DashCam Battery Thoughts?
Discussion in 'Fred's House of Pancakes' started by VelvetFoot, Feb 26, 2026 at 7:54 AM.
  1. PriusCamper
    PriusCamper Senior Member
    12,991
    5,284
    Pacific Northwest, USA
    $279? Are you crazy? You haven't even documented the voltage loss to your 12volt using your dash cam and now you're you gonna get scammed out of $300 and have a whole bunch of loose wires cluttering up the inside of your car forevermore?
    Please take a more professional approach where you measure how many amp-hours you're losing during your longest security mode sessions and then hardwire in a $20 battery into the car in a way that you don't have wires and boxes visible.
    #21 PriusCamper, Feb 26, 2026 at 9:54 PM
  2. PriusCamper
    12,991
    5,284
    Trying to make sense of it all... I've never in my life owned a car that wasn't at least 6 years old... It's a whole different culture, a whole different lifestyle where people lose a huge amount in depreciation value of their vehicle soon as they drive it around for a couple years.
    Whereas Gen2 and Gen3 Prius are still holding their value for a decade or more if you keep the mileage down. Used to be Prius owners were super frugal on here.
  3. VelvetFoot
    VelvetFoot Active Member
    1,146
    452
    New York State
    2026 Prius
  4. ETC(SS)
    7,322
    One other thought.
    I just looked at my company jeep let and discovered (to my disappointment) that Priuses are not the only one with idiotic 12vd management issues.
    If I were going to buy a pass-through 12vdc charger, I'd make it a jump-pack - since it seems that it would be idiotic to drive a G5 Prius without one anyway.
    This problem is not unique to Priuses, BTW.
    A swift confirmation from the googles confirms my suspicion that the people who design these devices thought this out ahead of time.
    A stand-out jump pack can be had for about $100.
    They're like EDC firearms.
    You don't have to overspend or get one with the highest capacity - but you're going to get the cheapest one out there you are probably better off without getting one at all.
    My answer from the Googles after asking about jump packs with pass through charging: (TIFWIW)
    .......Yes, several modern lithium jump packs feature USB-C ports that support pass-through charging, allowing them to act as a power bank while being recharged. Key models often cited for this capability and fast charging include the Noco Boost series (e.g., GB40), Imazing jump starters, and Gooloo (GP3000).
  5. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    Good to know about those examples, although AI generated, apparently, I don't know if I'd trust it. Perhaps I have Luddite tendencies. Worthwhile investigating.
    In this case, capacity is king, however still the question of how you're going to carry it, so to speak, and whether or not it will burn.
    Just a nicety for me, as I said.
  6. ETC(SS)
    7,322
    That's why I disclosed that they were AI generated. ;)
    Using a jump pack as a battery bank with pass through charging was my own perhaps even original thought for your need - which is why humans still have one leg up on Robbie.
    To quote a person who is unencumbered by intelligence, artificial or otherwise....
    HUMANS can still "imagine what can be, unburdened by what has been."
  7. Prodigyplace
    12,633
    11,810
    Central Virginia
    I am not sure what you consider huge. I bought my 2017 Prius Two in late 2016.In late 2024 dor $23K, Almost 7 tears and over 50K miles later it was totalled & I got $18K from the insurance company. To me, that is not a lot of depreciation.
  8. ETC(SS)
    7,322
    I do not worry about appreciation or depreciation with cars because they're not an 'investment' but rather they are an expense to be managed according to ones own needs and budget.
    People with large disposable incomes sometimes eat at McDonalds.
    People deeply in debt sometimes eat at Ruth Chris.
    Priuses are hardly what you would call up-scale sheet medal, so it would be hard to argue against using one for commuting.....unless you park one next to a Corolla. ;)
    AS ALWAYS.....
    YMMV.
  9. Leadfoot J. McCoalroller
    8,133
    7,632
    Pennsylvania
    2018 Prius c
    Safety first, pay enough that you are confident that the battery won't burst or catch fire when the cabin is 140°F (or however hot it gets where you live)
    Mitigation strategies include mounting it under a seat, but there are other ways as well.
    I've read many good things about the Blackvue B-130 battery. Looks like it will support any 12v camera, not just the Blackvue-branded ones.
    Also pay attention to charging times and set your expectations appropriately. A large battery may sound great for keeping your cameras operating several days in a row, but may then require a solid hour of recharging while you drive. Not a good fit if (for example) you're going to take two fifteen minute drives per week and expect recordings of the rest of the week.
    So, make sure the advertised performance actually fits your usage pattern.
    We decided against adding the complication of power for recording while parked. The original value proposition of 'automatic 4k movies of every time we drive' was good enough.
    Trollbait and VelvetFoot like this.
  10. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    As I originally said, it'd be a nicety.
    I hear Blackvue is big $.
    On a previous car the hardwire feed could be set to turn off at a certain voltage.
    Then, there's low bit rate recording, or even the motion or 'jostling' detection, for battery savings.
    I had a switch that I put in to turn off the constant feed wire, but I'd forget.
    Never killed the battery.
    This was all before the Prius 12v battery paranoia introduced to me by @Gokhan :).
    Enter, bluetooth monitoring.
    Also, I suppose you don't want to overtax the usb-c or even the lighter ports either if you use that to charge the battery.
    Then, there's cold weather operation.
    A purpose-designed battery would probably take all that into consideration.
    Throw in bluetooth for good measure.
    If usage patterns would work out, it might even be good for the battery to get some exercise.
    I'm not sure there's a cheap foolproof way.
    With my luck, I'd immediately fry the capacitor thingy, lol.
    Gokhan likes this.
  11. Leadfoot J. McCoalroller
    8,133
    7,632
    Pennsylvania
    2018 Prius c
    Our Blackvue cameras were not cheap. Happy to report that they are excellent- one now has about 7 years of flawless performance behind it. I appreciate their no-battery design, allowing them to remain safe at high summer temperatures for many years. And the real Sony 4k sensors deliver fantastic pictures the whole time.
    I would hope that the same quality shows up in their parking coverage batteries, but like I said I can't directly vouch for them.
    Low voltage cutoff circuits can be bought for cheap on Amazon or eBay. I got some for an unrelated DC power project and it worked fine.
    Good luck however you go!
  12. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    Thanks.
    I had a couple of Viofo A119's in a previous car and liked them a lot.
    I went with the screen less Viofo VS-1's in the Prius. They kind of dangle, with lens farther from windshield and with Prius' raked glass, it take in more plastic.
    4k was not something I was going to go with, but perhaps I should have.
    Hell, I bought a couple of 512gB cards. :)
  13. PriusCamper
    12,991
    5,284
    What did you think of the Wolfbox when you were researching? I remember when they first came out with those and there was lots of competitors and a few years later nobody offered one as good as them and they took over the market. But maybe that's changed in the past couple of years?
  14. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    Not interested in a mirror.
  15. PriusCamper
    12,991
    5,284
    It's great for when people are blasting you from behind with high beams on...
  16. VelvetFoot
    1,146
    452
    New York State
    2026 Prius
    That's why I like the manual dimming mirror. I feel the auto 'anti-dazzle' variety sucks.
  17. Prodigyplace
    12,633
    11,810
    Central Virginia
    I personally like the anti-dazzle mirror on my 2025 Camry.
