P0A0D but the interlock is pushed down
Discussion in 'Gen 2 Prius Technical Discussion' started by andy song, Feb 18, 2026.
  1. andy song
    andy song Junior Member
    The prius won't start. Only error code is P0A0D
    We checked continuity on the service plug, the interlock harness and to the plug from the car to the interlock, all has continuity
    So the only thing I can think of is that the wiring harness going to the ECU might be cut somewhere inside the car
    Here is my question. Has anyone jumped out the interlock pins at the ECU and which 2 pins are they?
  2. ChapmanF
    18,484
    The interlock circuit is a very simple series circuit that passes from an ECU pin, through cover interlock contacts in the inverter, back to the rear of the car, through the interlock contacts of the battery service plug, and to body ground.
    It is simple enough that finding the actual problem and fixing it ought to be a matter of minutes. I would consider defeating it by jumping at the ECU only as a very, very last resort.
    Brian1954 likes this.
  3. Tombukt2
    13,336
    2,401
    Does the car look like wires would be cut inside of it or otherwise be fubar . This is really a stretch . A Google question will bring you up a wiring diagram of the Interlock system I do believe on the Prius from the inverter to safety plug etc . Is the fuse good in the safety plug? Like chap said it's a pretty basic system
  4. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    Remove the orange safety interlock plug and reinstall it per the directions below.
    There are three steps to install the orange safely plug.
    1. Insert the plug into the socket.
    2. Flip the lever of the plug.
    3. Slide the lever with some force. This last step is sometimes not completed, which will cause the code.
    Here is a diagram from a Gen 2 Prius.
    #4 Brian1954, Feb 19, 2026
  5. Tombukt2
    13,336
    2,401
    Make sure the fuse is good in that plug. Continuity beep. Slam it down last step finger hurts click. You can check with meter to see the connection is made I think it's blk and white wire
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,083
    1,995
    NJ-USA
    What's the (recent) repair history on this car? Usually there's an interlock code after someone was working on something.
    The hybrid control ecu supplies a (low current) voltage signal that loops through the HV safety disconnect plug, then goes through connections in the inverter cover to ground (inside the inverter).
    So, when everything is connected correctly, the interlock circuit should be at 0V, when something is "open", it will read (some) voltage. (I don't know if it's 5V, 12V, or what) & will set the code.
    You can test at the white 2 pin connector that goes to the disconnect plug socket.
