why does Dr Prius app show only 14 modules when I thought there was 28?
Discussion in 'Gen 2 Prius Main Forum' started by Christophersavesgas, Apr 25, 2026 at 7:02 PM.
  1. Christophersavesgas
    Christophersavesgas New Member
    Bothell
    does each bar in the Dr Prius app equal two modules?
  2. Hayslayer
    Hayslayer Active Member
    485
    273
    Yes.
    There are 28 individual modules, each 7.2 volts nominal. Typical in use voltage 7.5-8.x volts.
    Each pair of modules forms a block, which is measured for overall voltage.
    There are 14 blocks, each consisting of 2 modules => nominal voltage 14.4 volts. Typical "in use" voltage 15-16.x volts
    Brian1954 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,163
    5,323
    Pacific Northwest, USA
    Yes... Unlike lithium that requires a voltage monitor for every cell for safety, NiMH cells in Prius don't have that level of risk so there's only a voltage monitor for every 12 cells, or every two modules.
