Rear ABS sensor fault after replacing wheel hub assembly
Discussion in 'Gen 3 Prius Technical Discussion' started by tonymats, Feb 27, 2026.
  1. tonymats
    tonymats Junior Member
    New York NY
    I just replaced the rear right wheel hub on my 2013 Prius. After turning the car on, I immediately see this fault code:
    ABS
    Part # suffix: 47214
    Calibration ID: F152647214
    Fault codes:
    C1466 Rear Speed Sensor RH Circuit
    I do not see any damage in the wiring that plugs into the sensor. Plugging out and back in didn't help either.
    Since the sensor itself is embedded in the wheel hub, would the most likely explanation that the wheel hub is defective?
    It's a Mevotech part ordered from RockAuto. The only thing that throws me off is that the fault code refers to the Circuit, not to the sensor itself.
  2. Tombukt2
    13,367
    2,405
    Yes I would think it's a bad hub sensor embedded in the hub which would be part of the circuit if completed and functioning. Try a trq from Amazon I had good luck so far not had to redo one yet I'm on cars heading to 5 and 600K . In for the long game
  3. ChapmanF
    18,522
    PSA: the car's brake/skid ECU has a sensor check test mode that the repair manual always advises to use after any work like replacing a hub. After completing the test mode procedure, all of the sensors have been confirmed working, to a more stringent standard than normal operation. This is worth doing even when using shiny new Toyota parts, just to make sure there won't be later surprises and customer returns.
  4. Tombukt2
    13,367
    2,405
    Do you have tech stream ? Then you can bring up the menu chap is talking about and see if that will tell ya much . With what's going on in manufacturing right now I'm banking on just a part that got thru that shouldn't have
  5. ChapmanF
    18,522
    Don't even need Techstream to get into the sensor check test mode; a jumper'll do it, as described at the link I gave.
  6. Mendel Leisk
    41,880
    @ChapmanF what does TS stand for, quote from your link:
    Brian1954 likes this.
  7. ChapmanF
    18,522
    The mnemonics that manufacturers assign to pins aren't always easy to guess meanings for. There are various "without using the Techstream" procedures detailed in the repair manual that involve playing with a jumper between the Tc and CG pins, or between the Ts and CG pins, of the diagnostic connector. CG is easily guessable as chassis ground, which is pin 4.
    Your guess is as good as mine what Tc or Ts stand for. Tc at least has been pin 13 all along, while Ts went from being one pin in the gen 1 Prius to a different pin in later gens.
  8. Tombukt2
    13,367
    2,405
    Yeah back in the '80s it was like te and E1 under the little square box under the hood there's always been funny letter designations for test ports . Then obd came into play .
  9. tonymats
    New York NY
    I ordered another hub assembly from TRQ as @Tombukt2 suggested, but the fault code is still there. I'll try to figure out how to do the sensor check, trying to find the repair manual. Haynes has one for 2001-2012 years, is it likely to work for my 2013? I guess it should as both 2012 and 2013 are Gen 3.
    If the embedded hub sensor is not the issue, I guess I could have damaged the plug when disconnecting it. Doesn't seem obvious how to replace it (if they even sell it), the wiring just disappears into the frame.
  10. ASRDogman
    ASRDogman Senior Member
    7,799
    3,978
    Huge mistake!
    trq is crap! You might have gotten 4000 miles out of them. I went through that.
    Decades ago they were good, but not any longer.
    OEM, Timken, Moog(made in America hubs).
    How much time and pain have you wasted with cheap hubs? And still have problems.
    In theory, duralast hubs from autozone are made by Moog.
    Why did you replace the hubs? Were they noisy, or abs issue?
    The plastic holding the connector to the hub is tricky.
  11. tonymats
    New York NY
    I replaced the hub because it was humming, there were no ABS errors before. I replaced the other 3 with Mevotech parts a year ago without any issues. I don't mind paying a bit more for a US made part, but having gone through two hubs, I am getting pessimistic if that would help.
    I'm thinking I'll swap the other rear hub from left to right, then I'll know for sure if the error code changes from RH to LH.
  12. ASRDogman
    7,799
    3,978
    Okay, and you used trq? Swoping them might move the error code.
    Make sure you clear the code before swoping them. If the error code moved,
    then you know for sure it's the hub.
    You "might" get lucky and it won't throw a code. There could be a metal fragment caught
    in the sensor. Which "might" get knocked free since it's going the opposite direction.
    If that is the issue, it will probably come back eventually.
  13. Tombukt2
    13,367
    2,405
    I've got a 100k now on some trq hub and 70K.o some real cheap junk on purpose just to see if I could beat em out any kind of fast or so far and I can be hard on them in inclement weather sliding from ice to dry pavement car rights itself very abruptly brought to damage suspension parts and hubs. Still nothing ... Set of gen3 hubs loaded tra laying on carport floor been sitting 3 years probably never get installed . Move em over to Gen 2 hubs I guess .
  14. Tombukt2
    13,367
    2,405
    If there's a change and you have 2001 to 12 and yer 13 welp maybe . I don't have the manuals to look up to see if any of that changed some other folks have all that literature for the Gen 3 I do not buttheyre are changes rt around 13.
  15. rjparker
    10,484
    6,572
    I would get a copy of Techstream and a mini-vci to actually narrow down which c1466 code you have even though the hub is typically the "normal" problem.
    Your situation may not be "normal" because you changed your oem hub for noise and then got the code. If a mechanic did this, you would probably blame the mechanic.
    Or you could do the blink code jumper trick Chapman has been asking you to do.
    While the hub failure is typical, many have damaged their harness in the past. Some in ways which were not visually obvious but were diagnosed with a meter. A few shade tree wrenches with good soldering skills have achieved a "no parts required" repair on a bad harness.
  16. ChapmanF
    18,522
    The blink code jumper "trick" doesn't give you INF codes, though, so you'd still be wondering which subcase of C1466 you've got.
  17. tonymats
    New York NY
    So I swapped the rear hubs and no change to the code. So it's definitely a damaged harness. Already ordered a replacement from eBay. Now I just need to find the plug on the interior. And probably have to cut through the wheel well somehow to get the new wire through... Arrgh! Is soldering really the best option here?
  18. rjparker
    10,484
    6,572
    Here is the thing: It is 99% in the exposed part of the harness that flexes near the wheel. That part of the harness is two wire non-shielded - an easy solder job for any teenager who ever used a pencil soldering iron. For me this would be a ten minute job but it would be important to first find the break and simply repair it - eg no parts required.
    In the diagram above, the hub connector pins are labeled 2 and 1 vertically next to the sensor.
    Pic from my v years ago when changing the xm satellite antenna preamp.
    The cable from the hub enters the cabin as shown. The connector zS1 is above this near the hv battery, at least in a v. It takes some panel removals to get to it but that's what you need to do to replace the 2 wire harness from there to the hub.
  19. ASRDogman
    7,799
    3,978
    Ebay???? :eek::confused:
    It's likely not that difficult to replace. Take the plastic wheel well cover off, you'll see where the wire goes
    into the body, the connector could be on the outside. If not, you'll be able to see where it is and what you
    need to remove inside to get to it.
  20. ChapmanF
    18,522
    They had to install it at the factory—they didn't build the wheel well around it. :)
    You'll find it goes through a rubber grommet that fits in a hole in the sheet metal. Pop the grommet out of the hole, and the hole's big enough for the connector end to pass through. Easy peasy.
