Does it make sense to replace front bearings at 95K miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Mar 19, 2026 at 4:29 PM.
  1. gatorback
    gatorback Junior Member
    58
    2010 Prius: The right rear bearing began failing at 95K miles: both rear bearing assemblies were replaced last week at 95.2K miles.
    Given the rear bearing failure, does it makes sense to change out the front bear assemblies? I suspect that if one goes, then that may very will be harbinger what is to come in the very near future.
  2. BiomedO1
    4,115
    2,157
    SacTown, Ca
    Not really; IMHO - they last a long time; if they aren't abused. The right side usually goes, because you keep bashing them against a curb. Parallel parking and curb rashing them. It's the sideways pressure on them that takes them out. I've seen cars that go 500+K miles without replacement and I've seen some that don't make it past 40K miles.
    YMMV
    Mendel Leisk and gatorback like this.
  3. ChapmanF
    18,531
    Yeah, in my gen 1 by 238k miles I had replaced only two, and those years and tens of thousands of miles apart.
    People sometimes get too caught up in "they have the same expected time to failure"—that is, the center peaks of some probability distributions all line up—when those distributions are such wide, squat curves that it just makes more sense to fix the ones that go.
    It's different for things like internal engine parts, where you'd replace a bunch of things together so you only do the long disassembly and access work once. But wheel bearings, changing 4 of them is just pretty much 4× the work of changing 1, so may as well change each one only if needed.
    BiomedO1 likes this.
  4. CR94
    CR94 Senior Member
    2,742
    1,200
    Northwestern S.C.
    The other major threat to wheel bearings is water intrusion. I replaced the left front bearings of my Mazda three times for that reason, but no others in that car or any other car I've owned in nearly 900k total miles.
  5. BiomedO1
    4,115
    2,157
    SacTown, Ca
    I don't know how you got water intrusion into your wheel bearing assembly. Some sort of manufacturers defect? I've only seen that in lifted 4x4 that do a lot of water crossings. We usually sell them differential oil changes and sometimes ATF changes too. The water gets in through the breather tube, at the top of the unit. Pretty obvious, since the oil becomes milkshake.o_O:cool:
    We usually have to educate those guys. Just because their feet are dry, doesn't mean their SUV is OK.
    #5 BiomedO1, Mar 19, 2026 at 6:38 PM
  6. Tombukt2
    13,384
    2,408
    No noise no replace my work 09 has 535K no bearings replaced yet seriously I got it at 178K from orig owner . And those folks never did anything except put gas in the vehicle possibly change the oil a few times two sets tyres a few 12V. They said so and had receipts for everything ever been done to the car at dealer
  7. Tombukt2
    13,384
    2,408
  8. Tombukt2
    13,384
    2,408
  9. Mendel Leisk
    41,889
    Let sleeping dogs lie.
  10. bbrages
    bbrages Member
    167
    47
    St. Louis
    In my experience, the rear bearing came out easy, but the front was real tough. I wouldn't do it.
  11. ASRDogman
    ASRDogman Senior Member
    7,801
    3,980
    If you do it right, it's easy. You have to rotate them. Everyone tries to hammer them out.
    Rust Penetrant, and then rotate them one way a little, then the other. That starts to free them.
    Then rotate so the holes are covered so you and us a bolt or two to start pressing them out.
    When you have pressure on the hub, smack it with a 5# hammer, then tighten the bolts, hit again,
    hit it again, etc.
    I've done about 50 of them like that, and they always come out. I've never fought them, too much work.
  12. ChapmanF
    18,531
    That's good to hear. It's the plan I hatched after my last time fighting with one, but I've never had the chance to try it yet.
