2013 Plug-In to Charge Bluetti Battery Bank
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by FrugalBeeotch, Apr 10, 2026 at 4:56 PM.
  1. FrugalBeeotch
    FrugalBeeotch Junior Member
    People's Republic of Seattle
    2013 Prius Plug-in
    I have a 2013 Prius Plug-In. I'm trying to determine if it is possible to charge my Bluetti Elite 200 V2 using my car as a generator. I know I can use the 12v "cigarette lighter", but that gives me a slow trickle charge. It's enough to keep my internet and security cameras running during a power outage, but I'd like to be able to keep our refrigerator running as well. The Bluetti can handle the spikes, as long as the car can provide a sufficient charge inflow to keep up with the outflow.
    I know cars with "normal" alternators can run a device between the alternator and the battery that can bring in like 600-800 watts continuously, but I've heard the plug in prius can't really do it.
    Any ideas how I might be able to draw 600-800 watts continuously from my plug-in prius if the grid is down?
  2. BiomedO1
    4,216
    2,200
    SacTown, Ca
  3. VelvetFoot
    VelvetFoot Active Member
    1,245
    487
    New York State
    2026 Prius
  4. bisco
    52,417
    VelvetFoot likes this.
  5. VelvetFoot
    1,245
    487
    New York State
    2026 Prius
    My Bluetti AC180 easily powers the fridge overnight. It's a newer model Frigidaire side by side. The new ones consume less power and energy. The defrost cycle is still a big drain, but I've found no easy way to defeat in for the duration of the outage. Maybe open cycling power can give you a couple hour respite? I forget. Easy to do when you have power, lol.
    I recharge with a Honda inverter generator 2000i.
  6. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    Using your Prius to power stuff in your house up to ~1000 watts is as simple as wiring an inverter to the 12volt battery. I prefer a 2000w inverter because everything runs better at only half its limit. And because Bluetti is simply a battery and an inverter in a box, you should be able to wire it's 12volt inputs directly to the battery. The challenge will be how Bluetti limits the amount of amps it can draw from an external 12v. Perhaps there's a function in the settings that allows you to set it to pull max amps?
  7. BiomedO1
    4,216
    2,200
    SacTown, Ca
    All you have to do is unplug the "hot wire" for the defroster cycle - but you'll run the risk of icing up and occluding air flow thru your evaporator.
  8. VelvetFoot
    1,245
    487
    New York State
    2026 Prius
    I'll have to look again. Everything's digital. This would just be for the duration of the outage.
    BiomedO1 likes this.
  9. BiomedO1
    4,216
    2,200
    SacTown, Ca
    Find the controller and look for hefty relay and wire; that should be the heater circuit. As long as that wire doesn't go to the compressor. Those should be the only hefty wires in that unit. You may want to put it on an easy to reach switch - so you don't have to move it every-time power goes out.
