AC Condenser drain location?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Misterman74, Feb 19, 2026.
  1. Misterman74
    Misterman74 New Member
    27
    Fresno
    2018 Prius
    Gen 4 Prius 2...
    Where is the AC condenser drain at?
    Ive looked as well as one can with a flashlight with the under pan still on but cant find it?
    Bonus points for pictures!
  2. Misterman74
    27
    Fresno
    2018 Prius
    Not a single person knows?
  3. rjparker
    10,437
    6,544
    Passenger side near back of wheel
  4. ChapmanF
    18,484
    You'd probably get more answers if more people could tell what you really are trying to find out.
    You said "AC condenser drain". There isn't one. The stuff inside an AC condenser shifts between liquid and gas phase, but it is in gas form when released. It doesn't 'drain', it gets sucked out and reclaimed through the gray-capped AC service ports under the hood.
    The AC evaporator is inside the cabin, under the dash, and it gets cold when it works, so water from the air ends up dripping off of it. That water drains out through a hose that you should be able to find poking down through the floor pan, near the base of the firewall.
  5. Misterman74
    27
    Fresno
    2018 Prius
