EvGo Charging Station?
Discussion in 'Prime Technical Discussion' started by maiki, Apr 8, 2026.
  1. maiki
    maiki Member
    219
    35
    As I have indicated before, I have no option to plug in the car (2025 XSE Premium) where I currently live, so am dependent on charging stations. (besides occasionally getting a tiny bit of charge from the solar charging roof.) Therefore yesterday, totally out of charge, when I saw a charging station a couple blocks away from where I had a doctor appointment, I thought I would get some charge while at the doctor?
    It was an EvGo charging station. They had cables with two different kinds of connectors, both much larger than the one for my car. (Not the Tesla connector either.) So I could not charge there.
    This also happened recently when I wanted to charge at chargers within a Von's supermarket parking lot. Only one connector, similar to one of those at EvGo, too large to fit in my car.
    As I think the kind in our cars is the most common type of connector (not counting Tesla), why do some charging stations not have a cable that that will fit it? Seems they are losing business that way? (If many cars cannot use their station?)
    Can one obtain some kind of adapter that would enable one to use those different chargers?
    Thanks in advance.
    BTW, speaking of charging while shopping, etc., it is aggravating that Whole Foods (at least here in California) no longer have chargers in their parking lots! (Bezos kissing up to Trump?)
  2. BiomedO1
    4,493
    2,359
    Left Coast
    Your more than likely running into DC fast chargers in So. Cal.. IMHO; it's unwise to hook-up using an adapter to something you don't know what the output is. That's the reason they are different connectors; to prevent stupid stuff from happening. If it's a popular charging spot, there should be a J1772 connector somewhere.
    On my car and my driving style; I've calculated that paying more than $0.38 Kwh is the same as paying for gasoline. That calculation was done @ $4 a gallon of gasoline. In my experience, most charging stations charge way north of that and stack fees on top if it. This also doesn't take into account how long you'll need to hook-up - since these cars are slow chargers compared to other modern cars. Some will add a parking time fee that ticks off every 30 minutes.
    Your car, your wallet, do whatever you like....
    #2 BiomedO1, Apr 8, 2026
    PrimeDan, maiki and pasta4breakfast like this.
  3. bisco
    52,758
    public charging is complicated. you should see the confusion over on the chevy bolt forum.
    if you want to learn about public charging, you'll have to spend a lot of time with google, it's a steep learning curve
    PrimeDan and maiki like this.
  4. pasta4breakfast
    131
    66
    Anaheim, CA
    2020 Prius Prime
    You are probably looking at CHAdeMO or CCS level 3 DC fast chargers. I don't think there is a lot of financial incentive to build out much more level 2 chargers. Plug-in hybrids are the only new cars that are limited to L2 public chargers and it is usually more economical and convenient for their owners to buy gas if they need to fuel outside of the home. The DC fast chargers generate more revanue becaue time is money. Even if the owner of the charging station could add J1772 connector to it, why would they? It would probably cause them to lose money. For a plug-in hybrid to even bother charging, the price would have to be less than $0.40 per kWh. Imagine a Prius Prime taking a spot for 1 hour just to spend $1.32 when 3 modern EVs could spend over $100 at a fast charger during that same hour.
    Usually the only economical L2 charging stations in my area are at malls (best chance of getting a spot is before they open) or government buildings (libraries, city halls, parks etc.). Most of the charging apps allow you to filter out any charging stations that won't connect to your Prius Prime. The ones I use the most are JOLT (mostly free charging at malls), charge point (sometimes has reasonably priced L2 charging at about $0.30 per kWh) and plugshare (finds pretty much any charger).
    #4 pasta4breakfast, Apr 11, 2026
    PrimeDan, maiki and BiomedO1 like this.
  5. BiomedO1
    4,493
    2,359
    Left Coast
    I've got the plugshare app on my phone, but rarely use it - since my car charges while I sleep.
    I was pleasantly surprised to find a couple of L2 charger in a national park I camped in for two days. They were marked for a specific brand of EV but had J1772 plugs and what looked like a chargepoint screen. I was lock-out of one, but the other did an electronic hand-shake and started charging. I corrected the plugshare data and description, that one of the two is freely open.
    I had to wait for that plug the second day. When I got up; I was planning to recharge while I made breakfast and broke-down camp. There was a Nissan leaf in my spot, but it was almost full - when I walked around it. I guess the owner saw me do that and unhooked as soon as it was done. He commented that he thought it was a EV specific charger and knew about it the last three times he's camped there, but never tired it. I told him I was the one who correct that post. I guess I should've waited, before posting my discovery. :(:rolleyes:
    Oh well, live and learn.....
    #5 BiomedO1, Apr 11, 2026
  6. maiki
    maiki Member
    219
    35
    Those (EvGo) I mentioned were in a bank parking lot, and were all empty. So I don't think they bring in a lot of revenue? Yet they could have earned a little from me if they had a plug that fit the prime.
  7. maiki
    maiki Member
    219
    35
    As I menrtioned Whole Foods parking lots near me used to always have at least one charging station (which fit the Prime), some a few, even up to 4, At first totally free to use, no app, just plug in. Later changed to Shell. Didn't cost much, but the app rather buggy, didn't always work. But now they have removed those, no charging stations at WF stores here at all. Is that true nationwide? Anyone know why?
    For those of us that can't charge at home, it is convenient to be able to add some charge while shopping. Is the government pressuring stores not to have them now? (Since Trump gets loads of money from the fossil fuel industry, petro states like Saudi Arabia, etc.)
  8. BiomedO1
    4,493
    2,359
    Left Coast
    Quite the oppisite; they've removed Federal incentives to install them. That's why you saw the shift at Whole Paycheck; they didn't want to deal with it and signed up Shell to take care of it and pay them back. Shell determined that it wasn't a cost effective location for them or Whole paycheck wanted too much money; maybe a combination of both. Shell ripped it out and relocated the equipment to a more profitable location. I'm sure whole paycheck didn't have to listen to complaints for the locked-out EV parking spots too. So it was a win-win.... Not for the customers, of course.
    That call is usually at the property manger's desecration; if they lease that space vs buying that space. Ditto with the banks; if the bank manager, employees, and customers mainly drove EV's - that would be an incentive for them to ask that a charging station be installed. The additional revenue or deficit could be added or subtracted to the monthly rent for that additional convenience. Equipment and labor cost may come down, because there's no more FREE money; so build-out will be much slower. Add to that; no standardization of infrastructure, makes building one a big gamble that won't pay-off....If the standards changed tomorrow; you just flushed $100K and need to rebuild to the new standard and/or rip out the one that you just built.
    There's no FREE lunch; someone needs to pay the bill........
    #8 BiomedO1, Apr 12, 2026
  9. pasta4breakfast
    131
    66
    Anaheim, CA
    2020 Prius Prime
    Yeah, I don't think I have ever used an EVGo charger and it is not surprising that they were empty. The ones I noticed on the app were either overpriced, in an inconvenient location, or did not have the right connector.
    I have never seen a J1772 connector on a DC fast charger. If it was practical, you would think someone would have done it by now. There is probably some technical limitation or it is just not that much cheaper than installing a separate L2 charger. I have seen multiple charging locations with separate DC fast chargers and L2 chargers in the same lot. Thus, companies must think it's more profitable to install separate chargers. Even if a DC fast charging spot is often empty, it could still be a net negative in revenue to add a L2 plug to it. If you are spending less than $2 to take up the spot for an hour and a modern EV would spend over $30 to rapidly charge in 20 minutes, you would have to charge there 15 times to make up for the revenue loss of preventing an EV from charging at that location just one time.
    #9 pasta4breakfast, Apr 18, 2026
    maiki and PrimeDan like this.
  10. maiki
    maiki Member
    219
    35
    I have seen on Facebook ads now (FB likely saw my post here) for adapters that could go from J1772 to those other kinds of connectors. Surprisingly expensive though, like hundreds of dollars, for a little adapter? But was the advice here that that could harm the car, to connect the Prime to one of those other types of connectors via an adapter?
    I also checked Ebay. Some only connecting to Tesla connectors not expensive, but the other kind still expensive, of what I saw.
    When one has no option to charge at home, it is convenient to be able to charge while doing errands, shopping, at a doctor office, etc.? So such an adapter could be helpful at charging stations without J1772 connectors?
    Not recommended? Any familiarity with less expensive adapters?
    Thanks in advance?
  11. bisco
    52,758
    Whole Foods did that here as well. I used to plug in my pip there. then they went to paid and I couldn't be bothered. and then those were eliminated as well. idk why
    maiki likes this.
  12. maiki
    maiki Member
    219
    35
    Perhaps Bezos trying to please EV-hating Trump?
  13. maiki
    maiki Member
    219
    35
    The paid (Shell app) didn't really cost much, but more hassle, buggy app. And yes, lately took out the charging completely.
  14. BiomedO1
    4,493
    2,359
    Left Coast
    If you use adapters and plug into a charging station that you don't know what kind of power is coming out of that connector - Do you think that would be wise???? That's why there's different connectors to begin with. Why do you think 115VAC sockets are different from 220VAC sockets, ditto with international electronic connectors???? While a lot of equipment has an automatic switching power supply - Not ALL equipment is built that way.
    Do you want to pay a couple of thousand of dollars to repair your car; if it can be repaired - after plugging it into a high voltage DC fast charger? Suddenly $6 a gallon of gas; starts looking really cheap.........
    #14 BiomedO1, Apr 22, 2026
  15. bisco
    52,758
    I don't do Fakebook, but there's a prime owners group that seems more in touch with public charging. reddit too.
    3066099590325883
  16. pasta4breakfast
    131
    66
    Anaheim, CA
    2020 Prius Prime
    I wonder if Shell selling their former VOLTA charging network to JOLT had anything to do with this at all. The free chargers by a Whole Foods in Long Beach CA started as VOLTA. Then when Shell purchased VOLTA, they became Shell Recharge stations. They were still free at that time. Then the massive row of reasonabely priced Chargepoint chargers at that Whole Foods became non-operational. Thus, I stopped meeting family there so I could charge for my trip back home. Choosing a distination for a free charger isn't worth it if there isn't a reasonable backup option. The Shell Chargers could have switched to paid in the meantime. Then JOLT bought Shell/VOLTA chargers and now the Whole Foods ones seem to be gone. The JOLT (former Shell/Volta) chargers still exist at other malls though and they work just as well as when they were Shell.
