What else should be replaced when replacing the water pump?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, May 5, 2026.
  1. gatorback
    gatorback Junior Member
    60
    A 2010 (16 y.o) Prius with 95K miles was inherited and I would like to prevent any damage. As I understand it the water pump should be replaced because of its age?
    If that is correct, what other parts should I replace while I am in there?
  2. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    My impression is that coolant pump failures at such low mileage are rare, assuming it hasn't been coping with overheated coolant.
    When the pumps have to be replaced, people often replace the coolant thermostat at the same time, because it's easy then. However, I've yet to hear of an original thermostat actually failing at any mileage.
    gatorback likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    I still don't understand why Gen3 owners have been so passive about engine destroying ability of this valve failure via class action lawsuits? Head gasket failure due to a stuck valve boosting engine temperature is a smoking gun... Guess its not common enough for outrage of significance?
    #3 PriusCamper, May 6, 2026
  4. Mendel Leisk
    42,289
    Which valve? Maybe pre-edit?
    ^ got this alert too, Priuschat snafu?
  5. PriusCamper
    13,417
    5,416
    I got confused when reading this first time around and thought OP was mentioning a different valve, rather than just the EGR valve itself. Once I realized it, I edited you and Chapman out of me asking for help, but notification was already sent.
    Point being this is the first thread I've seen that specifically said valve was jammed and forcing engine temperature higher. As in cause and effect, which is much less vague than how others have presented EGR issues in the past.
  6. ChapmanF
    18,969
    Looks like maybe you mixed up this thread with the other recent one where the exhaust heat recirculation system was being discussed. That system has the little wax-thermostat actuator down on the exhaust pipe that waggles an exhaust valve, controlling whether the exhaust goes straight through the pipe, or has to go through the EHRS heat exchanger and heat up the coolant. If the valve gets stuck in the latter position, it heats up the coolant more than intended.
    In that other thread, rjparker posted graphs of the two temperature sensor readings, one at the engine water outlet, and one at the coolant return from the EHRS exchanger. The graphs show that your signal of the sticking valve is likely to be a temperature-warning light because of the EHRS temperature reading, while the engine temperature reading stays relatively tame. So you get notification of the EHRS issue and, ideally, go unstick it. I'm not sure how much excitement should be attached.
    Mendel Leisk and PriusCamper like this.
  7. gatorback
    60
    An LLM query returned a practical “long-life Gen 3 Prius protection” bundle:
    1. Engine water pump
    2. Thermostat + gasket
    3. Serpentine belt
    4. Fresh Toyota SLLC coolant
    5. Inspect/replace aging hoses as needed
    6. PCV valve
    7. Full EGR/intake cleaning
    8. Transaxle fluid drain/fill
    9. Inspect inverter pump operation
    10. Spark plugs (optional but reasonable)
    That combination addresses most of the common aging/failure paths on a low-mileage but older Gen 3 Prius. I'd appreciate any helpful comments from senior forum members.
  8. PriusCamper
    13,417
    5,416
    Perfect example of the LLM problem solved via a select all for reply... As in it lacks critical oversight / quality control. For example, there's no Serpentine belt in a Gen3 Prius. There's also only one or two things on that list that are relevant... Or as my personal AI was explaining to me earlier this evening:
    "AI reaches for rhetorical scaffolding the way a nervous speaker reaches for filler words. Brevity is harder because it requires knowing what to omit, which requires genuine judgment about what the reader already knows and what actually needs saying. AI tends to over-explain because it can't fully model that gap." --Claude
    #8 PriusCamper, May 8, 2026
  9. rjparker
    11,027
    6,916
    Actually it addresses none of the most common failure paths.
    Head gasket failure - design flaw
    Excessive Oil Burning - design flaw
    Inverter failure - design flaw
    Brake Booster Assembly -design flaw
    Hybrid battery - expected around 150k or higher
    Each was repaired free if they failed within certain timeframes and mileages.
    Improved parts include head gasket, pistons, rings, inverter power electronics and perhaps brake booster since repeat problems on the last item is rare.
    Sure you should do regular maintenance on fluids and spark plugs. Generally fluids twice as frequently as the maintenance schedule recommends. Plugs are ok as recommended around 100k. I believe oil and coolant are key. If its not burning any observable oil in 5k miles you want to keep it that way. Change the brake fluid every 50k.
    I have never changed my water pump in 350k miles. But I do have a temperature display with an early audible alarm.
    P10 display $35
    Change the fluids. Save for a new hybrid battery.
    #9 rjparker, May 8, 2026
    gatorback and Brian1954 like this.
  10. Mendel Leisk
    42,289
    I’d add periodic, in-depth brake inspection, and brake fluid replacement.
  11. pandion
    pandion Junior Member
    Florida, USA
    Aisin OEM thermostat. I'm not an original Toyota parts only zealot, but I've recently been burned by a name brand aftermarket thermostat and going to the OEM fixed it.
  12. rjparker
    11,027
    6,916
    The best thing to do is not use aftermarket parts in the cooling system, coils, hybrid batteries, egr valves or for sensors including the maf.
    Part of the aftermarket problem is poor quality. Another is straight out counterfeits advertising as oem using oem counterfeit boxes and part numbers.
    Example:
    New NGK coil costs owner thousands
    Watch through end where spark plug takes out a 40k mile engine
    About 95% of the time the original parts your car already has are better than the aftermarket or counterfeits. Which makes "preemptive" changes a crapshoot and waste of money.
    Quite a few times we hear how no problem or one problem turned into two or more issues after multiple parts were changed.
    Diagnosing a real problem first is the way to go.
    Changing fluids and spark plugs makes the best sense on a hybrid with no issues.
    #12 rjparker, May 10, 2026
  13. cdherman
    cdherman Member
    68
    27
    Kansas City
    I agree. IF your prius is burning no oil, then leave the EGR alone. Leave the intake manifold alone. Change all the fluids meticulously and put the best oil money can buy in every 10k mile or 5k if you feel like it. (my 2011 and 2014 Prius got Mobil 1, and have never burned oil (n=2, statistically irrelevant as most success/failure claims are, on the internet)
    The coolant temp gauge is an interesting option -- not likely to cause a failure, and way cheaper than a new water pump........
    Oh, one more suggestion that will not extend your Prius life, but DOES need to be done to save money -- grease the brake pad slider pins. The grease gets old before the pads wear out, and when the sliders stop working, you will ruin what's left of you pads and rotors......
  14. Leadfoot J. McCoalroller
    8,275
    7,776
    Pennsylvania
    2018 Prius c
    If you're going to replace anything, maybe get rid of the thought that a parts cannon fired at a top-ten list of problem areas is going to reset the clock and give you a bunch of carefree miles.
    An old Prius demands vigilance. Keep your powder dry (wallet closed!) and stay ready for the next hit.
    AzWxGuy likes this.
  15. Mendel Leisk
    42,289
    If the inference is that it's oil burning that causes the EGR to accumulate carbon, otherwise it'll be fine, I'll disagree.
  16. rjparker
    11,027
    6,916
    No inferences needed.
    I will agree to disagree. No excessive oil burning residue sucked into the egr before the cats (fixed in gen4 after the cats) means egr flow continues nicely.
  17. rjparker
    11,027
    6,916
    Above aftermarket video cut to spark plug takes out 40k 4Runner engine
    Discussing a 40k 4Runner. A reference to a Sienna minivan was about ignition coils costing the owner thousands.
    #17 rjparker, May 12, 2026
  18. cdherman
    cdherman Member
    68
    27
    Kansas City
    You are free to disagree. I have cleaned the EGR on two Prius, 2011 and 2014 both at around 140k miles, NOT burning oil, serviced by me from new with quality oil.
    Neither EGR was anyway clogged. First vehicle, the 2011 I did not bother to check the intake manifold. Its at 160k now and fine. Second vehicle, 2014 has a new headgasket, courtesy of leaking EGR AFTER IT WAS CLEANED....
    In short, the cult of EGR cleaning circulated here is not without its detractors.. I stand by my assertion. Do not clean or mess with a Prius that is not burning oil. Change out the fluids, and perhaps a temp gauge (to detect water pump failure early). I threw away two seemingly fine water pumps because they were at 140k miles and surely were on the edge of failure???? Neither had a crack, bulge or any other sign of malfunction.....
    Both original and got replaced with Aisin pumps. You can see the spot where Aisin ground off the Toyota badging.. Anyhow. In my opinion we have a brave new world where the internet (full of real knowledge, to be sure) can become a sounding chamber for the unproven.
    I think it is true that gen 3 prius have issues. What is clear as day is that if your Gen 3 burns oil, you will have problems. But the whole cascade of oil trap can, EGR cleaning, intake manifold cleaning is less clear at all for a Prius that does NOT have oil ring problems and oil consumption......
  19. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    The truth might be between extremes. Mine doesn't consume much oil. Overall EGR restriction is not bad at all, according to the Mode 6 self-test result. However, when I took off the manifold, the #1 EGR port appeared partially clogged.
  20. cdherman
    cdherman Member
    68
    27
    Kansas City
    When I say, ours burned no oil, I meant that. As in right where started after 10,000 miles. For vehicles that might burn "a little" oil, then EGR cooler cleaning over time probably makes more sense.
    My 2014 with the HG issues is back in town this weekend. After 2500 + miles the coolant and oil levels are rock stable, on the flat, in the cold. Seems likely I fixed things.
