Rough/pulsing engine & Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fit Yz, Apr 28, 2026 at 11:56 PM.
  1. Fit Yz
    Fit Yz New Member
    Tuesday
    I've been working on this for about 6 months and out of ideas.
    I have a 2010 Prius with around 170,000 miles. Near the end of 2025, the engine started running rough with a pulsing/surging sound and threw a check engine light. I had it scanned at O’Reilly and was told it was related to the EGR system, but I no longer have the exact codes (I can try to track them down if that’s important).
    Over the next few weeks, I removed and cleaned the EGR valve and cooler, cleaned the intake manifold (there was oil pooled inside), and replaced the PCV valve. After putting everything back together, the car ran a bit better but still didn’t sound quite right. The check engine light did not come back at that time.
    In January, I took it on about a 2 hour highway drive. By the end of the trip, the engine started making a pulsing/surging sound again. After letting the car sit for a couple of hours, I started it again and it ran extremely rough right when the engine kicked on. I got the red triangle warning and a "Check Hybrid System" warning, and the car basically died and would not accelerated. I shut it off, restarted it, and was able to limp it to a safe place to park and eventually get it towed home.
    I took it to a local mechanic (not a Toyota dealer). After diagnosing it, he said the hybrid battery needed to be replaced and believed that would fix the rough running and may have actually been the original cause that threw the EGR related codes as the battery was likely failing at that time. He also inspected the cylinders with a camera and said he didn’t see signs of a head gasket issue.
    Since a new OEM battery was quoted to my by my local Toyota dealer at ~$5,500, I decided to try recondition the battery myself. I cycled all the modules multiple times through discharge/charge cycles (up to about 20 cycles) with the goal of getting >5 aH consistently per module. From what I found, “healthy” modules should be >5 aH, but most of mine wouldn’t reach that. I aimed for at least ~4.5 aH per module because replacement modules on eBay weren't advertised to be any better, then balanced the pack and reassembled it based on each modules best performance (all data below).
    After reinstalling the battery, the car seemed to run better at first on a 5 mile drive but I could still hear a pulsing/surging engine. The next day, within a 10th of a mile, I again got the “Check Hybrid System” warning along with a check engine light. I don’t have an OBD2 scanner and it’s difficult to get the car somewhere for another scan.
    I’m trying to figure out whether this really is still a hybrid battery issue or if something else is causing the rough/pulsing engine. Does this sound like a battery problem, or should I be looking at something else, or even a head gasket despite what the mechanic said? Did I recondition the battery incorrectly or incompletely? Did I rebuild the battery packs incorrectly?
    Bottomline, what should be my next step?
    Below is a csv of all my data from the battery reconditioning as well as how I rebuilt the pack.
    Code:
    Module,Pre-reconditioning Voltage (oc),Discharge 1,Charge 1,Discharge 2,Charge 2,Discharge 3,Charge 3,Discharge 4,Charge 4,Discharge 5,Charge 5,Discharge 6,Charge 6,Discharge 7,Charge 7,Discharge 8,Charge 8,Discharge 9,Charge 9,Discharge 10,Charge 10,Discharge 11,Charge 11,Discharge 12,Charge 12,Discharge 13,Charge 13,Discharge 14,Charge 14,Discharge 15,Charge 15,Discharge 16,Charge 16,Discharge 17,Charge 17,Discharge 18,Charge 18,Discharge 19,Charge 19,Discharge 20,Charge 20
    1,7.95,3295,5042,3286,6500,3572,6500,4334,6500,4260,6500,4505,7000,4766,7000,4742,6500,4885,6500,3932,6500,4841,6500,4911,6500,5191,6500,4894,6501,5112,6500,4884,6172,4780,6500,5033,6500,5090,6500,,
    2,7.96,3547,6500,3826,6500,4048,6500,4152,6500,4090,6500,4547,6500,3495,4982,4140,6500,4599,6501,2595,6501,4460,6500,4514,6500,4742,6500,4580,6500,4533,6500,4606,5450,4391,6500,4488,6500,4836,6500,4686,6500
    3,7.95,1422,5578,2671,6440,3139,6478,3565,5611,3775,5926,3841,6500,3308,7000,4516,7000,3453,6500,4896,6500,4520,6500,4981,6500,5012,6500,4636,6500,5081,6501,4873,6500,4765,6500,4791,6500,4958,6500,4882,6501
    4,7.97,1933,6010,2935,6500,3396,6500,3629,6500,3497,6500,3898,6500,3386,7000,4471,7000,4481,7000,4442,7000,4437,7000,4234,7000,4905,7000,4736,6500,4925,6500,5069,6500,4146,6500,2444,6500,4913,6501,4980,5396
    5,7.95,1821,4360,2844,4460,3101,6500,3960,6096,4181,6500,4233,6500,3743,7000,4568,7000,3836,6166,4790,6500,4708,4544,4017,6501,4741,6500,4773,6501,5027,6500,4896,6500,5125,6500,,,4874,6500,4812,6500
    6,7.94,1222,5614,2645,6500,3188,5708,3373,5355,3540,6500,3816,6500,3396,7000,3923,7000,3792,7000,4213,7000,4556,7000,3834,6501,5092,3606,3175,6501,4894,6500,4830,5745,4660,6500,5222,6500,4867,6500,5113,6501
    7,7.94,1411,5220,2772,6248,3312,4950,3466,5487,3796,6500,3866,6500,4690,6500,4793,6500,4878,6500,4745,5588,4597,6500,4971,6500,4643,6500,4771,6501,4867,6501,1748,6500,4896,6500,5125,6500,4874,6500,4812,6500
    8,7.94,2379,5139,2748,5551,2904,5457,3060,5711,3208,5734,3228,5968,3222,6089,3541,6152,3651,6423,4258,6310,3212,7000,4437,7000,4457,7000,3945,6500,4639,6500,4774,5961,4858,6500,4894,6501,4919,6501,5127,6500
    9,7.97,2374,5653,3277,5816,3632,6370,3993,6500,3935,6500,4295,6500,3531,7000,4369,7000,4603,7000,4070,6501,4924,6500,4881,6500,4763,6501,4782,6500,4966,6500,4908,6500,4911,6500,4989,6500,4993,6500,4763,6501
    10,7.96,3201,6500,4219,6500,4156,6500,4186,6500,4692,6500,4349,6500,3698,7000,4745,7000,4621,7000,4841,6500,4825,6500,4535,6500,4633,6500,4708,6500,4908,6501,4710,6500,4907,6500,4732,6500,4693,6500,4905,6501
    11,7.94,1547,4794,2370,5183,2809,5508,3155,6107,3475,6215,3695,6500,3231,6500,4164,6500,4313,7000,4191,7000,4423,7000,4441,7000,4681,6500,3934,6214,4926,6500,4709,6500,5058,6501,4872,6500,4739,6500,4738,6500
    12,7.94,1278,4541,2589,5550,3170,6090,3545,6500,3570,6500,3874,6500,3288,6500,4136,7000,4110,7000,4266,7000,4235,7000,4258,7000,4665,7000,4896,6500,5013,6500,4311,6398,4979,6500,5134,6500,5128,6500,,
    13,7.95,1331,5074,2766,6217,3376,6500,3912,6500,3946,6500,3966,6500,3828,6930,4848,7000,4833,7000,3674,6500,4680,6501,4646,6500,4898,6501,4719,6500,4688,6501,4812,6500,4687,6500,4737,6501,4822,6500,4759,6501
    14,7.98,3168,6500,4298,6500,4332,6500,4436,6500,4611,6500,4631,6500,3521,6500,4762,6501,4612,6500,4905,6500,4669,6500,4603,6501,4901,6500,4940,6500,4645,6500,4630,6501,4450,6500,4486,6500,5034,5512,4484,6500
    15,7.94,2474,6083,3405,6500,3843,6500,4954,6500,4986,6500,5545,7000,3890,6500,5021,6313,5123,6500,,,,,,,,,,,,,,,,,,,,,,
    16,7.94,2246,4482,2986,5482,3482,6196,3964,6500,4486,6500,4250,6500,3595,7000,4792,7000,4123,6500,4864,5979,4917,6026,4734,6500,4892,6500,5117,6501,5019,6500,,,,,,,,,,
    17,7.97,3384,6500,4495,6500,4456,6500,4489,6500,4449,6500,4817,6500,3827,6500,4676,6500,4796,6501,5091,6501,4872,5929,4839,6500,4778,6501,4785,6500,5063,6500,5122,6500,,,,,,,,
    18,7.95,1292,4464,2526,5512,2866,5868,3279,5318,3510,6370,3601,6500,3128,6383,4144,6199,4270,6433,4277,6500,4576,7000,3535,6396,4857,6500,5036,5916,4776,6500,4890,6501,5157,6500,5194,6500,,,,
    19,7.96,1868,5829,3190,6500,3640,5467,3884,5881,4058,6081,4143,6500,3077,7000,4102,7000,4140,6894,4502,7000,4626,7000,4536,6500,4525,6500,4630,6500,4431,6500,4556,6500,4709,6500,5007,6500,4711,6276,4932,6500
    20,7.94,1242,5666,2920,4839,3301,4844,3507,6500,3597,6500,3882,6500,3383,6500,4263,6485,4299,6901,4141,7000,4281,7000,4299,7000,5199,7000,4148,5897,5037,6256,4976,6500,5008,6501,5182,6501,,,,
    21,7.97,2024,4560,3178,4842,3493,6500,3968,6500,4281,6500,4312,6500,3617,7000,4622,7000,3591,6501,4686,6500,5076,6495,5038,6500,,,,,,,,,,,,,,,,
    22,7.94,2109,5510,2742,5698,3185,6413,3692,6500,4019,6175,3953,6500,4031,6500,4627,7000,4533,7000,4624,7500,3999,5789,4810,6501,5146,5028,4328,6500,5217,6500,4918,6500,4959,6500,5092,6500,4924,5905,4945,6501
    23,7.96,2434,5936,2970,6500,3257,6500,3251,6342,3720,6500,3900,6500,3133,7000,4392,7000,4365,7000,4701,7000,3669,4959,4175,6500,4855,6501,4837,6501,4689,6500,4870,6501,4986,6500,4986,6500,4888,6205,4901,6500
    24,7.97,2272,4655,3131,5334,3470,5818,3759,6442,3740,6500,4159,6500,3538,7000,4175,7000,4616,7000,3716,6501,4869,6500,4551,6278,4814,6501,4965,6501,4594,6500,5012,6500,4831,6500,4690,6500,4700,6500,4853,6500
    25,7.96,2204,6500,3031,5407,3587,5525,3826,6500,3991,6500,4273,6500,3623,7000,4746,7000,3903,4860,4108,6500,4843,6500,4958,6500,4776,6500,4988,6500,4761,6500,5086,6500,5239,6500,,,,,,
    26,7.97,1653,4021,2628,6331,3177,6256,3599,6500,3809,6500,3922,6500,3341,7000,4207,7000,4770,7000,3695,6500,4872,6500,4817,6500,4743,6500,5020,6500,4882,6500,4830,6500,4658,6501,4789,6500,4744,6500,4724,6500
    27,7.96,3741,6500,4247,6500,4352,6500,4486,6500,4490,6500,4541,6500,3599,6500,4635,6500,4589,6500,4626,6501,4711,6500,4620,6500,4590,6500,4782,6500,4609,6501,4896,6500,4576,6500,4925,6500,4925,6501,4601,6500
    28,7.94,2326,5182,3369,6500,3869,6500,4065,6500,4171,6500,4385,6500,3991,7000,4326,7000,4549,7000,3649,6500,4311,6500,4365,6500,4931,6500,4573,6500,4758,6500,4652,6500,4583,6501,4809,6500,4690,6500,4678,6500
    Below is how I rebuilt the battery packs:
    Code:
    Pack,Module,Max mAh
    1,15,5545
    1,25,5239
    2,6,5222
    2,22,5217
    3,20,5199
    3,18,5194
    4,1,5191
    4,12,5134
    5,8,5127
    5,5,5125
    6,7,5125
    6,17,5122
    7,16,5117
    7,3,5081
    8,21,5076
    8,4,5069
    9,11,5058
    9,14,5034
    10,26,5020
    10,24,5012
    11,19,5007
    11,9,4993
    12,23,4986
    12,28,4931
    13,27,4925
    13,10,4908
    14,13,4898
    14,2,4836
    I know this is long and a lot, so thanks so much for reading this, and thank you if you're able to provide some help!!
  2. WICruiser
    WICruiser New Member
    22
    WI
    My grand daughter's 2013 had a similar problem, loss of power and red triangle. Towed it to a Toyota dealer and they diagnosed the problem as an inverter failure that was covered under a class action lawsuit settlement.
    It is a long shot but you may want to spend the money to have a Toyota dealer inspect the hybrid system. You may get lucky and get a new inverter and fix your problem.
  3. bisco
    52,492
    doesn't sound like the battery to me. do yourself a favor and look into an autel maxi 200 code reader, instead of guessing and wasting time, money and labor.
    Brian1954 likes this.
  4. Brian1954
    Brian1954 Senior Member
    2,477
    990
    South Central PA, USA
    The hybrid battery will not cause the engine to run rough/surge.
    You need to use a good scanner to read all the trouble codes that your car has and then come back and post all the codes that were found.
    Read this Gen 2 OBD2 App Review thread, https://priuschat.com/index.php?posts/3290690
    I recommend the Autel AP200 because it is capable of communicating with all the ECUs in the car, which means that it can read all the trouble codes. Most scanners can not read all the trouble codes (Dr Prius, Car Scanner, etc). The Autel AP200 is a Bluetooth OBD2 dongle that you use with an Autel app on your phone or tablet. It costs about $60 on Amazon.
  5. Fit Yz
    Fit Yz New Member
    Tuesday
    Thank you all for the help! I looked at the Autel website and don't see either a "autel maxi 200 code reader" or a "Autel AP200". The closest scan tool I see is the Autel MaxiScan MS300 (I'm restricted from posting a link to it in their website). This doesn't seem right though. I just want to make sure I'm buying the right tool for this.
    Once confirmed, I'll get the scanner ordered! I do live in a rural area and mail takes a week. So my response with the codes may be delayed. But I'll be back! Thanks again!
  6. rjparker
    10,639
    6,668
    This is the Autel AP200 on Amazon
    Even though Autel and Launch are arguably the best aftermarket scanners and are the basis for many other brands, this low end version has its limitations.
    It is a capable data and code reader but has limited (practically no) bidirectional controls. It will give you codes although it can be slow to update. I found the graphing capabilities to be almost nonexistent.
    It allows you to choose one vehicle type for unlimited use with no recurring subscription, eg Toyota in your case. You need to pay a recurring $25 for each additional manufacturer.
    You won't be programming keys, ecus or directly testing pumps or controls. It claims to support Brake Booster setup but I have not heard of success on a Prius.
    Lately O'Reilly's seems to have better code scanners for free use.
    #6 rjparker, Apr 29, 2026 at 11:57 PM
