Prius (2nd gen) FOB battery: is CR2025 compatible w/ CR2032
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusrust, Feb 23, 2026.
  1. priusrust
    priusrust Member
    225
    85
    MA
    Hello,
    Being lazy, I had the battery place pop a new battery in my FOB. Worked for a while, then did not open doors. Decided to replace shell as old is worn. Opening FOB up, I noticed it was a CR2025, and not the recommended CR2032 . I understand the size is slightly different. Could this CR2025 battery have affected operation? (FOB unable to open doors)
    Thanks!
    52,399
    same voltage, but your not getting solid contact. didn't hurt anything
    Brian1954, mingc and priusrust like this.
  3. JC91006
    JC91006 Senior Member
    16,829
    8,601
    it's a thinner battery, so if the contact is not good, it would affect the operation
    Brian1954 and priusrust like this.
  4. bisco
    52,399
    did the battery place charge you for their mistake?
  5. PriusCamper
    PriusCamper Senior Member
    13,078
    5,306
    Pacific Northwest, USA
    Sounds like the battery they changed is thicker and forcing it in there could of damaged it and now they might have to replace it. I'd go back and talk to the manager about their policy for damaging a customers FOB. Businesses charge way more than $2 cost of battery for this "service" and now its time for them to lose money replacing the FOB they broke.
    priusrust likes this.
  6. priusrust
    priusrust Member
    225
    85
    MA
    I have yet to go back (blizzard today). I had a hard time getting battery out...then I saw it was a CR2025. I'll try the correct battery, hopefully it will work. At any rate, I'll let them know either way. ...2032 is marked right on the cover!
  7. jdenenberg
    jdenenberg EE Professor
    3,953
    1,950
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Besides being thinner the CR2025 has less energy capacity than the CR2032 and will mot last as long.
    JeffD
  8. mingc
    mingc Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    CR2025 and CR2032 are the same diameter, 20mm, but the CR2025 is 2.5mm thick compared to the CR2032 which is 3.2mm thick. As you can see, the dimensions are reflected in the battery's number. Both are 3V and the thinner battery probably did no harm to the fob.
    #8 mingc, Feb 23, 2026
  9. priusrust
    priusrust Member
    225
    85
    MA
    (I think you meant CR2032) So it is conceivable while the CR2025 did no harm, it may have caused a malfunction by being a 1mm less thick (?) as in perhaps it did not contact (reliably) the contacts it was intended to. We'll see. Thanks
    mingc likes this.
  10. pasadena_commut
    pasadena_commut Senior Member
    2,862
    853
    Southern California
    CR2032 is the more common size for key fobs, and it is hard to imagine that any battery shop wouldn't have those on hand. CR2025 are typically used in watches and other locations where shaving off .8mm is worth the loss of capacity. The shop probably just screwed up, and they really should just would swap it for you for free.
    mingc, fuzzy1 and priusrust like this.
  11. mingc
    mingc Member
    Portland, OR
    2023 Prius
    XLE AWD-e
    Yeah, numeral dyslexia.
  12. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Nope as the following posts have noted the correct battery size is CR2032. The CR2025 that the OP received was thinner. So while it would not have caused damage (they are both 3 V), there could be problems with poor contact causing the fob to intermittently lose power.
    priusrust and Brian1954 like this.
