P0560 troubleshooting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DanHoug, Feb 25, 2026.
  1. Tombukt2
    13,336
    2,401
    It'll be in the gray red and green electrical publication manual has allplugs pin outs and wiring diagrams a separate book . Have it sitting close by
  2. ChapmanF
    18,484
    My own lazy inclination would be to avoid doing any more work as long as it's working. Now you've got a nice spare '07 inverter assembly in case you ever need it.
  3. Tombukt2
    13,336
    2,401
    If it's working leave it alone both those gen2 inverters are very Stout . They're usually not getting changed because they're bad they getting changed for DC to DC on bottom mostly I'd bet.
  4. DanHoug
    DanHoug Junior Member
    northern Minnesota
    thanks for the advice, will leave the 05 inverter in place. as a reward for finally getting this car going i pulled the plugs to see if it might need new ones... 0.062" gap!! 200k miles on it, felt like they'd never been out as i had to work them back and forth along with penetrating oil in the bore. they all came without damage but were very stubborn. NGK BKR5EIX-11 ... i don't THINK that is OE so they must've been changed once. check out the gap in the attached photo!
  5. Tombukt2
    13,336
    2,401
    They came in at 044 somewhere around that so they were 20 thou out
  6. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    The plugs specified in the manual are:
    • DENSO SK16R11
    • NGK --- IFR5A11
    I believe the Denso might have be superseded, I'm not sure about the NGK.
