Got a Smog Check for DMV, soon after, warning lights came on, front end is near the ground
Discussion in 'Gen 2 Prius Technical Discussion' started by jaw444, Apr 4, 2026 at 7:12 PM.
  1. jaw444
    jaw444 Member
    282
    27
    San Fernando Valley CA Van Nuys/Sherman Oaks
    On March 3, 2026, i took my car for a Smog check required for CA registration. The car was running fine, has been running fine for long time. The Smog check advertised "Smog check in 15 minutes, no repairs." i chose one nearby (there were many) and the guy finished in around 15 minutes. I drove home and made a copy of the DMV form which the Smog guy signed, saying the car passed everything. Then i drove to DMV, so far no apparent problems. I parked, went into DMV, it took about 5 minutes to hand them that form saying it passed the Smog Test.
    i went back to my car, turned it on and it made a high pitched sustained noise from in front of the steering wheel or dashboard thing. then the noise stopped. But the Red Triangle was on the screen and all the little orange lights and little car shaped orange light with vertical line above the roof. i pulled out of the parking space , i could drive the car, but scared.
    i had something similar several years ago, it wasn't exactly the same but it had the high pitched noise sometimes. My car has not had that noise again since a month ago after smog check when the problem started, but i think the other time, the Red Triangle came and went intermittently, but this time, it's been there the whole time since it started at DMV parking lot.
    Other symptoms include car resisting acceleration from Stop, then, not so much. And, while driving with windows closed, there is a sound of wind as if the right rear window is open. I have now slowly learned that the front bottom of the car is very low to the ground, it's probably getting worse over time. I think something went wrong during the smog check because Warning Lights started later that day, after short drive to DMV and have remained there continuously since then.
    the body is lower in the front and affecting driving and warning lights. One day, when i pulled into a parking place to go to a dog food store, a man was staring at the lower front of my car, he was frowning and didn't say anything, and walked away. I looked at the front of my car and didn't see anything.
    I was slowly driving out of the parking lot and another guy was staring at the lower front of my car and i stopped and he said "You have something under your car." He said he was going to remove it. He pulled on something under my front bumper but it apparently didn't come off, he didn't explain. He said i shouldn't drive it like that.
    i drove home and didn't know who to call, i don't currently have a trusted Prius mechanic. i had a good one years ago when i had the undiagnosed problem with warning lights before, Prius chat people told me about him, his name was Avi and he was a PC member. I made contact with him and talked on the phone and he said things with the warning lights can happen and you never find out what it was. That time the car died intermittently
    I had my car towed to his shop which was far away, he had said he needed to see the codes, i didn't know Priuses had codes then. But i had taken it to a local so-called Prius specialist the day before and they said i needed a new engine or transmission, they were scamming me, i asked for the codes but she said she needed new prius software to get them, and she never gave me any codes, she said they weren't for customers to have. i realized it was a really bad unethical shop, they came highly recommended by Prius people on NextDoor and one other place i can't remember. i was looking for something local.
    So when Avi tried to get the codes the next day, he couldn't, he tried really hard. i told him i thought that other shop had erased the codes so i couldn't take it anywhere else, just guessing, he said it might be because the car hadn't recently been driven (i may be remembering details wrong. Anyway, he did work on things under the hood and in the drivers area and the problem was intermittent unlike the current problem, so, he didn't charge me anything, i would've paid. After that i think either the warning lights never came back, or the problem continued intermittent. it did go away, without any of the repairs other shops said i needed. That was years ago.
    Now, i'm facing this again, looking for a trustworthy Prius mechanic or any mechanic who could fix this very low front end and the sound a wind coming into the car when driving it even though windows are up. This is different, it's not intermittent, and i'm untrusting of taking to someone i don't know, finding Avi's contact number will take some research, i'll try, this is slowly unfolding for me, there's been other things on the plate and i don't drive much, but i need to drive the car bad. prescription is waiting to be picked up at pharmacy, just got a text and i need to get to the pharmacy somehow, it's mile and a half. They close at 6 and it's now 4. is it better to take a taxi than to drive the car? i was thinking i will drive really slow and take bumps really easy and slow.
    Does anyone know of trustworthy prius mechanics, i'm in the San Fernando Valley, Van Nuys/Sherman Oaks, in Los Angeles. i will need to have it towed, the front end is an inch off the ground, i took pictures, i think it's gotten worse since it first started because i kept driving it.
    i have to get the prescription and don't know what to do. it's a nightmare fo me, because i had to get the smog check, i never had trouble from a smog check before, but this guy was really rushing, can anyone tell me what they do to your car during the smog check, what they connect to, the car was up on a rack. Are there things that might be accidentally detached or not tightened enough? or not put back together? or slowly come part after driving it, over time? the red triangle and other symptoms, sound of wind, started within an hour after the smog check. i'm scared to take it to someone i don't know or who doesn't know how to fix the lower front end of a prius, do i need a body shop?
  2. pasadena_commut
    pasadena_commut Senior Member
    2,866
    860
    Southern California
    So much text, so little useful information!
    Let's start with the basics: don't panic.
    The side view of the front of the car did not look alarming to me. The bumper cover is where it should be and I don't see anything out of the ordinary. If you stand in front of the car while it is parked on a flat surface, and look at the bumper or hood is one side notably lower than the other, that is relative to the street? I doubt that is the case, but if it was that would indicate a serious suspension issue.
    The picture under the car appears to show a splash shield hanging down. That is a nothing burger. There are sheets of thin fairly rigid black plastic under the front of the car whose purpose is to keep water from splashing up and also to control the flow of air. The car will work OK with that hanging, even if it is dragging, although then it may make some noise and could get caught on something and tear clean off. Some areas are attached by metal screws or bolts and others by nylon fasteners. The latter get old, break, and fall out. The former sometimes tear through the plastic if the car lands on a rock or other item in the street. Similar material goes around the wheel well and extends to the front of the bumper cover. The front part of that can break too. The view under the car does not indicate any serious suspension issues.
    Regarding the codes, you need to be able to read these yourself while they are present. No more being at the mercy of unscrupulous shops. Also, find out what the problem is immediately, so you can make an informed decision about continuing to drive the car if it is lit up. While there is a way to do this without a reader it doesn't sound like you are at all mechanically inclined, and I'm not going to suggest you even try it. You should buy a code reader. The Autel AP200 Maxi is a popular one on this forum. The price fluctuates, it is currently around $60 on Amazon B07QD4GZW4. It plugs into the OBD2 port under the dash and is accessed using an app on a smart phone. You have to set up an account with Autel, set it for "Toyota", and the phone needs to have working network access to install the software and enable you to use it, but then you will be able to read all the codes. There is no yearly charge to keep the app working. If you want to read another type of car, say a Honda, you would have to purchase support for that yearly. Plug the OBD2 dongle in, start the app, get the car to READY (if possible) and read the codes. Then look up what it/they mean on line. If in doubt, ask in this forum. Note, lesser code readers often cannot read all the codes on this car, the one at an Autozone or O'Reilly's may not be able to.
    I am not familiar with the repair shops where you are, so cannot suggest which you should visit. Perhaps somebody else here can help with that.
    bisco, jaw444 and Brian1954 like this.
  3. pasadena_commut
    2,866
    860
    Southern California
    The smog check likely has nothing to do with this. They just read the OBD2 codes, check the gas cap, look in the engine bay and under the car for illegal modifications. If he looked underneath using a mirror on a little wheeled cart with a long handle there is a remote chance he might have nudged the shield if it was already hanging down, and that might have made it worse. But if it did something else was sure to do the same thing pretty soon anyway.
  4. AzusaPrius
    AzusaPrius Senior Member
    2,243
    931
    Thats just plastic cover sagging, nothing to worry about.
    Get some zipties and get under there.
    Also once you get a smog, you do NOT have to make copies and drive to the DMV.
    They get a digital certificate next day.
  5. rjparker
    10,546
    6,620
    Walking is good for you
    Seriously, you need help and maybe a hybrid Prius is not the best car for you. A conventional car is repairable by any shop buts lots of those shops are scared of hybrids.
    It looks like you have a loose panel under the car and it may be scrapping. The car is not lower than normal; you just have a plastic cover that is removed during oil changes but is not secured.
    Your dash lights are another bag of worms. First thing I thought was bad brake booster (essentially the complicated hybrid master cylinder). Not low cost but not second mortgage time either.
    This could be a serious safety issue.
    I would take it to Hybrid Pit and leave it for a diagnostic. Get an appointment and save the car repair war stories for another time.
    #5 rjparker, Apr 4, 2026 at 11:50 PM
  6. pasadena_commut
    2,866
    860
    Southern California
    Not to cast aspersions on the Hybrid Pit, but surely there is a good independent mechanic closer than Buena Park, which isn't even in the same county. That would be a really long and expensive tow and if the OP has to get home on public transit it would be 4 or 5 hours. There is a shop named "Prius Doctor" that is close to Sherman Oaks. I don't know a thing about them, but rather than drive all the way to Orange County I would certainly check them out. Push comes to shove, there are a couple of dealer service departments in that vicinity. For the OP, independent mechanics are usually a better choice than the dealerships, which are often referred to as "stealerships" in this forum.
    In general I have found that one way to find a good mechanic is to find a car similar to your own (in this case an older Prius) in a parking lot with fast turnover, like a grocery store. Preferably near the place you live (or work). Wait for the owner to come out and then politely ask them where they get it serviced. Do this a few times and when the same name keeps coming up, that is where you go. When we had a Subaru the result was wild, literally all the Subie owners we asked were going to the same guy. So we did too and did not regret it. If the model is really rare (not the case here, I see dozens of Gen2 and Gen3 cars even on a short trip), just ask owners of the same brand. But again, not cars that are still under warranty as those owners are still going to the dealer.
  7. rjparker
    10,546
    6,620
    I would go to Hybrid Pit with a friend to take me back. A bird in the hand is worth two in the bush and this gal needs knowledgeable and trustworthy help.
    Car insurance often has a tow service but it sounds like she is driving it.
    I drive over an hour to get to a qualified but value oriented shop. Its worth it when you are looking at a $2000 brake booster.
    When I was in the LA metro last October I drove from one end to the other and back. Its no big deal.
  8. pasadena_commut
    2,866
    860
    Southern California
    Depends on the time of day and which route you are taking. We could drop our kid off at UCLA in 50 minutes early on a Sunday morning. It took 2 to 2.5 hours (typically) at rush hour.
