Capacitor issues, other than the MFD?
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Mar 6, 2026 at 1:13 AM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,787
    832
    Southern California
    It is common for the MFD to fail because an electrolytic capacitor used by Toyota wasn't quite the right capacity and over time it degrades to the point where it cannot do its job. That was a design failure, even though it took a few years to show up, it wasn't really the typical sort of capacitor age failure.
    These cars are getting up there in age, mine will be 20 next year, and at that age it is fairly common for this type of capacitor to fail. They swell, leak, or just get so far out of spec that they cannot do their job anymore. This can cause big problems in a car if it happens in the ECM. However, it seems not to be common in the 2nd Gen Prius, at least yet, as I have no recollection of any posts here describing an ECM failure from capacitors aging out. I have never opened a Prius ECM. Did Toyota just use really high quality electrolytic capacitors (in which case they will fail eventually, it will just take longer) or did they employ solid state capacitors, which last much much longer than the electrolytic ones?
  2. ChapmanF
    18,484
    I'd have to say the only gen 2 capacitor-related issues I've read about here have been in the Combination Meter. I just haven't heard of any others. To the point of the thread title, I haven't heard of any in the MFD, either.
  3. Tombukt2
    13,336
    2,401
    Very thin layer of protection on top of dash heat gets crazy under that thin layer of black abs or pvc and it's black too . Fire hot
  4. pasadena_commut
    2,787
    832
    Southern California
    The MFD is definitely going to be hotter, but the ECM is tucked up under the dash too. However, it is a little lower and is in a metal box which is bolted to other metal which might keep it cool by diverting heat down into the frame of the car
    I looked for a picture of a 2nd generation Prius ECM board on Google and didn't find a single one. The only failures I have seen referenced were of the "external short to ground kills ECM" variety.
  5. Tombukt2
    13,336
    2,401
    At times yes but I noticed when my car is parked the dash eyebrow display is taking a beating the forward edge of mfd is shaded . The plastic top over display is upside down . So the back side of the business end of the display is getting beat by heat . But it's all taking it pretty good.
  6. VelvetFoot
    VelvetFoot Active Member
    1,162
    459
    New York State
    2026 Prius
    Does this generation use a capacitor sub battery like the Gen5, to keep safety stuff alive if the 12v battery fails?
    There have been some problems with the Gen5's. Expensive.
  7. ChapmanF
    18,484
    Gen 2 does have a capacitor module, just to supply backup power to the brake controls. The gen 5 one does more.
  8. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    Still, if Gen2's don't have much of a problem, maybe it was just a bad batch of caps for Gen5, hopefully.
  9. pasadena_commut
    2,787
    832
    Southern California
    Maybe the Gen 5 issue is somehow related to its high parasitic draw issues? If that box of caps is being charged and discharged too often it could cause them to fail sooner. Just speculating, I have no data to support this.
    The capacitor plague (huge number of defective electrolytic capacitors) came to an end a year or two before the 2nd generation Prius did. Now admittedly most of those failed caps were not from first tier manufacturers, but if a particular generation Prius was going to have capacitor problems it would be more likely the 2nd than the 5th. Toyota seems to have avoided this problem by sticking with first tier Japanese made capacitors for the 2nd generation. I suspect Toyota remains to this day very picky about whose capacitors they use. Although I bet they have phased out electrolytic capacitors everywhere they could in favor of solid capacitors. For instance, in this disassembly of a 5th gen inverter
    I did not see a single traditional electrolytic capacitor (the sort that have a pressure release on top, and are noted for bulging and leaking). There were a lot of capacitors which look (at this low video resolution) like the solid ones used on Gigabyte's ultra durable motherboards (and by other manufacturers):
    https://www.gigabyte.com/webpage/8/article_02_all_solid.htm
  10. Tombukt2
    13,336
    2,401
    That looks alot cheaper compared to gen2 hitachi innards. This things got no copper he he .
