2016 Prius Check Engine Light – P0456 Code
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Alyssa L, Feb 25, 2026.
  1. Alyssa L
    Alyssa L New Member
    Los Angeles
    Hi everyone,
    My 2016 Prius just showed a check engine light. The car seems to run fine.
    I scanned it with my Autel MK808Z and got P0456 (EVAP small leak detected).
    Has anyone dealt with this before?
    Should I start with the gas cap or check something else first?
    Any advice would be appreciated. Thanks!
  2. BiomedO1
    4,047
    2,132
    SacTown, Ca
    Yep; start with the gas cap and inspect the lip of the fill tube. Any nicks or cut to the gas cap gasket or tube lip can cause a leak.
    Good Luck...
  3. Alyssa L
    Alyssa L New Member
    Los Angeles
    Thank you so much!
  4. BiomedO1
    4,047
    2,132
    SacTown, Ca
    Lamp should extinguish itself after it passes a couple of self-test; otherwise it will remain on. Check your registration to see when it requires a smog test - that's the time frame you have to get it sorted. The car will drive fine with that lamp lit, unless you get other problems. Since that lamp is already lit; if another problem crops up you won't know about it - since the trouble lamp is already lit.
    Good Luck..
  5. Alyssa L
    Alyssa L New Member
    Los Angeles
    Thanks for the earlier suggestions. I checked the EVAP system more carefully and found that one of the small hoses near the charcoal canister was loose.
    After reconnecting it properly and clearing the code, I drove the car for a while and the P0456 hasn’t returned. The check engine light is gone now.
    Looks like it was just a loose EVAP hose causing the small leak. Thanks again for the help!
    bisco and BiomedO1 like this.
  6. bisco
    52,319
