Wobble control of steering.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by GigglingPresident, Jan 15, 2025.
  1. GigglingPresident
    GigglingPresident Junior Member
    St. Pete FL
    2013 Prius v wagon
    Issue: Overtime our Prius V has a wabble sensation when driving from 0 to 40 on a even road. Kind of feels like might be coming from front right. It rides better on uneven road or with little potholes as soon as it hits something it resets the vibration.
    Car stats:
    Year:2013
    Model: Prius V Two
    Mileage: 125000
    Replaced parts as part of suspension:
    • Front and Rear Wheel Hub Bearings Assembly
    • Sway Bar End Link Front Stabilizer Bar Link
    • Suspension Stabilizer Bar Bushing Kit
    What steps taken to diagnose:
    • all 4 wheel balanced
    • Inner tie rod and outer test and nothing is moving as expected.
    • Wheels rotated.
    Symptoms:
    • Wabble feeling on steering wheel when going from 0 to 40MPH.
    • Wabble kind of shaking in a front right.
    • Knocking but not loud sound from steering column on super uneven road.
    • Slight squeaking sound when turning to a driveway (
      of when turning wheels while parked)
    • look of when parked and turning steering wheel:
    I am thinking to replace all 4 struts but I am thinking it could be also rack and pinion or both inner and outer tie rods.
    Any help would be apricated.
  2. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    Broken belt on one or more tires?
  3. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    How can you diagnose that ?
  4. Air_Boss
    4,219
    1,188
    New Yawk
    Visually, for starters. Inspect the outer and inner sidewalls for tread or belt separation.
  5. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Thank you. I will report back what I find out about the tires. They are 3 years old but you never know in Florida SUn.
    Air_Boss likes this.
  6. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Greetings,
    I inspected each tire individually by moving them to the rear position to rotate and check for any visible defects. Although I'm not an expert, they appear to be in normal condition to me.
    Below you will find me turning each wheel:
    https://youtube.com/shorts/_46N_uBmt20
    https://youtube.com/shorts/JR8vxZBUlq0
    https://youtube.com/shorts/vLEpK2thu18
    https://youtube.com/shorts/VxycksB4NrU
    (seems like this forum doesn't allow youtube shorts to be embedded as media)
    At this point, I hate to shell out $$ on new tires as the one I have are fairly new from TireRack. They are Yokohamas.
    Would be worth to start replacing struts with rack pinion, inner and outer rods? Or am I chasing something else? They are all original. Car is a Florida car since the beginning.
    Here is a test of the CV axle on the right side, which produced a slight clunking noise that may be worth noting.
    https://youtube.com/shorts/YP0QfRysN-U
  7. Mendel Leisk
    41,849
    Regular, landscape-oriented, YouTube videos post fine.
  8. Air_Boss
    4,219
    1,188
    New Yawk
    Do you get the same end-play on the other side axle? Is the wobble on the side with the end-play?
  9. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Hello Air_Boss
    I do not get that play on the passenger side axle.
    The Wobble appears to be coming from passenger side. Also I can feel wobble at same rate when turning left but not so much right.
  10. Air_Boss
    4,219
    1,188
    New Yawk
    Turning left loads the right suspension, and vice versa.
    Any play when in neutral and turning the passenger side CV joint (not the axle)?
  11. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Hope I did this right. Here is a video when in Neutral and turning steering wheel. Hope you can hear noises:
    Also when steering wheel been turned, circles on the picture is top of the struts, it moves up and down depending which direction you turn. I am guessing that is normal behavior.
  12. Air_Boss
    4,219
    1,188
    New Yawk
    I meant play in the CV joints.
  13. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    So I lifted prius again, attempted to make any movement with CV axle to look for any clicking or movement and nothing concerning. Except driver side CV axle just has a little play in and out but not up and down. Both boots for outer tie rods are broken but any other boots are find.
    Here is pic of driver side:
    and here passenger's side:
  14. Danno5060
    Danno5060 Active Member
    393
    201
    Wyoming
    Does your steering wobble vary with your car's speed?
    Is it more prominent when you accelerate?
    Is it more prominent when you brake?
    Is it more prominent when you turn right, or left, accelerate on a hard left turn, or hard right turn?
    Jack up the front end and try this (side to side as well as up and down). If you can wiggle it, see what's loose.It could also be a bearing too.
    #14 Danno5060, Jan 29, 2025
    MAX2 likes this.
  15. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Greetings Danno5060.
    Got answers below:
    Does your steering wobble vary with your car's speed? from 0 to 30mph and after that it stops but when I go to 69 it shakes like balance is off.
    Is it more prominent when you accelerate? yes up to 30mph and it stops gradually
    Is it more prominent when you brake? no
    Is it more prominent when you turn right, or left, accelerate on a hard left turn, or hard right turn? When I turn left it seems more .
  16. Air_Boss
    4,219
    1,188
    New Yawk
    You’re looking for CV joint rotational play, or ‘stickiness’ in its articulation, not end-play.
  17. Danno5060
    393
    201
    Wyoming
    I was looking for more of a direct relationship between your wobble and the speed, and not that it happens within speed ranges. Do slight changes in the car's speed result in slight changes in the frequency of the wobble?
    Looking at the above interactions, it sort of (I make no guarantees) that it may be CV joint related.
    One other thing to eliminate is the wheel/tires. Rotate the wheels/tires front to back and back to front. Does that have an effect. Rotate from left to right and right to left. Does that change anything? Did you hit a major bump, curb recently?
  18. vvillovv
    vvillovv Senior Member
    4,324
    1,512
    NY
    tire balance, alignment, ball joints, shaybar links, tie rod, loose rack,
    did I miss any of the obvious?
  19. GigglingPresident
    St. Pete FL
    2013 Prius v wagon
    Its a been a while but just wanted to report. I have replaced rack and pinion, out tie rod end, steering column damper, struts in the front and in a back. Took vehicle to get alignment and balance out the tires.
    End result: 90% improvement. I can finally ride highway speeds and in town without and significant wobble.
    Thank you all for help.
  20. ChapmanF
    18,484
    Any time you have a 'shorts' URL like https://youtube.com/shorts/VxycksB4NrU, you can turn it into a regular YouTube viewer URL like https://youtube.com/watch?v=VxycksB4NrU.
    In fact, that's a considerate thing to do, because the regular viewer UI gives more control to the person watching (we can pause, go back, and so on) than the stupid 'shorts' UI does.
