Noise coming from under the hood intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jotowers, Mar 4, 2026 at 10:22 AM.
  1. Jotowers
    Jotowers New Member
    Fresno CA
    2009 w/ 222k miles
    What is this sound? I only hear it occasionally. It comes from the driver's side. It happens while driving and while in park. It will stop once I shut the car off
    52,337
    What sound?
    Maybe a pump
  3. ChapmanF
    18,486
    There are several sounds that can fit that description. If you can post a recording, that helps, or you can search for other similar threads where other people posted recordings, and notice which of those sound like yours.
  4. Prodigyplace
    12,654
    11,825
    Central Virginia
    The gasoline engine? LOL
    Jotowers likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,006
    5,287
    Pacific Northwest, USA
    What is the sound that OP is not going to describe? Lol... I think its a trick question!
    If a car makes a sound and the person who is hearing the sound doesn't describe what the sound actually sounds like to people on PriusChat, does the car really make a sound?
  6. ChapmanF
    18,486
    Well, the OP described when it happens, which I guess is the easier part to put in words, without trying to do the "well, it's kind of screechy, with a little bit of whong-ong-ong-ong, only not as buzzy as that" kind of thing.
    If there were only one gen 2 Prius sound that could happen at the times described, that might be enough to ID it.
    Trouble is, there's more than one. So posting a recording is more helpful, or listening to the recordings from other people's older threads to pick out which one it sounds like.
  7. PriusCamper
    13,006
    5,287
    Now this is what I'm looking for... Lol... Not like it helps that much, but is always kind of fun. Way better than when they post a video and you can't hear it at all.
  8. Jotowers
    Jotowers New Member
    Fresno CA
    Lol I'm a new member so it won't let me post a link and I can't figure out how to add the video I have
    PriusCamper likes this.
  9. Jotowers
    Jotowers New Member
    Fresno CA
    I'm trying to contribute to be able to gain access to add links
  10. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    I suspect the OP (Jotowers) intended to post a link to his video, but then, because he is a new user with less than 5 posts, found he couldn't.
    So, OP, make 5 comments on some other threads, then come back and post your link.
    Also note, that with less than 5 posts, each of your new post have to wait for a moderator to approve them. Another reason to get you post count up to over 5.
    Prodigyplace and Brian1954 like this.
  11. JC91006
    JC91006 Senior Member
    16,825
    8,600
    If there is a continuous sound coming from the driver's side, I would have to guess it's a bad 3 way valve. This sound would be described by many as a stuck cd trying to eject over and over and over.
  12. dolj
    dolj Senior Member
    8,546
    4,341
    ... or, if you're old enough, like a broken floppy disk drive unable to find the track it is seeking.
    Prodigyplace likes this.
  13. Jotowers
    Jotowers New Member
    Fresno CA
    Yes that's exactly what it sounds like! It only comes on occasionally and no check engine light yet. Is this something I need to address immediately?
  14. Jotowers
    Jotowers New Member
    Fresno CA
    I want to post my link but it say I need to post 3 more times not just comment on others posts
  15. Jotowers
    Jotowers New Member
    Fresno CA
    https:// photos.app.goo.gl/wP5ygnkTNNoUmGWe7
  16. PriusCamper
    13,006
    5,287
    Looks like you made more than 5 comments and they're approved so your free to post links... I watched your Google Photos video but it wasn't a noise I could hear. Can you describe the noise?
    #16 PriusCamper, Mar 5, 2026 at 2:45 PM
  17. JC91006
    16,825
    8,600
    This failure should produce a check engine light, as the emissions system is affected. This is not anything that's an emergency, your car will drive fine. You might have an issue of not getting HEAT when you want it, but if you're in Fresno CA, it probably wouldn't be an issue.
    You should confirm the failure, it should produce code P1121
  18. pasadena_commut
    pasadena_commut Senior Member
    2,789
    832
    Southern California
    Eventually. It can make noise for a long time before that happens.
  19. JC91006
    16,825
    8,600
    yes that is correct, that sound is not necessarily a failure yet. It's just getting there.......
  20. ChapmanF
    18,486
    You can see this recent post for the reason the condition that produces a floppy-disk hunting sound is a different failure that doesn't match the detection condition for P1121. You won't see P1121 unless the valve eventually also fails in the way P1121 detects.
    If you can stand there and listen to the hunting failure with your own ears, it isn't necessary to wait for any code to tell you what you're hearing.
    Brian1954 likes this.
