Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. ChapmanF
    18,669
    I can see this conversation happening if we were talking theology and you belonged to one of the denominations believing the Bible is completely inerrant in every word.
    But the Repair Manual is a book we know was written by mortals, and edited and translated by mortals, and does have rare, occasional mistakes.
    So if you were a theologian and you noticed two things in the Book didn't seem to make sense together, yes, you would have to bend over backward and say the only possible explanations must somehow fit "to the T" with both parts 'cause you can't allow there could have been a mistake.
    But the Repair Manual doesn't require that treatment. It has very few mistakes (really amazingly few, given its sheer size and the complexity of translating technical info from Japanese to English). But I've found a few over the years, and others have too, and Toyota does have a process in place for accepting reports of errata and fixing them in the online version. I know they do that 'cause they've accepted at least one from me.
    So, first off, if you haven't checked yet what the current, online version says at that spot, there's a very good chance that what we're still going on about is something that may have been clarified or fixed years ago. (I had a permanent P0102 for, like, a year, that I couldn't clear because I was looking at a 2010 Repair Manual edition that had straight-up left a step out of the confirmation pattern. Found the missing step in the updated online version—well, really, Elektroingenieur found it for me—and good to go.)
    And, second, for times when you don't want to check for later corrections online, but you see something in the Repair Manual that looks like it might be a goof, it's ok to think it might be a goof. You don't have to limit yourself only to possible explanations that preserve the inerrancy of the Repair Manual. It's allowed to ask questions like "if this was a goof, what did they probably mean?".
    #161 ChapmanF, Apr 22, 2026
    Brian1954 likes this.
  2. Brian1954
    Brian1954 Senior Member
    2,479
    990
    South Central PA, USA
    I never had a problem with the hybrid battery in my 2011 Prius, so there was never a need to clear a permanent P0A80 code.
    One thing you seem to be missing in your written description of the Universal Trip Driving Pattern. It needs to be 10 minutes or more in total time, not just the 5 minutes or more driving above 25 MPH.
    I trust the Autell AP200 to read all the trouble codes on a Gen 2 or 3 Prius, so if you do a complete scan and find no codes, then it is ready to get the smog inspection done. I do not care if any of the other scanners that you own show a permanent code.
    #162 Brian1954, Apr 22, 2026
    PriuSocal likes this.
  3. PriuSocal
    PriuSocal Member
    346
    57
    SoCal
    OMO
    Actually, since you mention it off topic, I do fit the bill as one of those who believe the Bible is completely inerrant in every word. And its definetly not based on “denomination” its based on whether you are a true believer or not and have reviewed the facts. The questioning lies on “interpretation” and not “denomination” IMO ;)
    On the actual question, I rest my case as Im sure of there was someone who would have had success, it would have came up on all the posts regarding P0A80 in this forum.
    #163 PriuSocal, Apr 22, 2026
  4. PriuSocal
    PriuSocal Member
    346
    57
    SoCal
    Oh, it wasn't missed just not questioned in the procedure. But yeah that part was done each of the 2 times I tried the procedure.
    As for the trusting the AP200, I had that question somewhere in the last 8 pages where I inform that the permanent code doesnt show on the Autel based scanners and only on my BlueDriver scanner. The AP200 even shows IM readiness at a ready for smog phase. Further online research showed that “certain” scanners may not show “certain” permanent codes and only current or pending and one of those scanners on the list was the Autel based scanners and word of caution was to go by the one that actually showed it because it wouldnt continue to show if it wasn't there.
    I also mentioned how the smog guy here in CA concurred with some scanners not showing permanent codes and then them showing up on their computer which is linked to the state and if it does show on their end, it will automatically fail with no pre test available for this type of code since they use a scanner of their own to pretest if the car has any current issues and if none show on their scanner (dont know what type of scanner they use) they run it but have had moments where their scanner shows clear and the when they hook it up to the states system, the permanent comes up and fails.
    That was my dilemma since I do need to smog it here in CA to get it registered and thats the only thing pending to get my tags from and finalize the title transfer. They are willing to try it but theres that asteRISK that exists and I have to be willing to take it if I want to “find out” if indeed the code is not really there like the AP200 and my Icon T10 suggests.
    #164 PriuSocal, Apr 22, 2026
  5. Brian1954
    2,479
    990
    From website, (US Ship)Autel MaxiAP AP200 Bluetooth OBD2 Scanner Auto Car Check Engine Light Code Reader for Family DIYers – AutelShop.us
    Functions:
    1. ....
    2. ....
    3. COMPLETE OBD2 FUNCTIONS:
    1. Read extensive current, pending and permanent codes in OBD system quickly
    You wrote in post #68:
    #165 Brian1954, Apr 22, 2026
  6. PriuSocal
    PriuSocal Member
    346
    57
    SoCal
  7. ChapmanF
    18,669
    I know there are denominations confessions groups of Christian-identifying people who hold the position you hold there, and other groups of Christian-identifying people who do not, and saying which ones are right is above my pay grade. For the purpose of this thread it doesn't matter, because the key on-topic point of my post is that no such treatment is merited by the Toyota Repair Manual. That's a book we know can have mistakes. :)
    So if you come at Repair Manual interpretation using the same approach you have to use when treating a different book as inerrant, you can miss possible simpler answers to puzzling bits.
  8. ASRDogman
    ASRDogman Senior Member
    7,890
    4,013
    Just drive it. However you normally drive. Eventually it will go away.
    If the issue that threw the code is repaired, according to Toyota.
    It will take a few cycles for the mileage to equal out.
    Just use the same station, and the same pump each time. Fill up the same way each time.
    That way you can get the most accurate readings.
    I believe you said you disconnected the 12v battery, so it resets everything.
    The computers learn how you drive, and the accuracy of the guestamite will get closer
    to the real thing. The best way is to reset one of the trip meters when you fill the tank.
    drive to about half a tank, fill up and write down the mileage. Then divide the mileage by
    the number of gallons.
    Enjoy the car!
  9. PriuSocal
    PriuSocal Member
    346
    57
    SoCal
    Something funny happened yesterday.
    A friend who has a 2012 called me saying they had the RTOD come up on theirs and wanted me to check it out for him. He brought it over and immediately I noticed the car would not shut off even when parked. I ran a scan and what do you know, P0A80 as current, pending and history/permanent. He stated he had been driving the car like this for about 2 weeks. Like Avril Lavigne said…. “And isn’t it Ironic…Don’t you think? It’s like Crayyyyzayyyy” LOL.
    However, not entirely a bad thing. Why you ask? Well, it allowed me to see another side of this P0A80 code and compare symptoms from his car to mine and they are similar in the fact that both cars are running well and he even says his MPG is in the mid 40’s still, but night and day in others. His car has 206k and he has only done basic maintenance on it since he bought it 2 yrs ago (oil, brakes, tires etc). I checked the HV blocks while car was on and most blocks were hovering in the low 16v’s and 5 and 6 were on the mid to high 15v’s, at times reading 0.4v-0.5v under. I shut the car off and deleted the codes, then when I turned it back on, the car would now stay on for 5-10 secs and then shut off like they normally do and battery was holding steady charge at minus 2 bars from full. Something the car was not doing before since it would stay on constantly and most likely PCM recognizing weak cells/blocks and constantly sending a charge which would not hold on its own.
    Here are the key differences noticed from his car to mine with a permanent P0A80. With car A being his and B being Mine
    A.
    1. Showing permanent P0A80 on the AP200/T10 scanners
    2. Multiple blocks at -0.4v-0.5v
    3. P0A80 came back on after 2 hours
    4. Has slight death rattle at startup
    B.
    1. Not showing the permanent code on AP200/T10 (only showing on BlueDriver)
    2. All blocks show consistent similar readings
    3. No CEL or current codes present so far after 1k+ miles
    4. No death rattle
    i know the last difference could be unrelated and more a possibility in relation to EGR side of things (if that), but we will be going into the battery and checking the condition of the busbars/nuts as well and testing each modules voltage at static and under load to get a clearer picture.
    I am beginning to feel more aligned with @ASRDogman that my car may just need to be driven and perhaps this code will resolve on its own after some drive cycles. Also, with the OP who mentioned taking it to the smog place and taking a chance at smogging it and it not appearing on their side either has become a plausible idea.
    #169 PriuSocal, Apr 23, 2026
  10. PTS
    PTS Member
    94
    44
    Austin, Texas
    2013 Prius v wagon
    His battery is toast and it is very possible he has a head gasket leak.
    When I had a permanent P0A80 the only thing that cleared it was a replacement. Prior to that, the Toyota documented or the internet modified Confirmation Driving Pattern failed.
    After replacement it cleared by itself in a day.
  11. PriuSocal
    PriuSocal Member
    346
    57
    SoCal
    You referring to a “replacement” of what the battery fixed your issue? I feel that way as well in his case. Good thing is he is prepared to get a replacement HV battery if it indeed is the issue. As for the death rattle, HG issues usually have underlying and visual symptoms like coolant loss as well as washed out cylinders etc. He is not experiencing coolant loss at least. It could be the beginning of such issue though and at this time, you start by the EGR, TB and Intake Mani cleaning and sometimes that does the trick for that, also dirty or failing injectors can cause that as well.
    #171 PriuSocal, Apr 23, 2026
