Kinda an odd problem about my 12V battery-cables
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Feb 1, 2026.
  1. priuslyfe
    priuslyfe Member
    264
    66
    thanks for the advice. HAD to walk through snow and ice today and thought maybe a better design is 1) battery was moved towards the front of the car ie. the normal place or 2) have a hot air vent from the engine towards the battery to at least mitigate the risk of freezing.
    also discovered that while walking through snow and ice, you often take twisted ankle steps, sometimes several in a row. a technique that seemed to work for me today is trying to use one foot as my flat foot and the other as my twist-foot, thus giving me some stability. I seemed to move marginally faster.
    the reason I don't use both as my flat-foot is that isnt a reasonable request. the reason for this is most people havent shoveled their sidewalks. i dont fault them as snowplows have covered them with 2ft of snow that has since become blocks of ice.
  2. Hayslayer
    Hayslayer Active Member
    466
    265
    The other end of that heavy cable is connected as the supply source for the underhood fuse box in the upper driverside of the engine compartment. There is no real slack to be had.
    You'll either need to get the crimp fitting removed, opened up and recrimped/soldered, OR do what some others have done and find a salvage yard that has a gen 2, cut that cable several inches back and crimp/splice the new piece of 'yard' cable onto yours. You don't want to make a loop in the wire, so you'll need to trim it as needed to get the correct original length. Otherwise it's just a pain to stuff it in place.
    priuslyfe likes this.
  3. ChapmanF
    18,563
    but, for that size wire and ampacity, is less common, and requires the heavy crimp tools they have at your neighborhood independent auto electric shoppe.
    I would probably try to get the last foot or so of that wire out of a salvage car, then take it to my neighborhood auto electric shoppe and have them make it up. They'd charge me less than the cost of a heavy-nice-person tool I might never use again.
  4. priuslyfe
    priuslyfe Member
    264
    66
    update:
    half accomplished. got about 6" off that cable which is firmly into the connector off a salvage car. much more length is hard to get as this cable becomes intertwined with others (the main?) that make pulling out more length to cut unfeasible. there is very little slack available at all at most 2-3 inches anyways. the cable basically makes a straight shot to the positive terminal with no room for modifications in length.
    think I'm gonna go with my idea of jamming the wires together. once you cut the cable you see there are about a dozen heavy duty steel wiress housed within the cable. i'm gonna need a breakaway to prevent this from happening again. ideally toyota should have had a white connector about a foot back that I could detach (however i guess ideally i should be living in a warmer place. always forget about this snow/ice in the middle of summer).
    too cold to finish this job today and light is starting to wane so yeah **** that.
    #24 priuslyfe, Feb 2, 2026
  5. rjparker
    10,536
    6,617
    If it goes to Ready with the short salvage battery wire jammed into the remaining vehicle harness it might work for a short time. A battery that could not staying charged before has no chance with a battery cable rigged in that manner.
    To properly repair using a salvage pigtail (piece) it should be crimped or lugged at the spliced connection.
    Crimp sleeve for wires (sized for wire diameter - typically 4-6 awg with automotive stranded)
    Lug Butt Splice (tighten with allen wrench and insulate)
    Amazon Butt Splices
    Once you splice the wires together, you still need to do something about your battery. It is likely weak and needs testing and replacement as indicated.
    Again, a good battery adequately charged won't freeze. How many of your neighbors are removing their battery every night? Some will attach a battery maintainer as I have when in Calgary during the winter. Many do nothing and still crank their high amp starters.
    A Prius 12v battery does not have to supply large currents and is in the cabin rather than under the hood. After achieving Ready, a weak battery can initially charge by drawing 60-80a from the hybrid system. A loose, "jammed" connection won't do it and is likely to fall out and short the battery. At best you can be stranded somewhere.
    #25 rjparker, Feb 2, 2026
    priuslyfe and Brian1954 like this.
  6. ChapmanF
    18,563
    The markings on that splice identify the not one but two distinct special tools and dies to be used to properly crimp it onto the wire.
    Your neighborhood independent auto electric shoppe already has the right tools and dies to do that, and when they're done you'll have a properly all-around-crimped and insulated connection, more reliable than the set-screw butt connectors, and they'll probably be done in a couple minutes and you'll be on your way for a nominal charge.
  7. priuslyfe
    priuslyfe Member
    264
    66
    OK. I've called A LOT of shops. first problem is due to the snowstorm almost all of them cannot work on it with any timeline soon. Most turned me down for fear of working on a hybrid.
    WILL THE ABOVE PICTURED CRIMPS BE ADEQUATE TO = a solder or hydraulic crimp re: transfer of voltage and codes P0A080 being dismissed?
    some are saying to replace entire cable (not feasible because its connected to the harness and stupid expensive). Just want to know how much something like this might cost to repair professionally as well. My local NAPA suggested I do it myself but kinda worried about not doing it correctly.
    #27 priuslyfe, Feb 4, 2026
  8. ChapmanF
    18,563
    Have I missed something? That seems to be the first mention in this thread of that code—which isn't really a code (real ones are five characters), but P0A08 and P0A80 are both real codes (meaning quite different things). One of them has nothing to do with the 12-volt electrical system.
    Is your car giving you either of those codes?
    Or are you worried about a prospect of seeing one of those codes after repairing the broken wire?
  9. priuslyfe
    priuslyfe Member
    264
    66
    No. The P0A codes you mentioned are only going on intermittently for some reason. By slightly manipulating/squeezing the crimped area the codes stopped. However I realize this is still a risk. Again now the cable wires sans black-housing is lightly and loosely twisted together underneath the black duct tape.
    maybe I'm not being clear in my question, basically the the NAPA part GRO #829219 seems to be the correct method and more secure method vs. hand-tool crimps above (home depot and others). However, the NAPA crimp would require going to the shop as i don't have the tools.
    The wires are crimped together very lightly and also with about 4 extra inches of slack in the black-cable to allow for a proper repair.
    IF it can be adequately repaired (no voltage issues, no codes) with the hand-tool options then although I don't prefer that method, at least I don't have to wait for a shop. Many shops turned me down (maybe too easy or too difficult to do correctly, not sure). but i'll have to wait a while do to everyone else having car issues because of the snowfall cold.
  10. rjparker
    10,536
    6,617
    Given it was running before the 12v wire broke off it would seem the hybrid battery code is secondary now even though it needs a solution in the next month or so.
    In your situation the easy and functional 12v splice is the Home Depot splicer that you tighten with an allen wrench or dcrewdriver. Then wrap with Self fusing tape or Scotch (3M) 33+ electrical tape, both available from Home Depot.
    You splice the piece on when its not connected to the 12v battery. No electrical concerns during that installation.
    You can get a auto shop to crimp the appropriate Napa crimp sleeve later.
    Around here Home Depot will deliver the same or next day if parts are in stock. However it would be much better to take your salvage yard piece in and verify fit.
    #30 rjparker, Feb 4, 2026
  11. priuslyfe
    priuslyfe Member
    264
    66
    but which is the preferred method to fix this cable? heavy-duty press/hydraulic OR allen-wrench screw fix
    for definitional terms if it seems confusing
    - by wire i mean the dozen or so wires underneath the black positive cable housing
    - by cable I mean the black housing only with the wires therein
    I am most concerned that if not done adequately (by me or by shop), that resistance will develop while I'm driving and cause a fire. I've been checking the cable (the area underneath the black duct tape) for heating up and so far that black cable scrimp (the area underneath the black duct tape) doesn't feel hot/emit heat.
    One issue is that you are supposed to keep the wires inside the cable housing relatively clean and not frayed for an ideal crimp job. wouldn't the pressure of allen-screws crush and fray the wires unevenly at the pressure points?
  12. ChapmanF
    18,563
    A good crimp with a proper tool will be superior to the screw-tightened splices.
    The screw splices will get the job done and not require relying on a shop or an expensive investment in tooling.
    Although it travels in a harness that may also contain other wires, what connects to that one large single-terminal connector is a single, large, wire. It is a stranded wire, made of a number of thinner copper strands twisted together, but that's still considered one wire.
    Make sure that whatever splicing you do involves only that one, large, stranded wire, and not any other wires you may find in its vicinity.
  13. rjparker
    10,536
    6,617
    The screw type splice is just fine and is made for the job. Heating is really not a concern because high amps only occur for a short time. Regardless all of those splice devices can take the amps.
    If this was a conventional 12v starter car, a screw type splicer might last two to five years. But this application is much less demanding.
    I suspect a friend or neighbor could help you do this quickly and easily. Its not that big of a deal.
  14. rjparker
    10,536
    6,617
    Your pic
    The thick black multi strand conductor on the right is the main 12v cable. The multiple strands ("wires") inside are built that way to make the cable flexible rather than one huge diameter conductor. All of those strands go into the splice device.
    Factory Setup
    The thin white wire is separate and is for remote monitoring of the battery voltage. It is not included in the splice. You already have it separated and taped together in the first pic above.
    Schematic for Tech Reference
    #34 rjparker, Feb 5, 2026
  15. Hayslayer
    466
    265
    After seeing your photo, which includes the (+) battery post, you need more help than just a splice. Quit jerry rigging and get it fixed correctly so you don't have to worry about breaking down. You're worried about a "correctly done splice" but have no worries about the (+) post? That terminal post clamp is available for about 15 bucks new. These are the things that drive me crazy when customers complain about something not working...........Crazy...............
    #35 Hayslayer, Feb 5, 2026
  16. ChapmanF
    18,563
    Yeah, I hadn't even noticed the hose-clamp ornament there. :)
    That clamp is probably too loose because somebody once overtightened the clamp bolt and bent the legs together.
    The clamp is a tinned copper stamping (not cast lead as many are), and can probably have the legs bent back out in a couple minutes by somebody good with a couple pairs of pliers.
  17. priuslyfe
    priuslyfe Member
    264
    66
    Yeah, I've been meaning to replace positive-terminal because its messed up. Luckily, my car always starts so I don't think about it much but next time I'm at the salvage yard I'm gonna try to replace all needed items.
    Coincidentally, many mechanics I called told me that I need to take this to a speciality hybrid-shop even after I sent some the above-posted pictures. I was led to believe there is very high-voltage going between through the positive-cable 12V to the hybrid-battery (which recharges the 12V). He said this based on the pictures above.
    I don't believe this is true but this is why I've been so reluctant to crimp it poorly, as I'm afraid I'll get the shock of my (soon to be over) life. Is this correct? that current is flowing between the 12V and the hybrid via the positive cable?
    One shop told me it would require an hour of labor and parts for crimping (plus waiting week). Their shop rate is $120hr plus I imagine parts would be another $30. Thats why I wanted to try another method I could do like the allen-wrench crimp.
    #37 priuslyfe, Feb 5, 2026
  18. Hayslayer
    466
    265
    There is no direct connection between the 12v battery and hybrid battery voltage systems. They are two distinct and separate systems.
    In a properly functioning car, once the 12v battery negative or positive post is disconnected, all wiring in the car is completely deenergized. Repairing that cable and post clamp is no different than any other car.
  19. rjparker
    10,536
    6,617
    They were wrong.
  20. PrimalPrius
    PrimalPrius Junior Member
    72
    America
    In case this helps, I have a (not prius exact, just a compact car 12V battery) in front of the passenger seat. The previous 12V, killed by my Prius, is still in the back, but disconnected (negative disconnected, IIRC). I have a pair of jumper cables that run to the battery in the front. This way I can easily disconnect the battery when I don't expect to drive the car soon.
    (This is not good because the computer loses programming every time and in the case of a rollover the battery carry handle, which I have tied to the seat bar, could easily come loose and the battery could make an already bad day a lot more memorable. I should probably secure the battery better to the seat frame, for example with a ratcheting cargo strap tightened around the battery and then tied of the seat frame.)
    A gen 2 can be made ready to drive with a very small 12V battery (in good condition) if necessary because the 12V powers on the electronics, but does not crank the engine. The tiniest lawn equipment battery can get it done.
    #40 PrimalPrius, Feb 7, 2026
