10,438
    6,545
    I would verify by inspection these parts were oem Toyota rather than aftermarket.
    I would have the maf sensor checked to ensure it was oem as most aftermarkets won't work properly but oems are expensive.
    I would also clean the maf sensor with proper cleaner and then clean the throttle body.
    A shop might verify injector operation.
  5. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    RockAuto is pretty solid and not know for selling knockoffs.
  6. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    The parts are 100% OEM, I have the receipts from the dealer where it was performed along with the cat converter there are also oxygen sensors in the list of approved repairs and charges.
    The MAF sensor does not appear to have been replaced but is OEM. I will def clean out the TB, I am just waiting on the parts which arrive at the end of the month (bummer, shipping with rockauto always takes long).
    I appreciate all your input guys, this place is def a world of resource and assistance to the needy lol.
  7. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    :confused::eek:o_O:barefoot:(n)
  8. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Update:
    I removed the EGR, cooler and Intake Manifold to check out their condition and they were gunked up. The small hole port inside the intake manifold on cylinder 1 was completely blocked and had hardened crust which I had to loosen with a pick and then clean with a wire brush thru. The EGR was dirty but not too bad, the PCV was also ok, the cooler was a bit gunked up as well where I couldbarely see traces of light thru the other end. I put it all in an ultrasonic cleaner and will check in the morning how they turned out.
    I am also thinking of doing an injector cleaning and was wondering if there is any specific method to removing them. Like remove a fuse to release pressure or something like that? Also, could I soak those in a ultrasonic bath as well or just do the cleaning the 12v connection and carb cleaner way?
    Here are some photos of the gunked up parts and partial clean up before the ultrasonic bath.
    Also, removed the plugs and found BOSCH Double Platinum R6 (cond below) which isnt such a good sign as OEM is NGK or Denso. I decided to replace those with OEM NGK ILKAR7B11 plugs.
    upload_2026-2-1_18-0-54.jpeg upload_2026-2-1_18-0-54.jpeg upload_2026-2-1_18-0-54.jpeg upload_2026-2-1_18-0-54.jpeg
  9. ASRDogman
    7,788
    3,975
    The cooler is really blocked. The intake manifold is really bad.
    PCV valve is $10, BEST to replace it, as bad as the blockage is. Just because you can shake it and
    it makes noise means it good.
    How BIG is your ultrasonic cleaner tank??? How many days will it take to clean each part?
    The INSIDE of the injectors might need cleaning, no really the outside. Spraying with the carbcleaner
    through a house with the 9v batter will work. Just make sure you BACK flush it to push any debrief back out.
  10. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Yeah it was bad, which in a weird way I am glad i found it this way as it could very well be the cause of the p0219A. The PCV was ok and makes noise when shaken but still opted for a new oem PCV. My Ultrasonic cleaner is 15L which fit the cooler, piping and EGR and still had room for more. I did 4 separate 30 min sessions at 120F (50C) and all the parts were left like new after the 3rd time, the 4th is just for good measure.
    As for the injectors, I have a small 2L jewelry cleaning Ultrasonic which I have cleaned all other injectors in and will do so with that and the small injector pulse machine to run current thru it while spraying cleaner into it. I just did not know if you are to relieve pressure on these priuses like other cars before removing the injectors. And if so, what is the process since these engines start then kill off after a few sec’s.
  11. indel
    indel Member
    267
    87
    Northwest Indiana
    Did you take pictures of the injector cleaning process?
  12. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I havent done that yet but can when I do.
  13. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Here are some photos of the ultrasonic cleaner I have used for the injectors, the injectors before and after the bath and the pulse machine to test injectors as well as pulse them while in the bath
    Before:
    After:
    IMG_3504.jpg IMG_3509.jpg IMG_3507.jpg IMG_3500.jpg IMG_3506.jpg IMG_3510.jpg IMG_3505.jpg
    #33 PriuSocal, Feb 2, 2026
  14. ASRDogman
    7,788
    3,975
    The OUTSIDE looks okay. Wonder what the inside looks like?
    Did you test spray them before the bath to see the pattern? Then afterward to see if it changed?
    Attach a hose to the output side, and to the nozzle of the carb cleaner then spray, creating pressure,
    and open and close the injector so you can clean the most important part...
  15. indel
    indel Member
    267
    87
    Northwest Indiana
    What is the liquid in the ultrasonic cleaner? And what do you mean by pulsing? How does the injector tester work?
  16. ChapmanF
    18,486
    In the car, the injector gets electrical power in small pulses, say 1 to 3 milliseconds on out of every 100 milliseconds at idle. An injector tester allows you to power it the same way out of the car.
  17. indel
    indel Member
    267
    87
    Northwest Indiana
    Interesting!
    It's hard to tell from the pictures, but it doesn't look like he is feeding any fuel to the injectors during pulse testing.
  18. ChapmanF
    18,486
    Nope—just wagging the valve pintle back and forth in a bath of solvent with ultrasonic waves.
    For bench testing, you do want something to supply a fluid to the injector under typical fuel-pump pressure, so you can measure the delivery per unit time into a graduated cylinder.
    The service we sent some PriusChat members' injectors to, back in the day, used a fluid made for the purpose, less hazardous than gasoline, but with known specific gravity and viscosity so the results could be interpreted.
  19. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    As @ChapmanF stated…he is correct on all the procedures for testing.
    I did test before and after and the pulse machine does this in 7 levels from low to constant mimicking somewhat a fuel pump current but I am sure not to its entirety. The pressure it will be exposed to is only that of the compressed air/liquid inside a can of carb/injector cleaner which is what I use. Its a fairly cheaper alternative BUT not to be compared to actual injector cleaners like the Autool etc. I have had success with this small one so Ill continue using it as my injectors are never really gunked up to pose a real issue cleaning with ultrasonic and pulse machine.
    What I used for the small ultrasonic machine is a ultrasonic general purpose powder from Amazon which mixes 1/4 teaspoon to 1 L.
  20. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Update: So far so good, car is super smooth and behaving well. No lights on either, hope all stays well.
    One thing off topic Id want to know is, I also changed out the coolant since the one in there looked orange rather than pink like the inverter coolant. When I drained and refilled to the top and put the car on maintenance mode, I read that you have to let the car idle until the fans came on then turn the heater on full blast and then AC full blast to allow all the air to get out of the system. Well, my fans took over 20 mins to kick on and the temp monitor on my scanner showed the temp fluctuation between 195-203 f. My scanned did not recognize them turning on though and showed them as Engine Fan OFF. Also, the coolant in the reservoir does not move from the FULL level nor does it show a flow or current. I am use to seeing a current/flow movement in the reservoirs on my old gen 2 but not sure if Gen3’s are suppose to show that as well. And the scanner did show the water pump RPMs from 3k-4300k so its is working.
    Good thing it, no overheating (online manual said normal temp for 10-15 prius is between 190-220 degrees f) or leaks.
    ANy input appreciated.
