Where does this mystery duct go?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hank, Mar 9, 2026.
  1. Hank
    Hank Junior Member
    MA
    Hi Prius Enthusiasts,
    I disassembled the rear passengers section for battery replacement etc.
    Weeks later I cant recall where this white duct attaches. Anyone out there know and have a picture or diagram?
  2. PriusCamper
    PriusCamper Senior Member
    13,021
    5,291
    Pacific Northwest, USA
    Is this a Gen2 Prius? Or a newer Prius? The battery duct work in a Gen2 Prius is black not white and this part doesn't look like anything I've seen inside a Gen2 (2004-2009) Prius?
  3. Hank
    Hank Junior Member
    MA
    Yes Gen2 2007
    I do see the black battery duct work in there too. Somewhere in that vicinity this white duct was connected.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,813
    840
    Southern California
    That looks like it splits from one large flow into 3 small ones. That suggests something HVAC related. The ducting for the the HV battery is just one big tube (in various cross section shapes) all the way from the air intake on the passenger side of the rear seat until it blows out the vent above the 12V battery.
    Edit: inspect the part carefully. It might have its OEM part number stamped on it somewhere.
    #4 pasadena_commut, Mar 13, 2026 at 6:45 PM
  5. pasadena_commut
    2,813
    840
    Southern California
    #5 pasadena_commut, Mar 13, 2026 at 6:56 PM
    xw20_driver and PriusCamper like this.
  6. Mendel Leisk
    41,873
    Something in this pic? I've highlighted one, but just a guess:
  7. pasadena_commut
    2,813
    840
    Southern California
    Nope, that part is black plastic.
    at 4:29 and 9:36
  8. Mendel Leisk
    41,873
    Maybe not always? Funny thing is, OP just removed this piece, just can’t remember from where… time for a hypnotist?
    or just pull it all apart again, see where it fits?
  9. xw20_driver
    xw20_driver Member
    99
    53
    PNW
    Mystery duct indeed. The only non-black duct piece in my 2007 Prius for the hv battery is the cooling fan. Capture.JPG
  10. pasadena_commut
    2,813
    840
    Southern California
    AFAIK they are all like yours. Mine is. It would help to see a rotated view of the one that looks like it splits into 3 outlets.
    Also, I did a google image search with the picture of that piece and it found nothing. Suggests to me that it is a part that is not frequently disassembled, and when it is, it isn't the reason for disassembly. So nobody takes pictures of that part. The ducts under the dash fit that description.
    xw20_driver likes this.
  11. xw20_driver
    xw20_driver Member
    99
    53
    PNW
    I believe the prize goes to pasadena_commut. OP's mystery duct with the 3-way outlet appears to match this part:
    DUCT SUB-ASSY, AIR, NO.2 Genuine Toyota (87201-47080)
    I snapped a photo underneath the driver's side steering column of my 2007 Prius and this hvac duct for redirecting air to the driver's feet looks very similar to the part that Hank somehow found in the back of his Prius. Maybe Hank can remember removing this vent from under his dash or maybe it fell off and the prior owner pitched it in the trunk bin.
  12. PriusCamper
    13,021
    5,291
    You're crazy... That part is not part of HV pack ventilation which is all black parts other than fan... This part is from HVAC system in the dash.
  13. Hank
    Hank Junior Member
    MA
    Hey Folks, thanks for all the comments.
    The mystery piece is in fact from under the dash near where the driver's right knee goes. The clue for me was googling the part number stamped on it and lo and behold it showed another thread on this very fine site with the answer.
    Couple of pics to show where it goes and the little fastener.
    I also did disassemble the dash at one point to fix another issue and as you guessed it, tossed the piece in the trunk. Then the snow storm hit and I didnt get to working on it again for a few months. Maybe a hypnotist would have helped!
    xw20_driver and Brian1954 like this.
  14. pasadena_commut
    2,813
    840
    Southern California
    Kind of interesting that Toyota chose to split the airflow to 3 different sizes of outlet ports. I wonder how much computer modeling they used to figure out how to balance the airflow out of that thing.
