Fuel leakage after fuel injector installation
Discussion in 'Gen 2 Prius Main Forum' started by Kenneth Steere, Jan 31, 2026.
  1. Kenneth Steere
    Kenneth Steere Junior Member
    26
    Richardson, Texas
    I recently did a replacement of the valve cover, O2 sensor, PVC valve, MAF sensor and fuel injectors. Everything worked out great and I have my original fuel mileage back.
    The problem is with the fuel injectors. I installed new Denso injectors for the best quality. Yes, I did remember to remove and install the new rubber o-rings that sit in the block. One thing though, The injector to my far right, was very difficult to get into the fuel supply manifold. What should I look for and are there any tricks to getting a tighter seal to eliminate any leaks?
    Thanks!
    Ken
  2. Tombukt2
    13,336
    2,401
    Ibte use the orange or pink colored o rings as many times as I do injectors hopefully once . The black o rings I replace thyre usually the uppers in the rail colored at pintle end I believe
    Kenneth Steere likes this.
  3. Tombukt2
    13,336
    2,401
    Lubing the rail o rings helps seat them in rail . Manifold end usually needs nada
  4. Kenneth Steere
    26
    Richardson, Texas
    I recall lubing the rail irings with a little motor oil. The first three(from my left to right) I could push into the rail by hand. But the one on the far right, I couldn't get it to go in by hand, so I aligned it with the rail and tightened down on it with the rail bolts. Those o-rings didn't come off the originals, but I didn't look up into the rail with a mirror.
  5. Kenneth Steere
    26
    Richardson, Texas
    So I believe what you're saying is that you replace the black o-rings that go into the rail. The o-rings that sit in the manifold are orange.
  6. Tombukt2
    13,336
    2,401
    Yes and I lubricate the o-rings that go into the rail the black ones I can't buy orange pink units . So they must be a better material or such . The replacements are black and from China Asia . So are the colored but they must be something to it . I never see the colored o rings fubar but black can be destroyed why material I'm guessing . The rail isn't crazy hot or such . Intake manifold maybe . Hence better quality o ring needed ?
  7. ChapmanF
    18,486
    No no no no no no no oh my goodness no don't do that.
    The ends that go in the fuel rail have O rings. Put those ends very carefully into the fuel rail first, lubing and twisting as needed.
    The bottom ends that sit in the cylinder head sit in simple grommets. It's easy to get those ends in, as you install the rail with the injectors' O-ring ends already carefully inserted into it.
    If you put the injectors in the cylinder head first and then try to get the fuel rail installed over them, you take a significant chance that the O-ring ends won't go into the rail right.
    If you then try cranking down on the fuel rail bolts thinking "this'll make 'em go in", you will, if you are lucky, only destroy some O rings, and if you are less lucky, you will destroy some injectors.
  8. Kenneth Steere
    26
    Richardson, Texas
    Chapman,
    I had a feeling this was the problem. I imagine the black o-ring got pushed back / damaged. I didn't understand why that one on the far right was so hard to get into the rail. I probably should inspect into it with a mirror... And the injectors for any damage... Then I have bank 11 in the big battery to fix lol. So many car repairs this month.
  9. Tombukt2
    13,336
    2,401
    If you're doing this then it's your first time or whatever because you're doing it this way you wiggle the rail side to side gently and you feel the rail slip down over the o-rings and you hear almost a squeak as rail seats. But the manual chap showed is the factory way . I'm guilty of the slide the rail down been doing it since EFI . Whoops. So far neva a leak
  10. ChapmanF
    18,486
    I'll do it the repair manual way every time, thankyouverymuch. I'm happy for you that you've succeeded with the just-crank-down-on-it approach, but I've had to help enough PriusChat posters who didn't get away with that to put me off suggesting it to anybody.
  11. Tombukt2
    13,336
    2,401
    We used to do that at repair shops on the BMW the m3s and all of that and the manual for those that's how they show them doing it I just thought that was the way it was done for the most part oh well.. it's not just whacking it down with a hammer or such . Gentle squishy rocking motion over lubed o rings .plop. can also set the injectors in rail flip it holding w fingers guide orange o rings into manifold . No matter. Just depends what I grabbed first or holding in my hand I guess.
  12. Kenneth Steere
    26
    Richardson, Texas
    I agree. You were right and that was the wrong way to install those. I replaced all four o-rings and most of them were damaged by doing it the wrong way. It's vapor free now and running great. You can see what happened to the original o-rings...
    Brian1954 likes this.
  13. ChapmanF
    18,486
