2006 Prius A/C Temperature Stuck?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daveyedgar, Dec 5, 2025.
  1. daveyedgar
    daveyedgar Junior Member
    Tampa
    Yes this is in florida with us gauges
    I have the shop manual and it states:
    The refrigeration system functions normally Gauge reading:
    Low-pressure side: 0.15 to 0.25 MPa (1.5 to 2.5 kgf/cm2)
    High-pressure side: 1.37 to 1.57 MPa (14 to 16 kgf/cm2)
    I tried using an online converter to psi but it didn't make sense.
    I can't find anywhere what the readings should be in psi.
  2. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    Conversion is pretty straight forward.
    Low-pressure side: 0.15 to 0.25 MPa (22 to 36 PSI)
    High-pressure side: 1.37 to 1.57 MPa (199 to 228 PSI)
    #22 dolj, Feb 24, 2026
    Brian1954 likes this.
  3. Tombukt2
    13,336
    2,401
    You're looking 36 to 40 on the low side the blue the hi I rarely connect much anymore .
  4. daveyedgar
    Tampa
    Thanks for the info. The online converter on google gave me strange conversions. Glad you settled that for me.
    #24 daveyedgar, Feb 24, 2026
  5. saneesh8
    saneesh8 Member
    210
    52
    Allen, TX
    As you know, proper method is to evacuate and refill with proper weight.
    Filling it by PSI is not accurate. R-134a chart can show approximate PSI values with humidity and temperature etc.
  6. ChapmanF
    18,484
    Seems to work ok for me; what happened for you?
  7. daveyedgar
    Tampa
    I guess I should have used google
  8. dolj
    dolj Senior Member
    8,546
    4,341
    Or ... chosen MegaPascals, not milliPascals.
  9. ChapmanF
    18,484
    Ah. So daveyedgar gave the prompt "mpa to psi converter", all in lower case, and Google honored the difference between m for milli and M for mega. As it should, I'd say.
    But that means it is not ignoring case, so maybe it should kinda warn you about that somehow.
    It would be easy in this example, given that the abbreviation for pascals is Pa, so it could say something like "I saw pa, did you mean Pa for pascals?".
  10. dolj
    dolj Senior Member
    8,546
    4,341
    If you don't understand that case is important. Having presented wth that question, you also might not pickup what the converter is subtly trying to tell you. Even then, you're focused on the question asked and will most probably not then apply that to evaluating whether you meant m or M.
  11. Tombukt2
    13,336
    2,401
    I know by looking at needle on gauge. They'll be at certain clock positions. My eyes go across gauge set see the aporox clock Positions and move on to the rest of it. Gas do look differently on gauges according to outdoor temps and time running. It'll take about ten minutes to stabilize the cabin . That's wen you want to read gauges.
