09 no ready weird codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tombukt2, Mar 15, 2026 at 4:30 PM.
  1. Tombukt2
    13,355
    2,405
    Gotta 09 in here . Car won't ready has a fake e bay remote buttons do nada. Slot it car starts but no ready ..shifts n drives has 2305 HV system and some history codes for door locks . The gas gauge and trans indicators are flashing . 12.6V steady. Brake light on comm errors present . No wiring damages . The immo and ready lead me to believe plays a big part . Never seen a car not ready but drive and operate and brake properly.
    52,356
    Ready light burned out?
  3. Brian1954
    Brian1954 Senior Member
    2,397
    960
    South Central PA, USA
    I do not see any trouble codes listed!
  4. Tombukt2
    13,355
    2,405
    I guess that's possible . I have changed the C monitor display board . Shoddy repair on original . No ready on original . Replace is from tx hybrids.
  5. Tombukt2
    13,355
    2,405
    P0852 current. C1511 current.C2315 current. Sorry about that .
  6. Tombukt2
    13,355
    2,405
    Looked at computer under lower glovebox and it's wiring . No rodents evident
  7. BiomedO1
    4,098
    2,141
    SacTown, Ca
    If you've found one shoddy repair; there may be many more hidden shoddy repairs you haven't found yet. I'd check CarFax or the previous owner on the car's repair history to narrow down the repair areas to search.
    Good Luck..
  8. Tombukt2
    13,355
    2,405
    Car is really clean history reveals door lock short codes in history but now all door locks open electrically without issue . Some kind of CANisdue I think the mfd is blanked out in some HVAC settings but the radio works fine so avc lan seems to function all stock no.spparrntvelectricsl work all plugs n connections so far are very nice looking .
  9. Tombukt2
    13,355
    2,405
    The shoddy repair was done by the friend of the car's owner who did a crappy job trying to replace one cap on the c monitor board . I mean it look like absolute crap. But that crappy repair did not ready either . This be a job for tech stream active tests the manual is referring to.
    BiomedO1 likes this.
